On Mar 4, 1:43 pm, "Bob Gardner" wrote:
Would this specific instruction include full flaps abeam the numbers? With any airplane? I think the "hard on the motor" argument is bogus. Beech doesn't build airplanes with pre-loaded failure modes. Bob Gardner Apparently people with much more Beechcraft experience than I assert that on-off-on is hard on that flap motor. The piano keys certainly aren't designed to facilitate that method, either. Dan |
On Tue, 4 Mar 2008 13:33:14 -0800 (PST), "
wrote: On Mar 4, 1:43 pm, "Bob Gardner" wrote: Would this specific instruction include full flaps abeam the numbers? With any airplane? I think the "hard on the motor" argument is bogus. Beech doesn't build airplanes with pre-loaded failure modes. Bob Gardner Apparently people with much more Beechcraft experience than I assert that on-off-on is hard on that flap motor. The piano keys certainly aren't designed to facilitate that method, either. You get used to it. The switch will probably fail long before the flap motor. Dan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Tue, 4 Mar 2008 10:43:58 -0800, "Bob Gardner"
wrote: Would this specific instruction include full flaps abeam the numbers? With any airplane? I think the "hard on the motor" argument is bogus. Beech doesn't build airplanes with pre-loaded failure modes. Agreed. As I said in another post. 1300 hours, two sets of tires and no problems with the flap motor. Nor have I ever seen any bulletins on flap motor problems. At one time there was an AD about split flaps but it was rescinded as they have more than enough aileron authority to overcome a full split flap situation. (Might be exciting thoughg) Bob Gardner "Robert M. Gary" wrote in message ... On Mar 4, 9:07 am, "Bob Gardner" wrote: I am reluctant to teach anything that should "always" be used. I agree with you in principle but from a practical point student pilots need to start with very, very specific instruction before they have the tools and expand into these types of judgements. If you don't give students specific airspeeds to hit in the pattern they will always have problems with landings. 9 times out of 10 when a student pilot is having trouble landing all I do is sit in the right seat and say "ok, what speed are you suppose to be at here?" and let them do the rest. -Robert Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Bob Gardner wrote:
I am reluctant to teach anything that should "always" be used. Flaps are a tool, and we learn early on in life that there are many ways to use a tool to achieve different results. I agree. I usually use multiple flap extensions at my home airport. Lots of student traffic, so there's really no point in slowing down early and flying a wide pattern behind a bunch of students emulating 747s. On the other hand, when I fly into small strips with tall obstructions, I drop full flaps abeam and fly a slow, tight, steep pattern all the way around. It makes speed control a lot easier in tight places. Different procedures for different conditions. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200803/1 |
On Mar 4, 1:11 pm, "JGalban via AviationKB.com" u32749@uwe wrote:
I agree. I usually use multiple flap extensions at my home airport. Lots of student traffic, so there's really no point in slowing down early and flying a wide pattern behind a bunch of students emulating 747s. On the other hand, when I fly into small strips with tall obstructions, I drop full flaps abeam and fly a slow, tight, steep pattern all the way around. It makes speed control a lot easier in tight places. Different procedures for different conditions. John Galban=====N4BQ (PA28-180) Wait -- why would your second method cause you to "Slow down and fly a wide pattern"? It seems the second method would suit nearly every condition -- big airport, lots of traffic -- get down and get off the runway. Small airport, small runway, get down and stop with room to spare. Dan |
On Mar 5, 1:29 pm, "JGalban via AviationKB.com" u32749@uwe wrote:
wrote: Wait -- why would your second method cause you to "Slow down and fly a wide pattern"? The traffic at the airport necessitates flying a relatively large crowded pattern. There's no real point dropping full flaps and slowing down to approach speed if you're going to be flying a big pattern behind several other aircraft. For me, it works out better to keep the speed up and slow incrementally, depending on what the traffic ahead is doing. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200803/1 In that case, I see the point. "Extend your final" means I'm maintaining my downwind airspeed and altitude until I hear "Follow the Mooney on Final." I'm no longer in a standard pattern, and so the full flaps come later -- probably on final. The question remains -- why not full flaps instead of incremental flaps? Dan |
On Tue, 04 Mar 2008 18:11:59 GMT, "JGalban via AviationKB.com"
