Hello again,
On Aug 19, 3:32*pm, Alexander Avtanski wrote: [...] I just came back from a walk outside my office in Santa Clara. *Around 3:00pm I saw something quite unusual - while all the planes from San Jose International were taking off in N-W direction, there was a single plane (something that looked a bit like MD-80) that seemed to _land_ coming from N-W, exactly opposite the rest of the traffic. [...] I just got an e-mail from a reader of this group (Thanks!), who sent me links to some ATC audio and pointed out the place where the tower says that a "flight check Lear will do a low approach to 12R". http://avtanski.net/images/var/KSJC-...2008-2200Z.mp3 (This is about 20 sec. from the start of the recording). So, first, shame on me that I could confuse a Learjet with MD-80. It has been quite low then and it zoomed really fast so it managed to surprise me and I couldn't get a look, but still... I checked the approach audio too - at about 24min 20sec of this recording some guy says something about "we've lost a receiver", but I can't make the rest. Here's the audio (don't forget to scroll to the 24:20 mark!): http://avtanski.net/images/var/KSJC-...2008-2130Z.mp3 What's this about? Just curious... Regards, - Alex |
Alexander Avtanski wrote: I just got an e-mail from a reader of this group (Thanks!), who sent me links to some ATC audio and pointed out the place where the tower says that a "flight check Lear will do a low approach to 12R". Flight Check is the FAA checking navaids. The ILS for 12R was probably due for a check. I've seen them do a check at Palo Alto (PAO), and they zipped through the approach really fast, on their way to the next check. John -- John Clear - http://www.clear-prop.org/ |
"Alexander Avtanski" wrote in message
... I checked the approach audio too - at about 24min 20sec of this recording some guy says something about "we've lost a receiver", but I can't make the rest. Here's the audio (don't forget to scroll to the 24:20 mark!): http://avtanski.net/images/var/KSJC-...2008-2130Z.mp3 What's this about? Just curious... FAA flight check uses NAV receivers in the back of the plane coupled to a computer that checks the ILS equipment. They could have had some type of glitch in the middle of a run which would require them to do the last run over. That's my guess. FAA flight check has numerous planes. They have a few Lear 35s, but most of their planes are King-Airs. All of them have 2 digit N numbers. |
![]() "Mike" wrote in message news:1S1sk.536$p72.166@trnddc05... "Alexander Avtanski" wrote in message ... I checked the approach audio too - at about 24min 20sec of this recording some guy says something about "we've lost a receiver", but I can't make the rest. Here's the audio (don't forget to scroll to the 24:20 mark!): http://avtanski.net/images/var/KSJC-...2008-2130Z.mp3 What's this about? Just curious... FAA flight check uses NAV receivers in the back of the plane coupled to a computer that checks the ILS equipment. They could have had some type of glitch in the middle of a run which would require them to do the last run over. That's my guess. FAA flight check has numerous planes. They have a few Lear 35s, but most of their planes are King-Airs. All of them have 2 digit N numbers. I used to watch the FAA conduct check flights at TEB and at other times at SJC. They oftentimes made several runs at the approach NAVAID...on coarse and at the limit instrument deviation. I don't know exactly what their plan was but it was more than 1 pass. |
"Bob F." wrote in message
. .. "Mike" wrote in message news:1S1sk.536$p72.166@trnddc05... "Alexander Avtanski" wrote in message ... I checked the approach audio too - at about 24min 20sec of this recording some guy says something about "we've lost a receiver", but I can't make the rest. Here's the audio (don't forget to scroll to the 24:20 mark!): http://avtanski.net/images/var/KSJC-...2008-2130Z.mp3 What's this about? Just curious... FAA flight check uses NAV receivers in the back of the plane coupled to a computer that checks the ILS equipment. They could have had some type of glitch in the middle of a run which would require them to do the last run over. That's my guess. FAA flight check has numerous planes. They have a few Lear 35s, but most of their planes are King-Airs. All of them have 2 digit N numbers. I used to watch the FAA conduct check flights at TEB and at other times at SJC. They oftentimes made several runs at the approach NAVAID...on coarse and at the limit instrument deviation. I don't know exactly what their plan was but it was more than 1 pass. The number of passes they make depends on what type of ILS it is and what check they are doing. I've seen them take several hours to do a CAT III ILS. For a typical CAT I ILS they will check it once per year making about 3 approaches and an arc. Every other year they will do a more extensive check. The equipment is also checked extensively on the ground at regular intervals. |
Mike writes:
The number of passes they make depends on what type of ILS it is and what check they are doing. I've seen them take several hours to do a CAT III ILS. For a typical CAT I ILS they will check it once per year making about 3 approaches and an arc. Every other year they will do a more extensive check. The equipment is also checked extensively on the ground at regular intervals. How do they fly the plane with sufficient precision to make the check valid? Or do they use methods that are independent of the precision of the aircraft's movements (if so, what are they?)? |
Saw something strange... (0/1) | jc[_4_] | Aviation Photos | 0 | January 31st 08 06:16 PM |
strange | houstondan | Piloting | 10 | February 14th 06 05:02 PM |
Seems a little strange- | Capt.Doug | Piloting | 20 | January 30th 05 02:30 AM |
Strange one about the 296 | kage | Piloting | 0 | June 13th 04 01:42 AM |
Strange one??? | Big John | Piloting | 15 | March 4th 04 12:25 AM |
