Thielert (Diesel Engines)
Old February 14th 08, 01:53 PM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert
Default Thielert (Diesel Engines)
Peter,
AFAIK this was forced on them by all the failure
Sorry, but that's completely wrong. "Power by the hour" was a Thielert
concept from the get-go.
But I bet the "scrap" engines get reworked by Thielert
You lose.
Why is it that each and every innovation in GA is met by people
spouting OWTs and made-up speculation, when a minute or two of simple
research would provide the facts? What picture does that paint of the
pilot population and their "hangar talk"? How about a simple "I don't
know and that's why I keep quiet on this" instead of spouting made-up
negatives? Sorry, but this is really annoying.
Thomas Borchert (EDDH)
Old February 14th 08, 03:12 PM posted to rec.aviation.owning,rec.aviation.piloting
Bertie the Bunyip[_25_]
Thomas Borchert wrote in
Peter,
You lose.
There's nothing made up about "No sparks, no power" I wouldn't buy one
because of this. My club was looking at one ofr a Cherokee and decided
against it because of the lack of limp home capability.
Bertie
Old February 15th 08, 07:44 PM posted to rec.aviation.owning,rec.aviation.piloting
Peter wrote in
You need to calm down Thomas before jumping on people like this.
Dunno, I kinda like him this way. Pounding on his keyboard, teeth gritted,
veins standing out on his neck. Standing on tiptoe, even though seated, his
leg muscles trembling. It's a good look for him.
Bertie
Old February 15th 08, 08:28 PM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert
Peter,
When you have calmed down, speak PRIVATELY to a few Diamond/Thielert
owners. I have.
Thanks, I have, too.
There is some way to go before Thielert have a reliable engine. I am
sure they will get there eventually, but they aren't there yet.
I agree completely. And I never said anything to the contrary. That's
not what I'm getting upset about.
Old February 13th 08, 07:21 PM posted to rec.aviation.owning, rec.aviation.piloting
WingFlaps
On Feb 13, 11:14*pm, Peter wrote:
WingFlaps wrote
Why should that be? Generally, diesels are great at running at high
power for long periods and they are also *the powerplant of choice for
high reliability when fuel consumption is also an issue (ruling out
turbines) -or am I wrong?
Diesels are indeed great in applications where they can be designed
without weight issues e.g. ships and trucks.
It appears that their problems (Thielert specifically - there is no
other diesel actually flying any meaningful hours at present) are to
do with a lightweight car engine - 1.7 litres - being run at 130HP (or
close to it) for 100% of the time. The original car engine would be
running at 20-30HP, maybe 100HP very briefly in a big Merc on a German
motorway (no speed limits). But an aeroplane is a whole different
situation.
Yes I've heard that argument but I'd like to add/offer a different
POV. What is really stressful for engines is constant power changes
and the temperature fluctuations that involves. Therefore if your
engine can do 150 mph on a german autobahn for an hour or two it
should have no trouble doing it for a 4 hour flight in a plane. I also
agree that marine installations pay no/little attention to weight
(some performance boat installations aim to keep weight low) but tha's
just a design thing. The natural rpm/torque curve for diesels seems to
match a prop better too. The metals exists to make a diesel about the
same weight as a petrol engine so with a bit more hours under their
belt to identify weaknesses I can't see diesels not becoming the (?)
engine of choice (more range, less fuel quality issues). One more
think, no mixture control just rpm and pitch!
Imagine just setting rpm just one and then doing everything else with
pitch ;-) ...
Cheers
Old February 14th 08, 02:41 PM posted to rec.aviation.owning,rec.aviation.piloting
Stefan
WingFlaps schrieb:
One more think, no mixture control just rpm and pitch!
pitch ;-) ...
There's nothing Diesel specific on this.
Old February 13th 08, 10:54 PM posted to rec.aviation.owning, rec.aviation.piloting
nrp
The weakness of the certification regime is that the engine only has
to show 2000hrs at 100% power,
I think it is 200 hrs @full throttle.
Old February 14th 08, 01:08 AM posted to rec.aviation.owning, rec.aviation.piloting
WingFlaps
IMHO it is a matter of degree. No road car will be actually run at say
75% power for more than minutes - you would kill yourself. Rally cars
get through engines at great rates, often breaking one in one race.
Whereas an aero engine just sits there the whole time at that power
setting. This may be just a matter of duty cycle but the end result
will be more stress and more wear.
to show 2000hrs at 100% power, and TBH you could probably get a lawn
mower engine to do that. Any engine that doesn't actually break (and
that is easy to achieve by design) and which meets the criteria (e.g.
starting at the certified ceiling) will be certified.
AFAIK there is no reliability requirement - that certainly applies to
avionics too.
I also
match a prop better too. *
It may be but diesels have a lot more high frequency components in
their torque spectrum which plays havoc with props and gearboxes. So
they tend to need rubber shock absorbers.
I agree but that is FADEC, not diesel. With FADEC on a Lyco you would
have similar benefits.
I was under the impression that diesels work by a governor that sets
RPM. The difference between desired rpm and actual rpm determines fuel
injected... In that case you could just set rpm and just adjust pitch
for speed/power. A single power knob (fadec) sets pitch and rpm
together?
Cheers
Old February 17th 08, 04:22 PM posted to rec.aviation.owning,rec.aviation.piloting
Stan Prevost
I haven't really been following this thread, but I thought I would interject
something I just learned about Thielert diesels.
A local flight school which also rents out airplanes, just got a DA42
Twinstar. An engine quit during a flight a few days ago. The pilot shut it
down, then later attempted a restart. It started back up and ran fine for a
few minutes, then quit again. No anomalous indication on any of the engine
instrumentation.
Turns out that an oil filter in a gearbox, I believe it was, was clogged.
The computer senses that and shuts the engine down. No warning, no
indication of trouble, just shuts it down, or takes it down to very low
power. Saves the engine in preference to the pilot. This seems to not be a
rare event with these engines.
"Charles Talleyrand" wrote in message
This data is from 2006, they Thielert has not released a 2007 annual
report yet.
The annual report for Thielert, which makes diesel engines for certain
single-engine Cessnas, Pipers, and Diamonds, shows an increase in
sales of aircraft engines from 22 million Euros to 31 million Euros.
That's a 44% increase. It's probably over 1000 engines in total.
They are the third largest piston engine maker in the world (which
surprises me, I would have thought Lycoming, Continental, and Rotax).
The total market for piston aircraft engines is about 13,000 including
both new planes and the larger replacement market.
They aim to sell helicopter engines in 2009.
The best quote from the annual report: "We aim to achieve a market
share in piston aircraft engines of over 50% in the medium term. The
necessary demand and customer base are already in place."
Maybe diesel engines are catching on??????
Old February 17th 08, 08:44 PM posted to rec.aviation.owning,rec.aviation.piloting
"Stan Prevost" wrote in
interject something I just learned about Thielert diesels.
shut it down, then later attempted a restart. It started back up and
ran fine for a few minutes, then quit again. No anomalous indication
on any of the engine instrumentation.
clogged. The computer senses that and shuts the engine down. No
warning, no indication of trouble, just shuts it down, or takes it
down to very low power. Saves the engine in preference to the pilot.
This seems to not be a rare event with these engines.
Oh boy. I definitely want one now.
Bertie
Thielert (Diesel Engines) Charles Talleyrand Piloting 108 February 19th 08 04:59 PM
diesel 160-200HP engines geo Home Built 27 April 2nd 04 04:27 PM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Home Built 3 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M General Aviation 2 September 13th 03 12:44 AM
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot Roland M Rotorcraft 2 September 13th 03 12:44 AM
