![]() "Neal Pfeiffer" wrote in message news ![]() When I asked about XCOM, it was not because of price. In fact in the US the cost is on par with a Becker and definitely well above a Microair. I simply wanted to know if others out there use them and found them to be reliable. As for ATR radios, the ATR720C in my Ka6E has worked well. The ATR57 in my Ka6BR has not been reliable. Now the ATR57 in a friend's Elfe appears to work well for him. My 57 was an early version and they may be more problematic. Whenever I get the 57 back from the shop, I will need to decide whether to keep it or trade it out. I do want to keep the small package with a circular, panel mount. ..... Neal I have one of the very early ATR 57s. It set around the shop for about four years while I was restoring my HP-14. When it was finally installed, it had problems. It was sent back to the factory (not a inexpensive process) and was upgraded. As Brian mentions, there are times I miss transmissions if my squelch is set too high and there is background hiss if it isn't. Counting the ART 57's original cost plus the repair cost, I could have had a new Becker and a few extra dollars in my pocket. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder |
At 19:18 16 August 2008, Wayne Paul wrote:
"Neal Pfeiffer" wrote in message news ![]() When I asked about XCOM, it was not because of price. In fact in the US the cost is on par with a Becker and definitely well above a Microair. I simply wanted to know if others out there use them and found them to be reliable. As for ATR radios, the ATR720C in my Ka6E has worked well. The ATR57 in my Ka6BR has not been reliable. Now the ATR57 in a friend's Elfe appears to work well for him. My 57 was an early version and they may be more problematic. Whenever I get the 57 back from the shop, I will need to decide whether to keep it or trade it out. I do want to keep the small package with a circular, panel mount. ..... Neal I have one of the very early ATR 57s. It set around the shop for about four years while I was restoring my HP-14. When it was finally installed, it had problems. It was sent back to the factory (not a inexpensive process) and was upgraded. As Brian mentions, there are times I miss transmissions if my squelch is set too high and there is background hiss if it isn't. Counting the ART 57's original cost plus the repair cost, I could have had a new Becker and a few extra dollars in my pocket. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder I had a Becker 3201 radio and Becker 4401 xpndr in my Ventus for 6 years (they are still there, I think, new owner). They both worked flawlessly in all kinds of temperatures at altitudes from sea level to above 20K. In both cases I spent a few extra bucks to have a professional make up the wiring harness for me. Basically all I had to do was hook up two wires for power. Also, a good antenna installation is a must. The Becker ran on a 12 volt battery and I had flights up to 6 hours in length with the radio going strong...xmit & receive (granted I don't talk much on the radio). I got many comments from others about how clear and strong my transmissions were heard over the air..."airline" quality. JLH |
On Aug 15, 8:18*pm, Dixie Sierra wrote:
I've decided to give up on my Avionic Dittel and buy new. It's been a good radio and has given many years of service, but I'd like some new functionality. Functionality is really at the heart of my dilemna. I've kind of narrowed things down to Becker vs Microair (I've ruled out Walter Dittel on price... everyone has a limit independent of reason). There seems to be a broad consensus that the Becker is a more reliable choice. However, the Microair seems to offer a number of superior features. 1) Remote operation from a stick mounted toggle. 2) Dual scan beteween the active and standby freqs with the ability to transmit on the active. (Becker also offers a scan option but it seems to be cover far more freqs and the freqs covered can only be changed by turning the radio off and on at least twice. Dual scan seems very nice when flying XC in the vicinity of an active airport.) 3 Alpha descriptions of saved freqs. 4) Variable squelch (Becker has this, but not without turning the radio off and on at least twice to make changes.) So here I am... The Microair costs less and has "better" features. But who cares if it doesn't work? What to do? What to do?.. I think I'll fly with the handheld! What am I missing? I'm sure there are many cosniderations that escape me. Doug Doug, I bought a used Becker AR3201 from Wings & Wheels more than 15 years ago and it has been working flawlessly ever since. If I had to replace it, I would consider a Becker again. You want to pick a manufacturer that has been around for a while and will be around for a while, too. Service/Repair facility network is an important point, too. Uli |
