Martin Gregorie wrote:
Interesting airport numbers from the FAA's NASR datamabase: I've read about an experimental circular runway being built in the USA - how many runways should it be counted as in this database? hmmm. perhaps 3.14? -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...aring/200801/1 |
Tuno wrote: Interesting airport numbers from the FAA's NASR datamabase: I've read about an experimental circular runway being built in the USA during the '20s or '30s: - where it was - does it still exist - how many runways should it be counted as in this database? Enquiring minds want to know. Likewise, I've read 'somewhere' of the same circular runway concept being made and tested, as well as an account by one of the pilots chosen to take off and land on it. Unfortunately, I can't lay my hands on the reference (boo hiss). Can't remember where it was (SW USA, I seem to remember), or when, but I seem to remember a picture of a 'Douglas SkyRaider-like' plane on the upper banking (imagine the upside down circumferential bits of a frisbee, from level through 25-degrees or so of banking). I also seem to remember: 1) the pilot reporting nothing fundamentally concept-killing was discovered during the tests...though certainly re-thinking the concept of 'airport' would've been necessary, and, making the requisite access tunnels for interior road access would add to initial costs, and 2) reference to it eventually being torn up. IIRC, crosswinds weren't an issue during their tests... Workable circular logic??? Rgds, Bob W. |
Banking would not have a whole lot to do with it after
losing flying speed. The turn would be cause by the rudder's acting against the wheel and blowng the tail around-- if you can keep the tail wheel off the ground. A little bit of bank would probably be helpful but there would be no need to get the wing tip close to the ground unless there is a really big cross wind. At 16:18 03 January 2008, Chris wrote: On Jan 3, 10:16=A0am, Martin Gregorie wrote: I've read about an experimental circular runway being built in the USA during the '20s or '30s: Speaking of which, I've been wondering how easy it would be to land in a curved field. Is there much special technique to landing on a curved field with trees on the sides? I suppose the biggest challenge would be to touch down at the right spot tangent to the curve and keep the right bank angle in through the pattern all the way to the stop. Suppose somebody could try it on a big square field. Not dragging the inside wing would be the biggest challenge, maybe a high wing glider like a K-8 would be easier. Chris |
One technique I've heard discussed is how to land on a center pivot alfalfa
field. The thought expressed was to plan to land crosswind on the downwind side of the circle so the crosswind helps the glider make the turn to follow the lane between the pivot arm wheel tracks. "Nyal Williams" wrote in message ... Banking would not have a whole lot to do with it after losing flying speed. The turn would be cause by the rudder's acting against the wheel and blowng the tail around-- if you can keep the tail wheel off the ground. A little bit of bank would probably be helpful but there would be no need to get the wing tip close to the ground unless there is a really big cross wind. At 16:18 03 January 2008, Chris wrote: On Jan 3, 10:16=A0am, Martin Gregorie wrote: I've read about an experimental circular runway being built in the USA during the '20s or '30s: Speaking of which, I've been wondering how easy it would be to land in a curved field. Is there much special technique to landing on a curved field with trees on the sides? I suppose the biggest challenge would be to touch down at the right spot tangent to the curve and keep the right bank angle in through the pattern all the way to the stop. Suppose somebody could try it on a big square field. Not dragging the inside wing would be the biggest challenge, maybe a high wing glider like a K-8 would be easier. Chris |
On Jan 3, 2:13Â*am, Tuno wrote:
Interesting airport numbers from the FAA's NASR datamabase: Â* FacilityType Â*Count Â* AIRPORT Â* Â* Â* 12641 Â* GLIDERPORT Â* Â*34 Interesting statistics. I guess that you have lots of glider operations at what the FAA classify as "airports". UK figures, from the last BGA table of annual club statistics (published each year in our magazine Sailplane and Gliding) a 92 BGA Clubs. In terms of sites, these consist of: 26 at airfields with other flying activities 66 operate from their own site (they own or rent the site and are the prime operator at the site) Ian Strachan Lasham Gliding Centre (yes, we bought the site!) |
operations at what the FAA classify as "airports". There are a number of airports shown on the charts as gliderports but listed in the database as airports. Crystal (CA), Adelnto (CA), and Pleasant Valley (AZ, aka Turf Soaring) among them. I'm curious how many others there are. btw my first set of numbers were incorrect. Should be: AIRPORT 13903 BALLOONPORT 15 GLIDERPORT 35 HELIPORT 5683 SEAPLANE BASE 526 STOLPORT 87 ULTRALIGHT 147 Total 20396 2NO |
Digital airspace data question -- any FAA data gurus out there? | Tuno | Piloting | 2 | December 27th 07 05:06 PM |
Flight Data recorders on a 757 - What data? | Al Dykes | General Aviation | 0 | January 1st 07 05:09 PM |
Some interesting data from today's Washington Post...re general aviation pilot numbers | Stewart Kissel | Soaring | 2 | July 28th 06 10:59 PM |
OT, but very interesting. | Flyingmonk | Piloting | 11 | January 16th 06 03:48 AM |
interesting | aluckyguess | Piloting | 11 | October 27th 04 11:10 PM |
