On Thu, 04 Sep 2008 21:28:24 GMT, "Mike" wrote:
"Steven P. McNicoll" wrote in message om... paul kgyy wrote: Is it normal practice for a Mode S transponder to display the aircraft tail number to ATC? No. It isn't displayed to controllers, but a ModeS transponder does transmit its serial number which can be read using tools not available to the controller. The serial number does translate to the N number so long as the transponder is correctly registered. As of now this technology hasn't been implemented to the controller, nor is the serial number recorded in the continuous data recording archive. Doesn't the system process the flightid field? Or isn't that transmitted? |
"Peter Clark" wrote in message
... On Thu, 04 Sep 2008 21:28:24 GMT, "Mike" wrote: "Steven P. McNicoll" wrote in message news:TMOdnSYGZc1D0F3VnZ2dnUVZ_gadnZ2d@earthlink. com... paul kgyy wrote: Is it normal practice for a Mode S transponder to display the aircraft tail number to ATC? No. It isn't displayed to controllers, but a ModeS transponder does transmit its serial number which can be read using tools not available to the controller. The serial number does translate to the N number so long as the transponder is correctly registered. As of now this technology hasn't been implemented to the controller, nor is the serial number recorded in the continuous data recording archive. Doesn't the system process the flightid field? Or isn't that transmitted? I'm not sure what "system" or "field" you're referring. The computers at the centers and tracons have no idea if the transponder is ModeS or not. They only process the beacon code and display the ACID that's in the flight plan. |
In article Pe%vk.431$Dj1.271@trnddc02, "Mike" wrote:
I'm not sure what "system" or "field" you're referring. The computers at the centers and tracons have no idea if the transponder is ModeS or not. They only process the beacon code and display the ACID that's in the flight plan. The centers and tracons don't have Mode S radars yet? -- Bob Noel (goodness, please trim replies!!!) |
On 2008-09-05, Bob Noel wrote:
In article Pe%vk.431$Dj1.271@trnddc02, "Mike" wrote: I'm not sure what "system" or "field" you're referring. The computers at the centers and tracons have no idea if the transponder is ModeS or not. They only process the beacon code and display the ACID that's in the flight plan. The centers and tracons don't have Mode S radars yet? Some do, some don't. The problem is not the radar or the computer behind it, bu the computer driving the displays that the controllers see: they don't get the mode S data. -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC |
"Bob Noel" wrote in message
... In article Pe%vk.431$Dj1.271@trnddc02, "Mike" wrote: I'm not sure what "system" or "field" you're referring. The computers at the centers and tracons have no idea if the transponder is ModeS or not. They only process the beacon code and display the ACID that's in the flight plan. The centers and tracons don't have Mode S radars yet? The centers never have and never will other than a few terminal radars which are piped into the centers for low level coverage in some areas. The ModeS systems themselves are located all over the US, but there's no datalink capability between the sensor and the automation system. So the only thing forwarded to the TRACON from the transponder is the 4 digit octal beacon code and the 3 digit altitude. |
Peter,
Doesn't the system process the flightid field? Some do. In Europe, more and more do. Or isn't that transmitted? It certainly is. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
Peter, Doesn't the system process the flightid field? Some do. In Europe, more and more do. Or isn't that transmitted? It certainly is. Not in the U.S. |
Sam,
Not in the U.S. Source? A source that shows a Garmin GTX330 does not transmit flight ID data in the US would suffice. -- Thomas Borchert (EDDH) |
"Thomas Borchert" wrote in message
... Sam, Not in the U.S. Source? A source that shows a Garmin GTX330 does not transmit flight ID data in the US would suffice. If a tree falls in the woods, but nobody is there to hear it, does it make a sound? |
Mike wrote:
"Thomas Borchert" wrote in message ... Sam, Not in the U.S. Source? A source that shows a Garmin GTX330 does not transmit flight ID data in the US would suffice. If a tree falls in the woods, but nobody is there to hear it, does it make a sound? Good way to put it. Plus, in the high end gear, the Mode S message data can be implemented in stages. |
| Thread Tools | |
| Display Modes | |
| Garrecht Mode S transponder - USA? | Eric Greenwell | Soaring | 3 | August 20th 07 10:05 PM |
| New transponder mode S vs. mode C | Tom N. | Soaring | 39 | November 7th 06 08:40 AM |
| KT76C Mode C transponder - what is it worth? | Mike Rapoport | General Aviation | 1 | November 21st 04 06:56 AM |
| KT76C Mode C transponder - what is it worth? | G.R. Patterson III | Owning | 0 | November 21st 04 06:56 AM |
| WTB: Mode C Transponder | Chris Batcheller | Aviation Marketplace | 0 | February 21st 04 02:31 PM |
