Bertie the Bunyip wrote:
Actually, it does. It's moving a lot of air from one end to the other an also producing quite a bit of heat. Guess by that definition Bertie is actually employed! |
On Oct 2, 7:39*pm, Tman x@x wrote:
Bertie the Bunyip wrote: Actually, it does. It's moving a lot of air from one end to the other an also producing quite a bit of heat. Guess by that definition Bertie is actually employed! ....and Congress works, QED? Please reconsider. |
Tman x@x wrote in :
Bertie the Bunyip wrote: Actually, it does. It's moving a lot of air from one end to the other an also producing quite a bit of heat. Guess by that definition Bertie is actually employed! Mmm, not a million miles form the truth,I suppose.. No more so than for anyone else in my trade, though... Fly somewhere, whine and bitch. fly somewhere else, whine and bitch. .. Bertie |
The only time you have to have more thrust than aircraft weight is if you
plan to take off vertically with no takeoff run. "Darkwing" theducksmail"AT"yahoo.com wrote in message ... How does rated thrust for a jet engine translate to actual power? I guess my question is, for example, a Cessna Mustang has two engines that produce 1,460 lbs of thrust each (x 2) so the total is 2920 lbs of thrust for the two engines. The takeoff weight for the Mustang is listed as 8,645 lbs. so the engines are only putting out a 1/4 of the total aircrafts weights. So do they rate thrust different to the actual weight that the engines can fly? Is the reason that is does only produce 2920 lbs. of thrust but the wing is what actually makes the plane fly so the thrust doesn't need to equal weight? |
thrust line for engine and not mounting engine on this thrust line | tommyann | Home Built | 8 | December 15th 06 03:31 PM |
Propeller thrust question | xerj | Piloting | 11 | November 25th 05 03:12 AM |
Engine question | Max Richter | Naval Aviation | 13 | August 29th 05 05:07 AM |
Shutting down engine Question | Lisa | Piloting | 26 | April 5th 04 12:53 AM |
Stupid hp to thrust question | Mark | Home Built | 52 | December 9th 03 01:41 PM |
