![]() wrote in message ... On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. I'm not sure where this all fits in, but most lightweight bicycle frames have a reinforcing "lug" around the tubes at the joints. Are you talking bicycles or motorcycles? -- Jim in NC |
Morgans wrote:
wrote in message ... On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. I'm not sure where this all fits in, but most lightweight bicycle frames have a reinforcing "lug" around the tubes at the joints. Are you talking bicycles or motorcycles? Yep. And the tubes are sometinmes "stretched" to reduce weight, and the connections are often brazed. Go figer... Richard |
On Jan 2, 1:28 pm, "Morgans" wrote:
I'm not sure where this all fits in, but most lightweight bicycle frames have a reinforcing "lug" around the tubes at the joints. Are you talking bicycles or motorcycles? -- -------------------------------------------------------------------------- Hadn't really thought of it... but you CAN use O/A on a bicycle frame. The swaged fittings you mention are available as a kit, by the way. They are normally secured via brazing. This allows you to use very thin-walled tubing, resulting in excellent strength-to-weight for the finished frame. Motorsickles typically require heavier walled tubing and are almost always welded directly, typically with MIG. But if you take a close look at low-cost import bicycles you can see they tend to use heavier-walled tubing & MIG. (Just lift one. Big difference between a 'Red Dawn' and a custom-built bike (bicycle).) -R.S.Hoover |
![]() wrote Hadn't really thought of it... but you CAN use O/A on a bicycle frame. The swaged fittings you mention are available as a kit, by the way. They are normally secured via brazing. This allows you to use very thin-walled tubing, resulting in excellent strength-to-weight for the finished frame. Motorsickles typically require heavier walled tubing and are almost always welded directly, typically with MIG. But if you take a close look at low-cost import bicycles you can see they tend to use heavier-walled tubing & MIG. (Just lift one. Big difference between a 'Red Dawn' and a custom-built bike (bicycle).) Yep, and they get lighter all the time. I remember back in about 1973, I bought a Peugeot, UO-8, I think was the model. At the time, it was around 27 pounds, and considered to be pretty light. Now, that's a tank, compared to the new models. -- Jim in NC |
![]() "Richard Riley" wrote in message ... On Fri, 28 Dec 2007 19:46:57 -0800 (PST), " wrote: On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. If brazing gives stronger joints that normalized 4130, why aren't we brazing airframes? (I'm not saying it's an incorrect statement - I know better than to disagree with VD on something like this. I just figure there must be a reason, like the brazing compounds are more expensive.) Won't withstand high temperatures? |
Blueskies wrote:
"Richard Riley" wrote in message ... On Fri, 28 Dec 2007 19:46:57 -0800 (PST), " wrote: On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. If brazing gives stronger joints that normalized 4130, why aren't we brazing airframes? (I'm not saying it's an incorrect statement - I know better than to disagree with VD on something like this. I just figure there must be a reason, like the brazing compounds are more expensive.) Won't withstand high temperatures? Structural brazing works just fine - if done correctly. But too much heat causes the brass to migrate into the grain of the 4130 - resulting in cracks. It HAS to be done right. And there is no way to tell afterwards if it was or not - until it breaks. Richard |
![]() "cavelamb himself" wrote in message ... Structural brazing works just fine - if done correctly. But too much heat causes the brass to migrate into the grain of the 4130 - resulting in cracks. It HAS to be done right. And there is no way to tell afterwards if it was or not - until it breaks. Richard I meant while the part was in service. If an engine mount was brazed, and there was an engine fire, would the braze joint fail (come apart) where a welded one would hold? |
Blueskies wrote:
"cavelamb himself" wrote in message ... Structural brazing works just fine - if done correctly. But too much heat causes the brass to migrate into the grain of the 4130 - resulting in cracks. It HAS to be done right. And there is no way to tell afterwards if it was or not - until it breaks. Richard I meant while the part was in service. If an engine mount was brazed, and there was an engine fire, would the braze joint fail (come apart) where a welded one would hold? Dunno, Mongo. I guess it would depend on how hot for how long. But remember that it takes an acetylene flame to braze in the first place. If if gets that hot in the engine room, whether the mount welds hold or not is probably going to be a secondary issue... Richard |
On Wed, 02 Jan 2008 13:22:24 GMT, "Blueskies"
wrote: "Richard Riley" wrote in message ... On Fri, 28 Dec 2007 19:46:57 -0800 (PST), " wrote: On Dec 28, 2:57 pm, wright1902glider wrote: the author seems to think that 4130 cro-mo steel can't be welded with an oxy- acetylene torch. -------------------------------------------------------------------------------- Pure bull****. Indeed, for the stresses encountered in bicycles (which is what he's talking about) there are any number of BRAZING compounds that yield joints stronger than than normalized 4130. O/A does just fine airframes... and for bike frames. If brazing gives stronger joints that normalized 4130, why aren't we brazing airframes? (I'm not saying it's an incorrect statement - I know better than to disagree with VD on something like this. I just figure there must be a reason, like the brazing compounds are more expensive.) Won't withstand high temperatures? Will withstand temperatures higher than anything attatched to the airframe will ever withstand. -- Posted via a free Usenet account from http://www.teranews.com |
On Jan 1, 9:54 pm, Richard Riley wrote:
If brazing gives stronger joints that normalized 4130, why aren't we brazing airframes? (I'm not saying it's an incorrect statement - I know better than to disagree with VD on something like this. I just figure there must be a reason, like the brazing compounds are more expensive.) ----------------------------------------------------------------------------- Dear Richard, That's a good question but you're asking the wrong guy. Also, it isn't just ANY brazing, it is a form of eutectic brazing developed specifically for alloy steels, initially for use in military weapon systems as a means of reducing the cost & weight of certain structures. The components are cut very accurately on CNC equipment and most of the joins were done in an oven with the parts secured in a jig. The only problem I can see with this method is that REPAIRS would be rather difficult; certainly not as convenient as with an O/A torch and wire coat hanger :-) Dig through French's books. If he hasn't written something about it, he should have. -R.S.Hoover |
4130 sheet | log | Home Built | 4 | September 1st 04 01:42 AM |
4130 - bad news... | Richard Lamb | Home Built | 28 | May 17th 04 04:08 PM |
IS the US out of 4130 Steel? | mallakka | Owning | 0 | April 21st 04 10:48 AM |
Why 4130 tube? | Leon McAtee | Home Built | 31 | March 28th 04 03:04 PM |
4130 frame? | Steve Thomas | Home Built | 23 | August 27th 03 05:50 PM |
