On Jun 22, 9:20 am, Scott wrote:
Richard Riley wrote: On Jun 16, 7:37 pm, Larry Dighera wrote: How Beat The High Cost Of Fuel The motor is powered by a 78 pound, custom-built lithium-ion polymer battery with a power output of "5.6 kilowatt hours"; projected life is 300 to 500 full discharge cycles or more than 1,000 partial cycles. The battery can be recharged in as little as two hours using a 220-volt charger (or six hours with a 110-volt charger). The cost for a full recharge is 70 cents with the 110-volt charger. Fishman says it's feasible to carry a small 110-volt charger as baggage on cross-country flights. 1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower hours. Good enough for a short burst to get you to altitude and soar the thermals, bu you aren't going anywhere cross country. Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr. Your battery is equal to .75 gallons of gas. Wait a second...5.6 KWH doesn't really tell you how much HP it is, does it? All it says is that it consumes 5.6KW in an hour. If you only ran the motor for 5 minutes per hours, the HP would be 12 times that or approx. 90 HP. Using KW HOURS doesn't tell the whole story. Running a 100W light bulb 10 hours uses 1 KWH and so does running a 500W bulb for 2 hours but the 500W bulb does more work at any instant in time (it's a lot brighter!). Now, if that motor was rated at 5.6KW, then yes, I'd agree it is about 7.5 HP. Scott True, KWH is a measure of energy, whereas HP (and KW) is a measure of power. Of course, this makes me wonder why the OP said the battery has a "power output" of 5.6KWH; that statement doesn't make any sense. Granted, he was obviously talking about the capacity of the battery, not the power output, but if somebody is making an electric plane one would hope they would know their terminology ![]() |
Scott wrote:
Richard Riley wrote: On Jun 16, 7:37 pm, Larry Dighera wrote: How Beat The High Cost Of Fuel The motor is powered by a 78 pound, custom-built lithium-ion polymer battery with a power output of "5.6 kilowatt hours"; projected life is 300 to 500 full discharge cycles or more than 1,000 partial cycles. The battery can be recharged in as little as two hours using a 220-volt charger (or six hours with a 110-volt charger). The cost for a full recharge is 70 cents with the 110-volt charger. Fishman says it's feasible to carry a small 110-volt charger as baggage on cross-country flights. 1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower hours. Good enough for a short burst to get you to altitude and soar the thermals, bu you aren't going anywhere cross country. Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr. Your battery is equal to .75 gallons of gas. Wait a second...5.6 KWH doesn't really tell you how much HP it is, does it? All it says is that it consumes 5.6KW in an hour. If you only ran the motor for 5 minutes per hours, the HP would be 12 times that or approx. 90 HP. Using KW HOURS doesn't tell the whole story. Running a 100W light bulb 10 hours uses 1 KWH and so does running a 500W bulb for 2 hours but the 500W bulb does more work at any instant in time (it's a lot brighter!). Now, if that motor was rated at 5.6KW, then yes, I'd agree it is about 7.5 HP. Scott The OP stated the motor was 18 H.P. "This year Fishman hopes to fly his new ElectraFlyer-C (a re-engined Moni motorglider with an 18-horsepower electric motor)..." |
![]() "Scott" wrote in message ... Richard Riley wrote: On Jun 16, 7:37 pm, Larry Dighera wrote: How Beat The High Cost Of Fuel The motor is powered by a 78 pound, custom-built lithium-ion polymer battery with a power output of "5.6 kilowatt hours"; projected life is 300 to 500 full discharge cycles or more than 1,000 partial cycles. The battery can be recharged in as little as two hours using a 220-volt charger (or six hours with a 110-volt charger). The cost for a full recharge is 70 cents with the 110-volt charger. Fishman says it's feasible to carry a small 110-volt charger as baggage on cross-country flights. 1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower hours. Good enough for a short burst to get you to altitude and soar the thermals, bu you aren't going anywhere cross country. Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr. Your battery is equal to .75 gallons of gas. Wait a second...5.6 KWH doesn't really tell you how much HP it is, does it? All it says is that it consumes 5.6KW in an hour. If you only ran the motor for 5 minutes per hours, the HP would be 12 times that or approx. 