Cherokee shoulder seat belt replacement
Old October 4th 08, 02:31 PM posted to rec.aviation.owning
Mike Spera
Default Cherokee shoulder seat belt replacement
texas slacker wrote:
My warrior is fitted with shoulder strap seat belts anchored to the
upper side of the plane, just above the second window. From the looks
of them they were original equipment. Now - I need to remove the
retracting mechanism so I can have new belts attached. After removal
of the plastic cover plate I see the spool, bolted to a bracket which
is attached to the fuselage with three phillips head screws. The bolt
just rotates so I assume it has an unsecured head that I can't get to
so the three screws are the only way to remove the retracting
mechanism. The only problem is that the screws are so close to the
spool that I can't get a proper bite with a screwdriver. A closefit
screwdriver will simply "cam out", I can't get any lateral pressure on
it. I might be able to grab the screw head with a pair of vise grips
but hoped that someone on this group would have a smarter way. If you
did - where did you take the equipment for fixin? Leo
As others have replied, you get the whole retract assembly off via the
big nut, not the screws. The bolt head is on the outside of the plane.
I did not get mine rewebbed. Instead, Chief Aircraft had (and still has)
complete new assemblies. I paid $136 each. They are up to $149. Part
number BM H162-9-66N. Since rewebbing costs $75 - $100 or so, once you
add shipping, it ain't worth it in my mind to reweb. Don't forget the
down time. Also, many of these old retractor mechanisms have pretty worn
out return springs. Rewebbing may give you a nice new belt that still
won't fully retract. As a bonus, you get shiny new chrome hardware.
Combine this with new lap belts and that new interior can look awfully
spiffy.
Good Luck,
Mike
Seat belt clip Fred[_4_] Soaring 2 June 23rd 08 06:10 PM
Seat Belt should be re-webbed or changed Patti Browne Soaring 3 December 13th 06 05:10 AM
Seat belt tags Stephen Stilkey Owning 28 March 15th 04 05:29 PM
Seat Belt Extenders M.E. Borner Owning 4 October 3rd 03 02:55 PM
Seat Belt Age? BD5ER Home Built 2 July 7th 03 01:10 AM
