On Apr 4, 12:27*pm, Ray Andraka wrote:
* Sounds to me like you need to be spending a bit more on aircraft maintenance. You might think so, but the reality is that both electricals were on planes I had just bought (lots of prior neglect), the vacuum failures were both dry pumps failing without warning (I suppose you could argue that they should be replaced prophylactically, but they have an infant mortality rate, and I do have two), and the engine failures were one on a plane I didn't own and two due to fuel contamination. No maintenance related failures ever. Michael |
Wow Ray, bad "snip effort". I definitely didn't write that.
"Ray Andraka" wrote ... On Mar 28, 12:42 pm, "Mike Isaksen" wrote: vacuum failure was in a twin (as was one of the electricals), and was the result of two independent point failures. First the vacuum pump on the left engine quit - but since I was on top, still had one good one on the right engine, and was going home anyway, I elected to continue. Then the right engine quit for unrelated reasons. That put me in a single-engine, partial panel situation. Also, tops were above my single engine service ceiling. And there was icing in the clouds. And there I was, single engine, partial panel, shooting an ILS while ice was building. Sounds to me like you need to be spending a bit more on aircraft maintenance. |
On Mar 28, 7:53*am, wrote:
*The point of Standy by Vac & electrical *is very valid! * I have investigated many IFR accidents *with no indication as to WHY! *No radio calls no nothing! I have a friend in the CHP that investigates car accidents. Often times there is an accident where there is no sign of malfunction of the car, skidding, etc. The one common element of all these accidents is that they involve cars. The best bet to ensure your safety would therefor be to avoid riding in a car. -Robert |
FAA Inspector overstepping his authority (I think) | Screwed | Owning | 7 | May 2nd 05 03:52 PM |
Aviation safety magazines | Dr Doug | General Aviation | 2 | March 3rd 05 01:56 AM |
Aviation Safety Counselor's??? | NW_PILOT | Owning | 20 | March 2nd 05 04:15 AM |
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Barnyard BOb - | Home Built | 5 | September 8th 04 07:27 PM |
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Cub Driver | Piloting | 0 | September 8th 04 10:35 AM |
