negative dihedral
Old June 5th 08, 05:49 PM posted to rec.aviation.piloting
Maxwell[_2_]
Default negative dihedral
"Maxwell" luv2^fly99@cox.^net wrote in
That's not compulsion, fjukkktard.
Bertie
Sure it is Squirty the ****drip, you just can't stop.
Old June 6th 08, 02:38 AM posted to rec.aviation.piloting
Daryl Hunt[_3_]
People, if you are going to answer any of the AUKk00ks, remove any mention
of any NG with the word "kook" in it. The AUKk00ks are actually harmless if
left to themselves.
"Robert M. Gary" wrote in
news:fe88d496-d08f-4a7f-8a0a-
On Jun 3, 3:13 pm, Tina wrote:
I understand how positive dihedral helps dynamic stability in
airplanes, but some big ones, like the Russian An 124 Condor, has a
pronounced negative dihedral -- the wings have a noticeable
downward slope.
Q1: Do those airplanes need active fly by wire controls to maintain
stability, or is something else at play that keeps them right side
up?
Q2: Does anyone have a design rationalization for such a
configuration, as opposed to just zero dihedral? I can appreciate
why fighters have it -- they exploit lack of aerodynamic stability
for rapid maneuvers -- but transports that spend their whole life
being straight and level are another issue.
Negative dihedral provides a place to hang bombs ala the USNavy's
A-7 Corsair II.
Uh. OK
Bertie
Relevance?
More compulsive behavior.
You reply even when you have no relevant answer.
Bertie
** Posted from
http://www.teranews.com **
Old June 6th 08, 05:47 PM posted to rec.aviation.piloting
Robert M. Gary
On Jun 5, 7:53*am, Bertie the Bunyip wrote:
"Robert M. Gary" wrote in news:fe88d496-d08f-4a7f-8a0a-
Negative dihedral provides a place to hang bombs ala the USNavy's A-7
Corsair II.
Uh. OK
Well just think how embarrased you would be if you had the bombs on
the top of the wing.
-Robert
Old June 6th 08, 06:54 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
A-7 Corsair II.
Uh. OK
You have me there.
Bertie
Old June 6th 08, 11:53 PM posted to rec.aviation.piloting
Tina
With all of the expert* pilots here, why would bombs on the top of the
wings be a problem? Go inverted, much better visibility toward the
ground then, right? Then release, they'll fall away.
*Expert: you have to take the word into its component parts: Ex is a
has been, and a spurt is a drip under pressure.
Corsair II.
Uh. OK
-Robert
Old June 7th 08, 12:14 AM posted to rec.aviation.piloting
Blueskies
"Tina" wrote in message ...
Which way is up?
http://www.fas.org/man/dod-101/sys/a...-solo_1024.jpg
Old June 6th 08, 11:31 PM posted to rec.aviation.piloting
John Godwin
A-7 Corsair II.
Hmmm. Our plane has positive dihedral and 2 hard points on each wing.
Another old negative Don Pyeatt Aviation Photos 0 March 2nd 08 05:32 PM
"predator' dihedral Phil Rhodes Naval Aviation 5 May 25th 07 09:54 PM
Wing dihedral Dallas Piloting 35 March 20th 06 04:01 PM
how to cope with negative g´s? Markus Aerobatics 6 July 2nd 05 12:00 AM
Biplane wing dihedral vincent p. norris General Aviation 20 June 18th 05 02:58 AM
