I just started using a fresh batch of resin/hardener from Aeropoxy
(shipped by AS&S last week). I had a single white light off to the side. I decided to uncover the part 30 hours after the lay up. When I pulled the peel ply off quickly, the line where it separated glowed bright purple for about 1/2 second. I couldn't believe it, so I went and got a couple witnesses and immediately they saw the ply turn from dim white to bright purple too. I proceeded to pull a large section off very quickly and that lit up the section of peel ply from underneath! Has this ever happened to anyone else? Any explanation how it could even be possible? We held the separation line up to the light and studied it when it was perfectly still. There wasn't the slightest bit of purple showing, as it wasn't being ripped off. The only explanation I can muster is, the breaking of molecular cross-linking caused a temporary, chemical reaction, that is not visible unless the epoxy is really fresh and the surrounding light is not too bright. |
| Thread Tools | |
| Display Modes | |
| Purple fringe--what to do about it and why [2/5] - "102 Jim-LeroyWVA-001- Portion showing purple fringe.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 1 | August 9th 07 10:34 AM |
| Purple fringe--what to do about it and why [3/5] - "103 Jim-LeroyWVA-001- Portion showing purple fringe gone.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 9th 07 01:33 AM |
| Robin Peel References | Robin Peel | Simulators | 3 | May 10th 06 09:11 PM |
| Is Ceconite and Peel Ply the same thing? | Lou | Home Built | 9 | January 14th 06 06:53 AM |
| "orange peel" and dope | Michael Horowitz | Home Built | 3 | June 17th 05 04:40 AM |