I have a Mircoaire Rev N radio in my glider, purchased as a "Gllider Kit"
kit with mic, speaker, and wiring harness from Aircraf Spruce. It has worked fine for me. Folks report my transmissions are clear and strong, as long as my glider is not pointed straight at them (antenna in trailing edge of rudder, most of which is carbon fiber). I mentioned it was specifically a "glider kit" since the modulation has been fine. Our club has another Mircoaire Rev N in a 1-26 that works fine, but has had to have the mic gain adjusted. If battery voltage is gets low, the transmission does seem to get garbled. I fly with 2 batteries so I can switch a fresh one in late in the day if needed to get good radio transmission. John Scott |
On Aug 16, 8:18*am, Dixie Sierra wrote:
2) Dual scan beteween the active and standby freqs with the ability to transmit on the active. (Becker also offers a scan option but it seems to be cover far more freqs and the freqs covered can only be changed by turning the radio off and on at least twice. Dual scan seems very nice when flying XC in the vicinity of an active airport.) I might be wrong but I don't think that the Microaire has dual scan. It has active and standby freqs but you have to manually toggle between them. Otherwise it has what you say that Becker has, scanning all the channels in memory. Here is a quote from the manual; Mode Switch - Scan Mode - By holding down the toggle switch for 3 seconds, the M760 goes into scan mode. The programmed memories are cycled quickly across the display. The M760 checks each memory in turn for any signal. If there is no signal the radio moves to the next programmed memory. When a signal is detected, the scan locks to that memory to receive the signal. This memory is held for 10 seconds after the signal finishes to afford the user an opportunity to reply on that memory channel. The user can stop the scan operation by pressing down briefly the toggle key, or the PTT button. |
Must be new to Rev P.
I decided on the Microair. I don't know if I'll regret it... but I'll sure find out. Cost was not the only factor, or even the deciding factor, but it was a factor. With the money I'll save, I can buy a PCAS (almost). There's at least one Microair in the local area that seems to work fine. 6.1.2 Monitor Function By holding down the remote memory button or toggle key for 3 seconds and then releasing, the M760 will enable the monitor function. Both active and standby frequencies are monitored at the same time for a signal. An ‘M’ character will oscillate up and down to indicate that the monitor function is active. A signal can be received on either the active or the standby frequency. While receiving a signal on the active frequency the standby channel is NOT monitored. While receiving a signal on the standby frequency the active channel is periodically monitored. If a signal is found on the active frequency the M760 will revert to the active frequency. After a signal has been received the M760 will return to monitoring both frequencies. IMPORTANT NOTE The user can only transmit on the active frequency. If the PTT is keyed the radio will transmit on the active frequency only. Monitor mode can be cancelled by pressing the remote memory button or toggle key briefly. The ‘M’ character is no longer displayed at the right hand end of the display. If the mode key is pressed to move to channel mode, the monitor function is dis-engaged. |
On Aug 19, 8:41*am, Dixie Sierra wrote:
Must be new to Rev P. I decided on the Microair. I don't know if I'll regret it... I doubt if you'll regret it. Many of the early problems were caused by poor contact between the microcontroller and its socket. Later version used a better quality socket and the early ones can be made fully function by following a service bulletin that improves the contact with the original socket. It an easy fix that any electronics amateur would be capable of doing. (A while ago Microaire prevented public access to the SBs but I have PDFs if anyone needs one) Thanks for the information on the dual scan mode. I don't have that but it sounds like are useful upgrade. I don't have to persuade you since you already decided on Microaire, but I'd never want a glider radio that didn't have pilot adjustable squelch level. It allows monitoring of safety calls from close gliders while shutting off the distant chatterers. Break the squelch before calling ground crew when out on course. Andy |
Microair 720 f/s | [email protected] | Soaring | 0 | October 26th 06 03:39 AM |
Microair 760 | Ian K | Soaring | 2 | August 29th 06 12:59 PM |
Parts for sale Microair radio and Microair transponder | User | Home Built | 2 | December 14th 05 11:23 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
Microair vs Becker | Ian McPhee | Soaring | 0 | August 30th 03 09:45 PM |
