Mapping Glider Locations
As a member ham and member of the local Search and Rescue organization, we
have been interested in tracking fellow searchers. The technology has been available for some time, but was not straightforward. That may be changing, and the change may be very useful for soaring pilots who wish to follow pilot tracks and locations and also for following the nearness of other glider pilots. APRS (automatic position reporting system) was developed by a ham and is now used by police and other groups for tracking. The problem has been taking the data and doing something useful with it. For a number of years, you could transmit a position report and have it show up as a position and track on the internet. That alone is useful to glider pilots, but it requires access by the receiving station to the internet. To implement this setup, all that is necessary is an old 2 meter handy talkie (about $50 or less used), a TNC (less than $50 new) and a GPS. The GPS can be any retired unit with simply a serial data output. So, for $150, you can place your location on the internet. Note that you do not need to be a ham to use this in your glider. It needs to be "operated" by a ham, which means the ham would install it and set up the software. The software controls the transmitter, so if the ham sets up the software, he is controlling the transmitter, even if not present. So far, this is fairly useful, although it does not allow the pilot to see other pilots with APRS installations. Now, however, there is a big improvement. See http://www.argentdata.com/products/tracker2.html . I am about to order the Open Tracker OT2m to try out. I think what the advertisement says is that with a 2 meter radio (the same $50 used one), the OT2m (under $100) and a mapping GPS that allows uploading waypoints, you could receive location reports from nearby soaring pilots and have them appear on your GPS - with an identifier. If you are not a ham or know a ham, you can now obtain a license without knowing the morse code. That requirement has been eliminated. The exam, in the simplest form, involves memorizing a pool of multiple choice questions and receiving passing grades. A book with the most current question pool is available. I have not tried out the OT2m but am planning on ordering one and thought I would post this to let others think about it. Colin Lamb |
"COLIN LAMB" wrote in message ... ....Snip... Note that you do not need to be a ham to use this in your glider. It needs to be "operated" by a ham, which means the ham would install it and set up the software. The software controls the transmitter, so if the ham sets up the software, he is controlling the transmitter, even if not present. Colin, That appears to me to really be stretching the rules. Does the glider pilot ever turn off the system? Isn't the glider pilot operating the system when he turns it back on? This my be in compliance with the "letter of the law"; however, it seems beyond the rule's intent. Has the FCC officially ruled on this; or, are you not asking the question for which you can't stand the answer. Respectfully, Wayne W7ADK http://www.soaridaho.com/ |
Hello Wayne:
To be honest, I have not reseached the answer about control - however APRS is used frequently in vehicles and animals that are not occupied by amateurs. They are installed in balloons, used on search dogs. I am a ham (K7FM) and have had an APRS unit installed in my car. It shuts down when the ignition is turned off and I have the software quit sending out reports if there is no change in position. I am sure I could write software that would cause the transmitter to quit transmitting a position report when the power was turned off. So, the answer is I do not know the fine line about control, and the main point of the post was to let soaring pilots (many who are hams or know hams) of available technology. If it useful, they might just want to get a ham ticket. My wife has no interest in radio at all but studied the question pool over a weekend and became N7WXY. Colin Lamb |
A bit of research says that it is not necessary to "babysit" an APRS
installation. See http://info.aprs.net/index.php?title=ControlOperator Colin Lamb |
"COLIN LAMB" wrote in message ... Hello Wayne: To be honest, I have not reseached the answer about control - however APRS is used frequently in vehicles and animals that are not occupied by amateurs. They are installed in balloons, used on search dogs. I am a ham (K7FM) and have had an APRS unit installed in my car. It shuts down when the ignition is turned off and I have the software quit sending out reports if there is no change in position. I am sure I could write software that would cause the transmitter to quit transmitting a position report when the power was turned off. So, the answer is I do not know the fine line about control, and the main point of the post was to let soaring pilots (many who are hams or know hams) of available technology. If it useful, they might just want to get a ham ticket. My wife has no interest in radio at all but studied the question pool over a weekend and became N7WXY. Colin Lamb Colin, No matter what the technical FCC rules answer, I have a nice little Garmin stand alone unit, and an old 2 meter hand held unit. It is time for me to spend a few buck and get out my soldering iron. Wayne HP-14 "Six Foxtrot" http://www.soaridaho.com/Schreder |
COLIN LAMB wrote:
APRS (automatic position reporting system) was developed by a ham and is now used by police and other groups for tracking. The problem has been taking the data and doing something useful with it. For a number of years, you could transmit a position report and have it show up as a position and track on the internet. That alone is useful to glider pilots, but it requires access by the receiving station to the internet. To implement this setup, all that is necessary is an old 2 meter handy talkie (about $50 or less used), a TNC (less than $50 new) and a GPS. The GPS can be any retired unit with simply a serial data output. So, for $150, you can place your location on the internet. Note that you do not need to be a ham to use this in your glider. It needs to be "operated" by a ham, which means the ham would install it and set up the software. The software controls the transmitter, so if the ham sets up the software, he is controlling the transmitter, even if not present. I don't agree with this at all. If you are using a 2M ham transmitter without a ham license, you are violating FCC rules. The software you claim to have controlling the transmitter does not eliminate the need for a "control operator" for the 2M transmitter to be licensed. If you are not a ham or know a ham, you can now obtain a license without knowing the morse code. That requirement has been eliminated. The exam, in the simplest form, involves memorizing a pool of multiple choice questions and receiving passing grades. A book with the most current question pool is available. This part is true. I have not tried out the OT2m but am planning on ordering one and thought I would post this to let others think about it. I assume you have memorized the questions for your ham license before you put a 2M transmitter on the air or you may get a written invitation from the FCC to explain your actions. Colin Lamb |
