I towed out and gridded. On the grid I still felt there was something
wrong, but couldn't put my finger on what was wrong. I asked another experienced pilot to do a control check before I launched. We found nothing wrong. In between this last paragraph and the text below, did you go through a pre-flight checklist, that had a C for "CONTROLS, CLEAR AND FREE- FULL MOVEMENT? Or did the problem not manifest itself until full flight? As soon as the tow commenced I could see what the problem was. I only had approx half stick movement. Umm, pop the cord? Did you not also have an E somewhere on your preflight checklist, for EMERGENCY, which in theory should have left you with clear options for aborting a takeoff at different phases? I realize that the layout of the airport this happened at may not have good emergency options and also that it may not have occurred until already past the "point of no return" so these points may be moot and your actions taken executed flawlessly (after all, you are here to tell about it...), so I don't mean to harp. I'm just curious if this particular frightening occurrence could have been avoided altogether or at least handled at MUCH lower energies if a thorough preflight checklist was actually performed. Thanks for sharing. Paul Hanson |
Guys you are missing the point! There is a difference between a
Critical Assembly Check and a Positive Control Check. A PCC would NOT have helped Clem. With the elevator connecting bolt taped over, the glider would have most likely passed the PCC! I am all in favor of doing the Critical Assembly Check. I always do mine twice, first after rigging, second before launch. Of all of the accidents described, most would have been avoided by doing a proper CAC, not PCC! On Jun 4, 8:56*am, Andreas Maurer wrote: On Tue, 3 Jun 2008 19:43:51 -0700 (PDT), wrote: Please name one accident of a glider with auto hookups that could have been prevented by a positive control check. I sure don't know any. A seized bearing will be detected by simply moving the stick. In all gliders I know there is no scenario of control failure that would necessitate a positive control check for detection. There have been SEVERAL incidents and accidents of DG gliders where the automatic hookup of the elevator was not connected correctly. Not to mention several (unfortunately usually fatal) crashes of gliders where the auto hookups were connected correctly, but the horizontal tail was not. Ernst-Gernot Peter and Clem Bowman come to my mind... You are making a slippery slope argument. Should we mandate annual stress tests of wings in the name of safety? Overhaul all tost releases every 100 cycles? Nope... but to do a simple 2 minute check before the flight... Bye Andreas |
On Jun 3, 7:43*pm, wrote:
Please name one accident of a glider with auto hookups that could have been prevented by a positive control check. I sure don't know any. Clem Bowman, Genesis 2, Minden Nationals.................pilot didn't fully seat the locking mechanism on the elevator because he had given the little red tool to his wife so she could put water in the wings..........................didn't do a critical assembly check..................elevator fell off during take- off.........................Clem is no longer with us! JJ |
Please name one accident of a glider with auto hookups that could have been prevented by a positive control check. Russia elevator. Air Sailing contest. Pilot Chad Moore. Broken elevator pintle discovered. Accident averted. Thanks, Bob K. |
On Jun 4, 8:48*am, Bob Kuykendall wrote:
On Jun 3, 7:43*pm, wrote: Please name one accident of a glider with auto hookups that could have been prevented by a positive control check. Russia elevator. Air Sailing contest. Pilot Chad Moore. Broken elevator pintle discovered. Accident averted. Thanks, Bob K. Russia pilot, at North Plains Oregon discovered broken rudder connection (I can't remember if it was a control horn problem or cables) while doing a PCC. He was glad he did! |
On 4 Jun, 03:26, "noel.wade" wrote:
On Jun 3, 7:18*pm, wrote: For ships with *auto hookups* positive control checks are a waste of time, and in fact do more harm then good. I have never heard of a I cannot believe this was posted. *Its YOUR airplane. *YOU are the Pilot in Command. *YOU have the responsibility to ensure that the checks are done properly and by someone who can do it without damage to the aircraft. It sounds to me as if that's what he's doing: taking responsibility for the checks which are done. It's just that he doesn't believe some checks need doing, or doing in a particular way. After all, he's going to be the one in trouble if he's wrong. But it would be interesting to hear of a real case where a glider with automatic connections has had a problem discovered during the positive control check. Anyone? Ian PS I do 'em myself. But then, my glider doesn't have automatic connections. I think I'd still do them then, though. |
Ian wrote:
After all, he's going to be the one in trouble if he's wrong. But it would be interesting to hear of a real case where a glider with automatic connections has had a problem discovered during the positive control check. Anyone? Just about any DG (already mentioned): possible to get horizontal stab on and secured with elevator pushrod outside of receptacle, resulting in reduced range of elevator movement and binding. Only managed to do this once. Duo Discus: possible to get horizontal stab on and secured with elevator drive pins jammed in-between torque tube and upper elevator skin, rather than in the receiving wholes on the torque tube, resulting in reduced range of movement and funny stick feel. LAK-17A: Possible to get wings and secured on with one control (I think it was aileron) disconnected, resulting funny stick feel and no surface movement. Never figured out how I managed to do that, and it never happened again. Ventus B: Possible to get wing on and secured with one control pushrod end (aileron again?) outside of socket and jammed into fuselage opening, resulting in no surface movement and binding. This area was apparently changed at least once during the production run. Marc |
Some more positive GA News | Jay Honeck[_2_] | Piloting | 22 | February 4th 08 01:46 AM |
USA Today .. Positive GA Pub | Jay Beckman | Piloting | 65 | February 14th 07 10:36 PM |
Positive, All-Comers Welcome. | Jim Culp | Soaring | 4 | January 2nd 05 06:18 AM |
some positive press for GA | Dave Butler | Piloting | 1 | January 28th 04 03:07 PM |
