| Tags: asl, camguard |
I just saw an ad for ASL CamGuard and wonder if anyone out there has any
experiences with this product that they would like to share. Good? Bad? Neither? Is it just a detergent or a balonium-based material, or does it have lubricating properties, such as TCP has? -- Remove _'s from email address to talk to me. |
| Ads |
Orval Fairbairn wrote:
I just saw an ad for ASL CamGuard and wonder if anyone out there has any experiences with this product that they would like to share. Good? Bad? Neither? Is it just a detergent or a balonium-based material, or does it have lubricating properties, such as TCP has? Penn Yan recommended it to me just before they got FAA approval on the stuff. I've been using it on Penn Yan's recommendation, but I can't tell you whether it makes a difference or not. It is supposedly at rust inhibitor additive. I don't know that it has any lubricating properties. The claims seem more plausible than some of the claims of past snake oils. |
"OF" == Orval Fairbairn writes:
OF I just saw an ad for ASL CamGuard and wonder if anyone out OF there has any experiences with this product that they would OF like to share. Aviation Consumer tested it favorably: "The middle ground--and it's admittedly vast--is the 60 hour-a-year owner who needs the airplane for three hours each December through March. CamGuard is the clear winner here, since its performance is nearly as good as the dedicated storage oils, it's cheaper and allows normal operation. Thus far, we've been impressed with CamGuard and we're using it in our own airplane. As we go to press this month, CamGuard is on the verge of obtaining FAA approval. Frankly, that doesn't impress us much but some buyers want the FAA imprimatur. Approved or not, we think it's a good product." http://www.aviationconsumer.com/issu...rs/5541-1.html OF Is it just a detergent No. Detergents aren't used in aviation engines. OF does it have lubricating properties, such as TCP has? No. TCP isn't a lubricant. CamGuard is an anti-corrosion additive, not a lubricant. -- An old person said to a youth, 'As you are, I once was; as I am, you shall be.' ~ Mexican proverb |
Bob Fry wrote: "OF" == Orval Fairbairn writes: OF I just saw an ad for ASL CamGuard and wonder if anyone out OF there has any experiences with this product that they would OF like to share. Aviation Consumer tested it favorably: "The middle ground--and it's admittedly vast--is the 60 hour-a-year owner who needs the airplane for three hours each December through March. CamGuard is the clear winner here, since its performance is nearly as good as the dedicated storage oils, it's cheaper and allows normal operation. Thus far, we've been impressed with CamGuard and we're using it in our own airplane. As we go to press this month, CamGuard is on the verge of obtaining FAA approval. Frankly, that doesn't impress us much but some buyers want the FAA imprimatur. Approved or not, we think it's a good product." http://www.aviationconsumer.com/issu...rs/5541-1.html OF Is it just a detergent No. Detergents aren't used in aviation engines. OF does it have lubricating properties, such as TCP has? No. TCP isn't a lubricant. CamGuard is an anti-corrosion additive, not a lubricant. I want to thank everybody who responded. I may just try the stuff! Orval -- Remove _'s from email address to talk to me. |
I was the director of the engine laboratory at Exxon Research and
Engineering and performed the initial research on the Elite oil. Exxon management decided to copy the Aeroshell oil. When I left Exxon I was asked to formulate Camguard. WOW! If someone could get you and Ben Vissar together, that would be an incredible forum on engine lubrication. |
Edward Kollin wrote: 'Orval Fairbairn[_2_ Wrote: ;639886']In article , Bob Fry wrote: --- "OF" == Orval Fairbairn writes:-- OF I just saw an ad for ASL CamGuard and wonder if anyone out OF there has any experiences with this product that they would OF like to share. Aviation Consumer tested it favorably: "The middle ground--and it's admittedly vast--is the 60 hour-a-year owner who needs the airplane for three hours each December through March. CamGuard is the clear winner here, since its performance is nearly as good as the dedicated storage oils, it's cheaper and allows normal operation. Thus far, we've been impressed with CamGuard and we're using it in our own airplane. As we go to press this month, CamGuard is on the verge of obtaining FAA approval. Frankly, that doesn't impress us much but some buyers want the FAA imprimatur. Approved or not, we think it's a good product." http://tinyurl.com/6ytgnn OF Is it just a detergent No. Detergents aren't used in aviation engines. OF does it have lubricating properties, such as TCP has? No. TCP isn't a lubricant. CamGuard is an anti-corrosion additive, not a lubricant.- I want to thank everybody who responded. I may just try the stuff! Orval -- Remove _'s from email address to talk to me. Camguard is conceptually the additive package that I designed for the Exxon Elite oil. It contains 11 additives and is 100% active. It prevents rust/corrosion and deposits, reduces wear and conditions seals. I was the director of the engine laboratory at Exxon Research and Engineering and performed the initial research on the Elite oil. Exxon management decided to copy the Aeroshell oil. When I left Exxon I was asked to formulate Camguard. Regards, Ed Thank you! I just received four pints and am going to put some in both my airplane and my vintage Porsche. -- Remove _'s from email address to talk to me. |
Quote:
Regards, Ed |
Camguard is really useful for older cars, as you get a substantial corrosion inhibiting boost and anti-wear protection superior to ZDDP.
| Thread Tools | |
| Display Modes | |
