Last November, I chaired a panel at the local SSA affiliate (PASCO)'s
Soaring Safety Seminar entitled "Complacency: What Me Worry?" I wrote up my part of that and made it available at http://ee.stanford.edu/~hellman/soar...2007_talk.html Just today, PASCO got a request from the Capetown S.A. soaring club to reprint the article with the following explanation: "The reason for writing to you is that my gliding club was unfortunate to lose a member recently in a ridge accident. He was an extremely experienced ridge pilot and only on his eighth flight in his brand new DG808. Your PASCO Safety Seminar article titled "Complacency" is therefore of particular relevance to our members." My Soaring Safety page http://ee.stanford.edu/~hellman/soaring/safety.html has links to several other highly relevant articles. With respect to ridge soaring and the too regular fatalities of "extremely experienced ridge pilots" please see the links to Henry Combs article and JJ Sinclair's. Gantenbrink's speech is a must read if you haven't seen it, though I suspect most of you have. But, then again, it is worth reading more than once. Hoping this helps. Martin N56WT |
Very good post and links. I consider myself a novice ridge flyer and,
despite having done a fair amount of reading on the subject, have never seen this phenomenon addressed. Being low on ridge experience, I tend to give the mountain a pretty wide berth but, as my confidence level goes up and I start flying closer, the chances of encountering this will increase. It has happened to me only a couple times at altitude (once while still on tow) and, initially, scared me pretty good each time. Being at what seems to be a 90 degree bank with full opposite control inputs is a little disconcerting. A few seconds of "What the*#!%?" followed by "Wow! Let me get back to that thermal!" Great food for thought as the ridge season in the northeast approaches. Mike |
On Feb 13, 12:17*pm, wrote:
Last November, I chaired a panel at the local SSA affiliate (PASCO)'s Soaring Safety Seminar entitled "Complacency: What Me Worry?" I wrote up my part of that and made it available at http://ee.stanford.edu/~hellman/soar...2007_talk.html Just today, PASCO got a request from the Capetown S.A. soaring club to reprint the article with the following explanation: "The reason for writing to you is that my gliding club was unfortunate to lose a member recently in a ridge accident. *He was an extremely experienced ridge pilot and only on his eighth flight in his brand new DG808. Your PASCO Safety Seminar article titled "Complacency" is therefore of particular relevance to our members." My Soaring Safety page http://ee.stanford.edu/~hellman/soaring/safety.html has links to several other highly relevant articles. With respect to ridge soaring and the too regular fatalities of "extremely experienced ridge pilots" please see the links to Henry Combs article and JJ Sinclair's. Gantenbrink's speech is a must read if you haven't seen it, though I suspect most of you have. But, then again, it is worth reading more than once. Hoping this helps. Martin N56WT In the Henry Combs article, what did happen to Chet Lymon? He survived and so did/does he confirm his roll control authority was overpowered? |
This discussion brings to mind an episode I had relatively early in my
soaring life. After licensing at Tehachepi in a 2-33, I went to Crystal to transition to glass in their Grob 103's. After being cleared to solo I was flying along the San Gabriel's in an area that had been shown to me. The lift was sketchy and I was flying long passes through bands of weak lift, not very close to the mountain, (I was and still am quite cowardly). After hitting a strengthening patch of lift through two passes, I had the brilliant idea to try circling. I made two circles just like it was any other thermal I had flown and then, between heartbeats, It all went to schist. I heard a loud bang and instantly i was no longer flying. the car keys in my shirt pocket were pinned against the canopy and all the gravel and dust on the floor was floating in front of me. my angle of bank entering into this was shallow and I think both wings hit at the same time. If it had been one wing only, I would have been vertical or inverted faster than I could have moved the controls to react. Luckily I was pointed away from the mountain, and recovery was to simply nose down and pull out. My own personal recovery took considerably longer. There is no skill in the world that could tame that kind of sharp edged shear while rock polishing, in my estimation. Mark Jardini |
