Other than the 'holier than thou' aspects of taildraggers and their
pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? |
![]() wrote in message ... Other than the 'holier than thou' aspects of taildraggers and their pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? Less weight and drag would be another plus. |
On Jul 7, 6:43 am, wrote:
Other than the 'holier than thou' aspects of taildraggers and their pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? Less tendency to flip over on soft fields than trikes. The taildragger's mains are not far forward of the CG, and the trikes nosewheel is a LOT further forward, so you can see, if you imagine a pole-vaulter, that the trike's nosewheel will get more and more weight shoved onto it when it starts to dig in, while the taildragger's mains get only a little. Besides that, the taildragger has a nose-high landing attitude that makes the wings lift the airplane and reduce the weight on the wheels until much lower speeds are reached. All of this applies for takeoff, too, though the trike's nose can be lifted under power to get it out of the mud. Dan |
In article , Maxwell says...
wrote in message ... Other than the 'holier than thou' aspects of taildraggers and their pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? Less weight and drag would be another plus. You're always in drag, Maxine. -- "Tis an ill wind that blows no minds" |
On Jul 7, 10:05*am, wrote:
On Jul 7, 6:43 am, wrote: Other than the 'holier than thou' aspects of taildraggers and their pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? * * * * *Less tendency to flip over on soft fields than trikes. The taildragger's mains are not far forward of the CG, and the trikes nosewheel is a LOT further forward, so you can see, if you imagine a pole-vaulter, that the trike's nosewheel will get more and more weight shoved onto it when it starts to dig in, while the taildragger's mains get only a little. Besides that, the taildragger has a nose-high landing attitude that makes the wings lift the airplane and reduce the weight on the wheels until much lower speeds are reached. All of this applies for takeoff, too, though the trike's nose can be lifted under power to get it out of the mud. * * * * * * * Dan The nose high landing can be done with a trike, of course, but there's no doubt most trike drivers come in too hot. I don't do sod fields with my old Mooney because even if I do drag the tail on when the nose wheel settles the prop is way too close to the ground. I do think one can lift off in the same distance no matter if the extra wheel is in the front or the back, but the extra weight could be a minor factor. Thanks for the insights, Max and Dan Hadn't thought about the extra weight |
"Maxwell" luv2^fly99@cox.^net wrote in news:Jwock.18253$%q.107
@newsfe24.lga: wrote in message ... Other than the 'holier than thou' aspects of taildraggers and their pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? Less weight and drag would be another plus. A bit like your pointy head. Bertie |
Bertie the Bunyip wrote: "Maxwell" luv2^fly99@cox.^net wrote in news:Jwock.18253$%q.107 @newsfe24.lga: wrote in message ... Other than the 'holier than thou' aspects of taildraggers and their pilots, what are their real advantages? Has it to do with prop clearance on unimproved fields, or fatter mains being better in that same environment? Does anyone know if, with the same level of experience pilots, they have a better or worse accident record when compared to airplanes of the same general size that have the tailwheel under the engine? Less weight and drag would be another plus. A bit like your pointy head. there are tail draggers still in operation? i thought everyone put the third wheel in front nowadays if a nose up profile on the ground is such an advantage why not just lengthen the front strut arf meow arf - raggedy ann and andy for president and vice limp and spineless lint for brains is better yet and nice then rueing pair of shrub and dick the republican lice call me desdenova seven seven seven seven seven seven |
Tricycle gear Cub? | Ken Finney | Piloting | 8 | September 17th 07 11:43 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Tricycle Midget Thought | Dick | Home Built | 4 | March 26th 04 11:12 PM |
WarPac War Plans-any conventional? | Matt Wiser | Military Aviation | 1 | December 8th 03 09:29 PM |
tricycle undercarriage | G. Stewart | Military Aviation | 26 | December 3rd 03 02:10 AM |