u32749@uwe wrote: Bob Gardner wrote: I am reluctant to teach anything that should "always" be used. Flaps are a tool, and we learn early on in life that there are many ways to use a tool to achieve different results. I agree. I usually use multiple flap extensions at my home airport. Lots of student traffic, so there's really no point in slowing down early and flying a wide pattern behind a bunch of students emulating 747s. On the other hand, when I fly into small strips with tall obstructions, I drop full flaps abeam and fly a slow, tight, steep pattern all the way around. It Why? The Bo is a great short field airplane that can slow rapidly. I fly down wind pretty much the same. If it's tight, I dump the gear at the end of the runway. From that point I use the appropriate amount of flaps and size my pattern accordingly.(With full flaps it'll be short and close) If necessary I can go full flaps (40 degrees on those big barn doors is EFFECTIVE) right after gear down as it'll slow so quickly with the gear down the flap speed is no problem. At that point I can simply make a slipping U-turn from pattern altitude on a *close* down wind to the end of the runway and my speed will be down to less than 80 at the round out. With practice I can make it over the so called 50 foot obstacle, at the end of the runway and still make the first turnoff at 800 feet when alone. That PA28-180 can do it in even less distance with those Johnson bar flaps. makes speed control a lot easier in tight places. Different procedures for different conditions. John Galban=====N4BQ (PA28-180) BTW the Deb has the same wing loading as the PA28-180 give or take change (17#/ ft^2. The earlier V35s had even less. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Mar 5, 4:22*am, " wrote:
I just read an interesting argument by Lew Gauge in his E-185 Bonanza book. Some background -- the older Bonanzas (straight 35) have a "Flap" switch. There's no increments unless you stop the motor as the flaps are being dropped. Apparently it's hard on that design to start-stop the motor. Lew said there's no reason to teach incremental flaps in small airplanes -- and that multiple flap applications just add to the workload with no advantage-- apply 10 degrees, trim, apply 10 more, trim, etc. His argument is that if the sequence is always the same -- gear down, trim, flaps down, trim -- the approaches will be consistent and reduce the likelihood of a gear-up landing (since the descent profile with 15" MP and full flaps gear up is very close to 15"+ full flaps + gear down). The more I think about this the more it makes sense, except in the partial flap case (though an argument can be made that there's no reason to ever go partial -- but that's another topic). I'm sure this will be contentious, but isn't that the point? I think in a 172R Vfe for 10 flaps is 110, and 85 for more. So maybe stages make sense, in that case? Cheers |
On Mar 4, 10:27 pm, WingFlaps wrote:
On Mar 5, 4:22 am, " wrote: I just read an interesting argument by Lew Gauge in his E-185 Bonanza book. Some background -- the older Bonanzas (straight 35) have a "Flap" switch. There's no increments unless you stop the motor as the flaps are being dropped. Apparently it's hard on that design to start-stop the motor. Lew said there's no reason to teach incremental flaps in small airplanes -- and that multiple flap applications just add to the workload with no advantage-- apply 10 degrees, trim, apply 10 more, trim, etc. His argument is that if the sequence is always the same -- gear down, trim, flaps down, trim -- the approaches will be consistent and reduce the likelihood of a gear-up landing (since the descent profile with 15" MP and full flaps gear up is very close to 15"+ full flaps + gear down). The more I think about this the more it makes sense, except in the partial flap case (though an argument can be made that there's no reason to ever go partial -- but that's another topic). I'm sure this will be contentious, but isn't that the point? I think in a 172R Vfe for 10 flaps is 110, and 85 for more. So maybe stages make sense, in that case? Cheers Perhaps, but I think it High Vfe can lead to sloppy piloting (so does high Vle). Instead of planning the approach and entering the pattern at the proper airspeed, we depend on the flaps and gear to slow us down. This is hard on the gear and can be downright ruinous in an airplane that is not so forgiving. Dan |
teaching emergency landings...How low do you go... | gatt[_2_] | Piloting | 18 | February 27th 08 09:57 PM |
Aerotow - learning and teaching | [email protected] | Soaring | 11 | September 12th 05 09:53 PM |
Teaching the aerotow | Paul Moggach | Soaring | 5 | September 12th 05 03:31 AM |
Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 10:50 PM |
Teaching airworthiness | Roger Long | Piloting | 28 | October 2nd 03 09:08 PM |