90 HP. Using KW HOURS doesn't tell the whole story. Running a 100W light bulb 10 hours uses 1 KWH and so does running a 500W bulb for 2 hours but the 500W bulb does more work at any instant in time (it's a lot brighter!). Now, if that motor was rated at 5.6KW, then yes, I'd agree it is about 7.5 HP. Scott You have a good point, but the KW Hours rating of the battery does seem a bit low. Even when you consider that cooling drag nearly absent, what little I think I know about the base airframe suggests that the battery rating needs to be at least twice the stated amount in order to provide the stated performance and endurance. The usual power of ten error in transcription does not make much sense in this case, but there are apparently two batteries of equal sive--and everything that I could find appeared to originate from a single article. In any case, it is interesting; but the economics really do not work based upon the stated maximum10 year and 1000 hour battery battery life. Even if the electricity was free and gasolene was more than twice its current cost, the gasolene powered airplane, on which it is bsed, would still give much greated utility for less cost. Nontheless, my hat's off to him for the effort. Peter |
On Jun 21, 11:42 pm, Richard Riley wrote:
On Jun 16, 7:37 pm, Larry Dighera wrote: How Beat The High Cost Of Fuel The motor is powered by a 78 pound, custom-built lithium-ion polymer battery with a power output of "5.6 kilowatt hours"; projected life is 300 to 500 full discharge cycles or more than 1,000 partial cycles. The battery can be recharged in as little as two hours using a 220-volt charger (or six hours with a 110-volt charger). The cost for a full recharge is 70 cents with the 110-volt charger. Fishman says it's feasible to carry a small 110-volt charger as baggage on cross-country flights. 1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower hours. Good enough for a short burst to get you to altitude and soar the thermals, bu you aren't going anywhere cross country. Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr. Your battery is equal to .75 gallons of gas. The technology is immature, but this is on the right track. When a suitable battery is invented, there is no arguing that it will easily replace small gasoline engines. And battery development is just getting started, so things can only get better. We have not invested in batteries other than for portable electronics. I am sure many in 1903 argued that a horse drawn carriage could go much farther and safer than the Wright flyer. |
In rec.aviation.piloting Andrew Sarangan wrote:
On Jun 21, 11:42 pm, Richard Riley wrote: On Jun 16, 7:37 pm, Larry Dighera wrote: How Beat The High Cost Of Fuel The motor is powered by a 78 pound, custom-built lithium-ion polymer battery with a power output of "5.6 kilowatt hours"; projected life is 300 to 500 full discharge cycles or more than 1,000 partial cycles. The battery can be recharged in as little as two hours using a 220-volt charger (or six hours with a 110-volt charger). The cost for a full recharge is 70 cents with the 110-volt charger. Fishman says it's feasible to carry a small 110-volt charger as baggage on cross-country flights. 1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower hours. Good enough for a short burst to get you to altitude and soar the thermals, bu you aren't going anywhere cross country. Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr. Your battery is equal to .75 gallons of gas. The technology is immature, but this is on the right track. When a suitable battery is invented, there is no arguing that it will easily replace small gasoline engines. And when fustion reactors are invented they will replace coal and fission plants. And when anti-gravity is invented, it will replace airplanes. And when... And battery development is just getting started, so things can only get better. Batteries have been under development for well over a hundred years. We have not invested in batteries other than for portable electronics. What do you think powered ALL the world's submerged submarines before the Nautilus was launched in 1954? What do you think powers the stuff in torpedoes and missiles and has for about a half century, an extension cord? Have you any idea what has powered telephone offices for over a century? Do you know what a UPS is and have you ever seen one the size of a small house? I am sure many in 1903 argued that a horse drawn carriage could go much farther and safer than the Wright flyer. In 1903 both the airplane and the car were new; it is now 105 years later. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Scott wrote:
wrote: I think his point was that the "standard" lead acid battery has been around in its basic form and pretty much unchanged for many years. If that is, in fact, what he means, I agree. Newer technologies have really only appeared in the last 20-30 years, ie NiCd, NiMh, Lithium Ion, etc. If we had been working to make "better" batteries as we have with planes, trains and automobiles, we'd have some pretty sweet electric power now...just my opinion. Lead acid batteries have changed a lot since they were invented. Other types of batteries have been around for way more than 30 years. The nickel-cadmium battery was invented in 1899 the Nike-Ajax missle had them in the 1950's. -- Jim Pennino Remove .spam.sux to reply. |
On Jun 24, 6:59 am, Scott wrote:
wrote: In rec.aviation.piloting Andrew Sarangan wrote: On Jun 21, 11:42 pm, Richard Riley wrote: On Jun 16, 7:37 pm, Larry Dighera wrote: How Beat The High Cost Of Fuel The motor is powered by a 78 pound, custom-built lithium-ion polymer battery with a power output of "5.6 kilowatt hours"; projected life is 300 to 500 full discharge cycles or more than 1,000 partial cycles. The battery can be recharged in as little as two hours using a 220-volt charger (or six hours with a 110-volt charger). The cost for a full recharge is 70 cents with the 110-volt charger. Fishman says it's feasible to carry a small 110-volt charger as baggage on cross-country flights. 1 horsepower = .75kw. So 5.6 kilowatt hours is only 7.51 horsepower hours. Good enough for a short burst to get you to altitude and soar the thermals, bu you aren't going anywhere cross country. Compare it to a really inefficient 2 stroke, burning .6 lb/hp-hr. Your battery is equal to .75 gallons of gas. The technology is immature, but this is on the right track. When a suitable battery is invented, there is no arguing that it will easily replace small gasoline engines. And when fustion reactors are invented they will replace coal and fission plants. And when anti-gravity is invented, it will replace airplanes. And when... And battery development is just getting started, so things can only get better. Batteries have been under development for well over a hundred years. We have not invested in batteries other than for portable electronics. What do you think powered ALL the world's submerged submarines before the Nautilus was launched in 1954? What do you think powers the stuff in torpedoes and missiles and has for about a half century, an extension cord? Have you any idea what has powered telephone offices for over a century? Do you know what a UPS is and have you ever seen one the size of a small house? I am sure many in 1903 argued that a horse drawn carriage could go much farther and safer than the Wright flyer. In 1903 both the airplane and the car were new; it is now 105 years later. I think his point was that the "standard" lead acid battery has been around in its basic form and pretty much unchanged for many years. If that is, in fact, what he means, I agree. Newer technologies have really only appeared in the last 20-30 years, ie NiCd, NiMh, Lithium Ion, etc. If we had been working to make "better" batteries as we have with planes, trains and automobiles, we'd have some pretty sweet electric power now...just my opinion. Scott You can add fuel cells to that list too, as a recent development. But I am sure one could claim that fuel cells are in the Smithsonian museum as a century-old technology. My opinion is that the current oil prices is not a crisis, but a necessary condition to refocus our technology. No one took electric powered automobiles seriously when oil was less than $60. Any transformative technology is not going to happen in a couple of years. I think 2050 is still very optimistic for fusion power, but that is still worth investing in. We can't always be thinking of ourselves and screw the rest after we die. We owe it to our children. |
On Jun 23, 11:05 pm, wrote:
And when fustion reactors are invented they will replace coal and fission plants. You mean fusion? Take a look at ITER: International Thermonuclear Experimental Reactor. It is far from reality, but it is not science fiction either. You can think what you want, but investment in batteries and fuel cells have seen a huge growth in the last few years. If batteries have been intensely developed for over a century and is very mature, all these investors and their expectations must be pretty foolish. |
Fighting the high cost of flying | Jay Honeck[_2_] | Piloting | 31 | June 11th 08 11:30 AM |
High Cost of Sportplanes | Gordon Arnaut | Home Built | 110 | November 18th 05 10:02 AM |
Fix the high cost [Was:] High Cost of Sportplanes | Evan Carew | Home Built | 40 | October 8th 05 04:05 AM |
These are not YOUR airplanes - Was: High Cost of Sportplanes | Lakeview Bill | Home Built | 28 | September 21st 05 01:37 PM |
Talk about the high cost of aviation! | C J Campbell | Piloting | 15 | August 12th 03 04:09 AM |
