On Jan 13, 5:33 pm, wrote:
Mat, training yourself to use an AOA indicator takes about 30 seconds - it's really obvious. Training to use the ASI for pitch attitude without reference to the visible horizon takes many hours of intensive training and even then most pilots don't do it well. AOA indicators are about reducing information overload, not increasing it. An AOA indicator IS a stall warning with far greater resolution. The EASY way to fly is with an AOA. The HARD way is to do without it. . Bill Daniels So, we are talking about pitch attitude control without reference to the visible horizon. In that situation how do we control roll and yaw? The same way as we control roll and yaw in normal flight, since we don't need a horizon to do this. Roll can be detected as long as there is a reference in the distance we can see we are rolling with respect to, and yaw can be detected using a yaw string or slip ball. Balanced bank will always produce a turn, which can of course be seen as the reference surface moving past the nose. |
wrote in message ... Mat, training yourself to use an AOA indicator takes about 30 seconds - it's really obvious. Training to use the ASI for pitch attitude without reference to the visible horizon takes many hours of intensive training and even then most pilots don't do it well. AOA indicators are about reducing information overload, not increasing it. An AOA indicator IS a stall warning with far greater resolution. The EASY way to fly is with an AOA. The HARD way is to do without it. . Bill Daniels So, we are talking about pitch attitude control without reference to the visible horizon. In that situation how do we control roll and yaw? I wrote a confusing line. It should have said "controlling AOA with the ASI and no relaible horizon is difficult." By saying, "Attempting to use aircraft attitude (deck angle) without a reliable horizon will get you killed real fast" do you mean attempting to CONTROL attitude, or attempting to DETERMINE aircraft attitude? Does it matter? If you can't detemine attitude, you can't control it. Bill D Obviously, if you can't DETERMINE attitude, you can't CONTROL it. |
On Jan 13, 9:05*am, "Bill Daniels" bildan@comcast-dot-net wrote:
To tie Fred's comments about false horizons to the thread on mountain flying, think about the situation when you descend into a mountain valley. As you drop below the ridge line, you lose a useful horizon reference. *If you keep the nose on the jagged line between ridge top and sky, your nose will get higher and higher as you continue the decent - you have to point the nose at some indeterminate point on the sides of the valley to maintain the desired airspeed and prevent a stall. This is a subtitle trap that snares many 'flatland' pilots on their first mountain trip - usually in an overloaded Cessna 172 right after takeoff. These pilots have learned to use the familiar, reliable horizon line at their home airports. *It's always there and they have always relied heavily on it. *Take it away, and their pilot skills evaporate. It's quite possible to fly pitch attitude with reference to the airspeed indicator but that's a instrument rated pilot *"partial panel" trick and most pilots either aren't trained to do it or aren't good at it. An AOA indicator solves the problem nicely. Bill Daniels "fredsez" wrote in message ... So many good ideas on AoA. *Much thought and real considerationhas have been expressed. Something (A-HA!) came to mind. Visual indicators! Back in 1901, *or some where about then, I flew a 1-26 to a really high altitude. I had left the area of recognizable land and decided to look at the ground and figure out where I was. Before I had that good idea, I was looking right at the sun, well above the horizon. Looking down, all I could see was black! The land was in definate NIGHT TIME! I have always been a FLAT EARTH person. I have also watched the sun go around the earth! I get up with the sun in the east and go to bed with it setting in the west. From umpteen thousand ft, I spotted a little (very little) strip of light. There was where I decided they would find my body. I opened the airbrakes and managed to find a lighted strip of asphalt at an intersection in Nevada. The rest of the story is interesting (to me) but has little to do with AoA. At my air strip, when you turn onto base leg, the ground rises, *With the horizon high, pilots tend to raise the nose to see a normal sight picture. Airspeed slows,.. things don't look right and some push rudder to point the nose down the runway...or at the tie-down area. At thousands of ft in the air, the horizon looks low relative to the instrument panel. At pattern altitude, the horizon looks higher and may lead a pilot to raise the nose, losing airspeed in the turn onto final. I need to make changes. What should I do? Maybe reverse the pattern and let pilots see the lower horizon and tend to make them let the nose down? Maybe I ought to go to bed and let things be as they will be. Fred.- Hide quoted text - - Show quoted text - Chuckle .........That's what I do when I see Fred here...haha Doesn't anyone use trim anymore? Some good aircraft fly best when they are not being touched. Some of them even thermal well by themselves.with a good trim setting. In the Blanik it used to be all the way back. When teaching beginners, I would show them how well aircraft fly by themselves. Guess as an old mtn-pilot, that's what I have always used: Trim and airspeed x-check. The 1-26, even in 1901 must have had a decent trim tab? Never owned one, but in the 2-33 I always remember yelling to the student in front" And now...trim forward. For some it would take a while to figure that out with that funny latch. With it all the way forward that bird would hurry home nicely. Of course one have to let it, and not use your biceps much. Coming back to the Blanik ...a little more advanced, after thermaling tightly with trim al the way back. If the pilot would forget to readjust the trim for level flight one could find oneself in a stall- spin situation! Teaching in the Blanik I would do that some time, sneak the trim slowly back. A student with a touch or feel would notice, also eye for airspeed. Muscel people would make a spin entry. Yeah Fred, didn't we have fun? Dieter Gliders Of Aspen |
At 05:36 14 January 2008, Eric Greenwell wrote:
Nope! We're not after an attitude indicator; we are talking about a relative wind indicator. We could call it something catchy, like an 'artificial horizon'! Well, maybe that's a simple way to get an attitude indicator that's commercially available for a $1000 or so, solid state so power consumption is low, and easily installed. It might indicate the AOA accurately enough in steady flight for performance optimizing. Anyone tried it? -- Eric Greenwell - Washington State, USA * Change 'netto' to 'net' to email me directly * 'Transponders in Sailplanes' http://tinyurl.com/y739x4 * 'A Guide to Self-launching Sailplane Operation' at www.motorglider.org |
| Anyone Here Ever Seen That Crappy Film Deep Impact? | Michael Baldwin, Bruce[_2_] | Products | 6 | August 21st 07 07:03 AM |
| El Nino impact on NZ soaring | Richard Hanschu | Soaring | 0 | September 14th 04 08:22 AM |
| Impact of noise control efforts on landouts? | nafod40 | Soaring | 9 | May 17th 04 05:28 PM |
| Impact of Eurofighters in the Middle East | Quant | Military Aviation | 164 | October 4th 03 05:33 PM |
| Surgical hardware's impact on a USAF recruit? | Raptor | Military Aviation | 13 | September 15th 03 11:58 AM |
