Richard: Thanks for the interesting article. The one problem with the
analysis is that the typical hardware store Grade 8 or Grade 5 don't seem to have the inspection processes to assure that they really are of the 120ksi or 150ksi. Assuming the grade 8 bolts really are grade 8, I have no trouble calculating a big safety factor in my application. However if they are only marked grade 8 but are of a lesser quality material?? Over in Engr.tips.com I get pummelled for talking about using any bolt not covered by either AN (grade 5) or MS which can go grade 8. However, with the counterfeit bolts that have slipped into the US I am not sure that an AN bolt is an AN bolt. Another curiosity found in the helicopter and not in his Rock crawler is the vibration frequency. My helicopter has a 2/rev vibration generated in the blades a propogates thru the head into the main rotor shaft and beyond. 2/rev corresponds to 61,200 cycles/hour. For a 10million cycle for fatigue failure, this is only 163hrs. Since fatigue strength is usually a fraction of tensile strength, the stronger bolts can jack the 10million cycle to 20million and beyond. The grade 8 bolt, and I hope it is a true grade 8 bolt, can give me more of a margin. Of course proper torqueing keeps the stress from truly cycling and I get a larger margin. Thanks again for your post as it kicked my little grey cells into gear and has motivated me more to explore the bolted joints to a greater degree. Stu "cavelamb himself" wrote in message ... Back to bolts... My point was that an super strong bolt can overtress the attached structure without any indication that it has happened - until a fitting breaks or something like that. This fellow comes to a different conclusion than I usually do. THe last line "When in doubt make it stout" will appeal to those who think an airplane can be built so strong that it can not be broken. But I trust that you, of all people, will know better than that. Very informative article on bolts - grad 5 vs grade 8. http://www.rockcrawler.com/techrepor...ners/index.asp Richard |
Stuart & Kathryn Fields wrote:
Richard: Thanks for the interesting article. The one problem with the analysis is that the typical hardware store Grade 8 or Grade 5 don't seem to have the inspection processes to assure that they really are of the 120ksi or 150ksi. Assuming the grade 8 bolts really are grade 8, I have no trouble calculating a big safety factor in my application. However if they are only marked grade 8 but are of a lesser quality material?? Over in Engr.tips.com I get pummelled for talking about using any bolt not covered by either AN (grade 5) or MS which can go grade 8. However, with the counterfeit bolts that have slipped into the US I am not sure that an AN bolt is an AN bolt. Another curiosity found in the helicopter and not in his Rock crawler is the vibration frequency. My helicopter has a 2/rev vibration generated in the blades a propogates thru the head into the main rotor shaft and beyond. 2/rev corresponds to 61,200 cycles/hour. For a 10million cycle for fatigue failure, this is only 163hrs. Since fatigue strength is usually a fraction of tensile strength, the stronger bolts can jack the 10million cycle to 20million and beyond. The grade 8 bolt, and I hope it is a true grade 8 bolt, can give me more of a margin. Of course proper torqueing keeps the stress from truly cycling and I get a larger margin. Thanks again for your post as it kicked my little grey cells into gear and has motivated me more to explore the bolted joints to a greater degree. Stu "cavelamb himself" wrote in message ... You get that many pieces vibrating at that any frequencies, then it must be a helicopter. The main and most important difference between great quality commercial hardware and plane jane aircraft stuff are two little details One is that the aircraft stuff has been x-rayed and defects culled. The other is the audit trail paper work. They go hand in hand when you really need the quality. Now if you can KNOW (rather than hope) you are really getting real grad 8's - and can KNOW that they have no internal voids or cracks - by all means go fer it. On the other hand is yer big bad butt worth $80 worth of bolts? On the other - other hand, I haven't been in a helicopter in - golly - 39 years now. And I'm ok with that... Respects, Richard |
| Thread Tools | |
| Display Modes | |
| Looking for Stuart K. Schwartz ? | chum | Soaring | 0 | May 30th 06 10:00 PM |
| PING Jay H ... | Jay Beckman | Piloting | 11 | February 1st 06 04:18 AM |
| Neil Stuart Lawson - Book of Condolence | Pete Masson | Soaring | 0 | August 13th 05 09:20 PM |
| Stuart FL F86 Accident | EDR | Piloting | 4 | November 12th 03 06:16 AM |
| Stuart Schwartz | [email protected] | Soaring | 0 | July 28th 03 03:56 AM |