"I don't agree with this at all. If you are using a 2M ham transmitter
without a ham license, you are violating FCC rules. The software you claim to have controlling the transmitter does not eliminate the need for a "control operator" for the 2M transmitter to be licensed." Response: See http://info.aprs.net/index.php?title=ControlOperator "I assume you have memorized the questions for your ham license before you put a 2M transmitter on the air or you may get a written invitation from the FCC to explain your actions." Response: I did not memorize any questions for the ham exam, since there was no question pool when I went down to the FCC office and passed the extra class exam. I had to learn the stuff. Colin Lamb K7FM (licensed in 1959) |
COLIN LAMB wrote:
As a member ham and member of the local Search and Rescue organization, we have been interested in tracking fellow searchers. The technology has been available for some time, but was not straightforward. That may be changing, and the change may be very useful for soaring pilots who wish to follow pilot tracks and locations and also for following the nearness of other glider pilots. APRS (automatic position reporting system) was developed by a ham and is now used by police and other groups for tracking. The problem has been taking the data and doing something useful with it. For a number of years, you could transmit a position report and have it show up as a position and track on the internet. That alone is useful to glider pilots, but it requires access by the receiving station to the internet. To implement this setup, all that is necessary is an old 2 meter handy talkie (about $50 or less used), a TNC (less than $50 new) and a GPS. The GPS can be any retired unit with simply a serial data output. So, for $150, you can place your location on the internet. Note that you do not need to be a ham to use this in your glider. It needs to be "operated" by a ham, which means the ham would install it and set up the software. The software controls the transmitter, so if the ham sets up the software, he is controlling the transmitter, even if not present. So far, this is fairly useful, although it does not allow the pilot to see other pilots with APRS installations. Now, however, there is a big improvement. See http://www.argentdata.com/products/tracker2.html . I am about to order the Open Tracker OT2m to try out. I think what the advertisement says is that with a 2 meter radio (the same $50 used one), the OT2m (under $100) and a mapping GPS that allows uploading waypoints, you could receive location reports from nearby soaring pilots and have them appear on your GPS - with an identifier. If you are not a ham or know a ham, you can now obtain a license without knowing the morse code. That requirement has been eliminated. The exam, in the simplest form, involves memorizing a pool of multiple choice questions and receiving passing grades. A book with the most current question pool is available. I have not tried out the OT2m but am planning on ordering one and thought I would post this to let others think about it. Colin Lamb Furthering on my previous reply, I quote FCC rules (Part 97) and hightlighted text with capitalization for emphasis: §97.5 Station license grant required. (a) The station apparatus MUST BE UNDER THE PHYSICAL CONTROL of a person named in an amateur station license grant on the ULS consolidated license database or a person authorized for alien reciprocal operation by §97.107 of this part, before the station may transmit on any amateur service frequency from any place that is: (1) Within 50 km of the Earth's surface and at a place where the amateur service is regulated by the FCC; (2) Within 50 km of the Earth's surface and aboard any vessel or craft that is documented or registered in the United States; or (3) More than 50 km above the Earth's surface aboard any craft that is documented or registered in the United States. §97.7 Control operation required. When transmitting, each amateur station must have a control operator. THE CONTROL OPERATOR MUST BE a PERSON: (a) For whom an amateur operator/primary station license grant appears on the ULS consolidated licensee database, or (b) Who is authorized for alien reciprocal operation by §97.107 of this part. And...I forgot to put my amateur radio callsign in my last post. Scott N0EDV |
COLIN LAMB wrote:
Hello Wayne: To be honest, I have not reseached the answer about control - however APRS is used frequently in vehicles and animals that are not occupied by amateurs. But, are they using transmitters on HAM frequencies? I hope not unless they are licensed to do so. See my other post quoting FCC rules about "Control Points" and "Control Operators". I am sure I could write software that would cause the transmitter to quit transmitting a position report when the power was turned off. I doubt you'd have to. If the transmitter power is turned off, no position reports could be sent out. So, the answer is I do not know the fine line about control, and the main point of the post was to let soaring pilots (many who are hams or know hams) of available technology. If it useful, they might just want to get a ham ticket. My wife has no interest in radio at all but studied the question pool over a weekend and became N7WXY. If you are unsure of control point regulations, you might want to peruse over the Part 97 rules. They can be found at http://www.arrl.org/FandES/field/reg...7/onepage.html It seems to me to be a disservice to tell folks about something and imply it's OK to violate FCC rules. They won't be very happy to get a letter from the Feds. Congrats to you wife on her new license! Maybe she will get hooked on radio if/when she starts using her privileges Scott N0EDV |
Similar Threads | ||||
2009 U.S. Contest Locations/Dates | Tim[_2_] | Soaring | 2 | February 28th 08 06:48 PM |
ICAO Locations | [email protected] | Piloting | 1 | July 2nd 06 04:06 PM |
buno or c/n number locations... | Gene | Naval Aviation | 0 | March 31st 04 05:36 AM |
DC-3 Locations | RobbelothE | Military Aviation | 11 | March 30th 04 03:36 AM |
cabin noise locations & dogs | [email protected] | Owning | 9 | August 30th 03 09:26 PM |
