#31
New fuel for GA?
Alan wrote:
In article Bertie the Bunyip writes: Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? If it really is a substitute for 100LL, then that would be exactly what one would do. A pretty big 'if', though. If he can really make the stuff, why is he talking instead of mixing? If you can put avgas out at 1/2 the price as he seemed to be claiming, he could get a lot of attention with a pump pumping for $2.499 / gallon. Of course, if he makes the stuff without lead, then I don't see why it wouldn't work in most cars as well. At $2.499 / gallon, he could sell all he could make. *IF* he can do it. Based on the claims, the only unknown for auto use would be the oxygenate requirement, i.e. would alcohol have to be added and would it be compatible. As for sales, if he could really make the stuff significantly cheaper, why isn't he doing it now? The US isn't the only market for fuel in the world. -- Jim Pennino Remove .spam.sux to reply. |
#32
New fuel for GA?
Bertie the Bunyip wrote: Orval Fairbairn wrote in news In article , Bertie the Bunyip wrote: Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? Timing? probably, if the octane rating is there. Mixture? You would probably have to adjust mixture accordingly. The different fuel density would probably require adjustments to float levels. Other hardware changes? I would have to see the materials compatibility tests before I started using it. It has been known since the 1950s that the synthetic rubber used in hoses, etc. can tolerate either petroleum-based or parrafin-based fuels. The problems arise when switching (either way) between the two, since each type fuel has its own effect on the polymers. Well, my luscombe had virtually nothing in the fuel system vunerable to anything this side of Skydrol, but only because I installed a metal float and an automotive fuel line. The float seat is metal of course and there's nothing else in the system that anythign can melt. My KCAB is anouther thing altogether. The LeBlond I'm going to have to check, but I think it has a standard MS carb form the thirties anyway, so it should be fine. What about the flexible hose from the gascolator to the carburetor? I would not use a hard metal line because of engine vibration and flexing. It is the synthetic materials use in hoses that is mentioned in my reference. If you can find one (I found mine by accident) a good reference is: "Aviation Fuels and Their Effects on Engine Performance," NAVAIR-06-5-501 USAF T.O. No. 06-5-4, prepared by Ethyl Corp supplied to U.S. Air Forces on Purchase Order AF-33(600)5312 Dept of the Navy BuAer on contract No. 52-2002 Copyright 1951 by Ethyl Corp. It is a comprehensive guide to aviation fuels and potential aviation fuels and lists energy output, vapor pressure, octane rating, density and numerous other pertinent qualities of those fuels. It makes specific note of the potential materials compatibility problems when switching between fuel bases. -- Remove _'s from email address to talk to me. |
#33
New fuel for GA?
news In article , Bertie the Bunyip wrote: Orval Fairbairn wrote in news_r_fairbairn-D13E8E.10215613052008@70-3-168- 216.area5.spcsdns.ne t: In article , Bertie the Bunyip wrote: Tell me this, what do you make of his claim that you can pour this stuff straight into an airplane set up for Avgas? No timing or mixture changes, no hardware changes? Timing? probably, if the octane rating is there. Mixture? You would probably have to adjust mixture accordingly. The different fuel density would probably require adjustments to float levels. Other hardware changes? I would have to see the materials compatibility tests before I started using it. It has been known since the 1950s that the synthetic rubber used in hoses, etc. can tolerate either petroleum-based or parrafin-based fuels. The problems arise when switching (either way) between the two, since each type fuel has its own effect on the polymers. Well, my luscombe had virtually nothing in the fuel system vunerable to anything this side of Skydrol, but only because I installed a metal float and an automotive fuel line. The float seat is metal of course and there's nothing else in the system that anythign can melt. My KCAB is anouther thing altogether. The LeBlond I'm going to have to check, but I think it has a standard MS carb form the thirties anyway, so it should be fine. What about the flexible hose from the gascolator to the carburetor? I would not use a hard metal line because of engine vibration and flexing. We made one up from an automotive line that was resistant to every fuel we intended to put in, including ethanol. I couldn't tell you which it was now cause the airplane is gone. I'll ask the guy who made it up for me what it was, though. It is the synthetic materials use in hoses that is mentioned in my reference. Yeah, I figured, but there's all sorts of other rubbers and platics in a modern system as well. If you can find one (I found mine by accident) a good reference is: "Aviation Fuels and Their Effects on Engine Performance," NAVAIR-06-5-501 USAF T.O. No. 06-5-4, prepared by Ethyl Corp supplied to U.S. Air Forces on Purchase Order AF-33(600)5312 Dept of the Navy BuAer on contract No. 52-2002 Copyright 1951 by Ethyl Corp. It is a comprehensive guide to aviation fuels and potential aviation fuels and lists energy output, vapor pressure, octane rating, density and numerous other pertinent qualities of those fuels. It makes specific note of the potential materials compatibility problems when switching between fuel bases. Good stuff! Bertie |
#34
New fuel for GA?
"Bertie the Bunyip" wrote in message .. . We made one up from an automotive line that was resistant to every fuel we intended to put in, including ethanol. I couldn't tell you which it was now cause the airplane is gone. I'll ask the guy who made it up for me what it was, though. It is the synthetic materials use in hoses that is mentioned in my reference. Yeah, I figured, but there's all sorts of other rubbers and platics in a modern system as well. Here we go again. Another "dog ate the homework" story. You lying piece of ****. You don't even fly. Funny when some one catches your ass lying. |
#35
New fuel for GA?
"Maxwell" luv2^fly99@cox.^net wrote in news:58oWj.1156$xF6.574
@newsfe20.lga: "Bertie the Bunyip" wrote in message .. . We made one up from an automotive line that was resistant to every fuel we intended to put in, including ethanol. I couldn't tell you which it was now cause the airplane is gone. I'll ask the guy who made it up for me what it was, though. It is the synthetic materials use in hoses that is mentioned in my reference. Yeah, I figured, but there's all sorts of other rubbers and platics in a modern system as well. Here we go again. Another "dog ate the homework" story. You lying piece of ****. You don't even fly. Funny when some one catches your ass lying. Yeh, right. That'll come to a bit of a surprise to the 757 I just left standing on the ramp. Bertie |
Similar Threads | ||||
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