Sadly, we lost Stew Kissel shortly after I wrote "Don't Smack the
Mountain-101", so we need to add yet another name to the list of "Mysterious high energy impacts on the side of a mountain". I live by the rules I stated and so far (35 years & 5000 hours in the Sierras & Whites) they have kept me from impacting the mountain. JJ |
On Feb 14, 2:06*pm, wrote:
In the Henry Combs article, what did happen to Chet Lymon? He survived and so did/does he confirm his roll control authority was overpowered? I checked with my friend who knew Combs and gave me the article, but so far he hasn't been able to provide an answer to the above question. I did do a search of the NTSB database and found the report attached below which says he encountered wind shear. The longer report lists the wind as 270@13, so I suspect they really meant a thermally induced wind shear. If that was the case, it wasn't quite the same mechanism that Combs described but the point is still there. Anytime we fly close to terrain, life is much more dangerous since there's less time (no time sometimes) to recover from an anomaly -- be it a wing lifted (as Combs describes), wind shear that causes a stall, etc. Hope this helps. Martin NTSB Identification: LAX84FA315 . The docket is stored on NTSB microfiche number 25291. 14 CFR Part 91: General Aviation Accident occurred Saturday, May 26, 1984 in LLANO, CA Aircraft: Bölkow PHOEBUS A-1, registration: N7700 Injuries: 1 Serious. CIRCLING IN LIFT NEAR A HIGH RIDGE THE SAILPLANE ENCOUNTERED WHAT THE PLT REFERRED TO AS WIND SHEAR. LOSING CONTROL, THE SAILPLANE COLLIDED WITH A TREE BEFORE IMPACTING THE GROUND. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: WEATHER CONDITION..WINDSHEAR AIRSPEED(VS)..NOT MAINTAINED..PILOT IN COMMAND |
Mark Jardini wrote:
This discussion brings to mind an episode I had relatively early in my soaring life. After licensing at Tehachepi in a 2-33, I went to Crystal to transition to glass in their Grob 103's. After being cleared to solo I was flying along the San Gabriel's in an area that had been shown to me. The lift was sketchy and I was flying long passes through bands of weak lift, not very close to the mountain, (I was and still am quite cowardly). After hitting a strengthening patch of lift through two passes, I had the brilliant idea to try circling. I made two circles just like it was any other thermal I had flown and then, between heartbeats, It all went to schist. "Going to schist" When rock polishing goes bad. Yeah, yeah, I know what your thinking "How gneiss." ;-) Shawn |
I remember reading an article, I thought it was Henry Combs, but not
sure, about a technique of rolling inverted deliberately and moving away from the mountain inverted, when encountering such a gust. It made sense to me, if you roll authority is less than the strength of the gust, then don't fight it and even reverse input and let yourself go inverted. You can then turn away inverted, or at least not into the mountain. Sounds like a Judo move to me. Does anyone remember this article or concur with this technique? |
On Feb 15, 12:39 pm, Shawn wrote:
Mark Jardini wrote: This discussion brings to mind an episode I had relatively early in my soaring life. After licensing at Tehachepi in a 2-33, I went to Crystal to transition to glass in their Grob 103's. After being cleared to solo I was flying along the San Gabriel's in an area that had been shown to me. The lift was sketchy and I was flying long passes through bands of weak lift, not very close to the mountain, (I was and still am quite cowardly). After hitting a strengthening patch of lift through two passes, I had the brilliant idea to try circling. I made two circles just like it was any other thermal I had flown and then, between heartbeats, It all went to schist. "Going to schist" When rock polishing goes bad. Yeah, yeah, I know what your thinking "How gneiss." ;-) Shawn Oh, that's just marbelous. |
| USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 | [email protected] | Soaring | 0 | November 9th 07 12:15 AM |
| The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA | [email protected] | Soaring | 0 | September 11th 06 04:48 AM |
| Soaring Safety programs at the SSA Convention | Burt Compton - Marfa | Soaring | 0 | January 21st 06 04:40 AM |
| Soaring Safety Seminar - SSA Convention | Burt Compton | Soaring | 0 | January 26th 04 04:57 PM |
| Soaring Safety Foundation invitation | Burt Compton | Soaring | 0 | January 18th 04 03:51 PM |
