#11
Grob 103 Twin II Brake Master Cylinder
The only way I ever got a Grob brake to bleed properly was to use a
pressure bleeder where fluid is forced up through the system from the slave cylinder. Not too expensive from Spruce & Specialty. JJ Mike McCarron wrote: JJ, I used Dot 3 fluid with compatible O ring on the slave cylinder. The cap on the BMW master cylinder said to use DOT 3/4 brake fluid only. MC At 14:22 22 October 2008, JJ Sinclair wrote: Why didn't it work, Mike? Hydraulics are hydraulics, the Clevland brake slave cylinder doesn't know (or care) where that pressure is coming from? Make sure you have compatible seals. What type fluid does BMW use? Can't mix the red stuff with the clear stuff. JJ Mike McCarron wrote: JJ, I did purchase a master cylinder from a BMW motorcycle dealer that did fit in place. Unfortunately it did not function properly. It was properly bled and all but it did not work. I don't know what to do next. There must be at least 100 of these gliders in the US that will need a master cylinder replacement in the future. I don't see how we can junk a $30K glider for lack of a functioning master cylinder. Thanks for your comment, MC At 13:41 22 October 2008, JJ Sinclair wrote: If memory serves me, its a motorcycle master cylinder BMW? I believe they cut it down from the original, good luck getting your inspector to sign off on installing it! JJ Mike McCarron wrote: My club has a 1983 Grob 103 Twin II that needs a new master cylinder. Over the years the Grob factory has made changes to the system without full documentation and as a result the US distributor can not be sure of how I go about purchasing the proper master cylinder for this glider. If you or anyone you know has replaced the master cylinder on a vintage Grob 103 Twin II recently I would appreciate your input on where I might purchase the correct system. Thank you, Mike |
there is now a new bleeder system from TOST
for details please see http://www.wingsandwheels.com/page32.htm tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Mike McCarron" wrote in message ... How can one tell where to position the lever? Half way through it's total travel or some other location? MC At 16:33 22 October 2008, Uncle Fuzzy wrote: On Oct 22, 8:22=A0am, Uncle Fuzzy wrote: On Oct 22, 8:01=A0am, "bumper" wrote: Yup, what JJ said. The "red stuff" is Mil Spec 5606 hydraulic oil and i= s compatible with Buna-N O-rings and seals. It's also commonly used in th= e USA for most small GA aircraft. DOT automotive brake fluid, the "clear stuff", most often glycol-ether based, and is compatible with EPDM rubber seals. If you are switching parts from one fluid to the other, you gotta chang= e the rubber stuff. bumper "JJ Sinclair" wrote in message ..= .. Why didn't it work, Mike? Hydraulics are hydraulics, the Clevland brake slave cylinder doesn't know (or care) where that pressure is coming from? Make sure you have compatible seals. What type fluid doe= s BMW use? Can't mix the red stuff with the clear stuff. JJ Mike McCarron wrote: JJ, I did purchase a master cylinder from a BMW motorcycle dealer that d= id fit in place. =A0Unfortunately it did not function properly. =A0It was p= roperly bled and all but it did not work. =A0I don't know what to do next. = =A0There must be at least 100 of these gliders in the US that will need a mas= ter cylinder replacement in the future. =A0I don't see how we can junk a= $30K glider for lack of a functioning master cylinder. Thanks for your comment, MC At 13:41 22 October 2008, JJ Sinclair wrote: If memory serves me, its a motorcycle master cylinder BMW? I believ= e they cut it down from the original, good luck getting your inspecto= r to sign off on installing it! JJ Mike McCarron wrote: My club has a 1983 Grob 103 Twin II that needs a new master cylin= der. Over the years the Grob factory has made changes to the system without= full documentation and as a result the US distributor can not be sure = of how I go about purchasing the proper master cylinder for this glider. If you or anyone you know has replaced the master cylinder on a vintage Grob 103 Twin II recently I would appreciate your input on where = I might purchase the correct system. Thank you, Mike- Hide quoted text - - Show quoted text - In our club Grob 103, the master cylinder is a Magura motorcycle front brake master cylinder. =A0Magura makes parts for a bunch of bikes, and for the aftermarket. Motorcycle front brake master cylinders come in a variety of piston diameters. =A0They are also somewhat weird to bleed. They won't develop pressure unless almost all of the air is bled out of the system. =A0"Pumping" one endlessly has no effect. =A0On a bike, on= e trick is to zip tie the handle so that the lever is halfway to the grip, crack the bleeder on the caliper (with a tube on it to direct the drainage), and walk away for a couple hours and let gravity do some work for you. =A0Much quicker is to zip tie the lever halfway, and use a small vacuum pump rig to PULL the fluid through. =A0Once most of the air is gone, you should be able to develop some pressure to complete the bleeding in the normal manner. =A0YES to DOT 3/4. =A0NO to Mil Spec 5606 hydraulic oil. =A0As an experiment, I tossed some motorcycle brake bits in a jar of 5606. =A0They turned into something other than brake bits pretty quickly.- Hide quoted text - - Show quoted text - Clarification on the quicker way to purge the air out: Zip tie the lever at half travel, use a vacuum pump ON THE CALIPER BLEEDER to pull brake fluid through. Hope this helps |
On 22 Oct, 19:05, "Tim Mara" wrote:
there is now a new bleeder system from TOST for details please seehttp://www.wingsandwheels.com/page32.htm tim Please visit the Wings & Wheels website atwww.wingsandwheels.com "Mike McCarron" wrote in message ... How can one tell where to position the lever? *Half way through it's total travel or some other location? MC At 16:33 22 October 2008, Uncle Fuzzy wrote: On Oct 22, 8:22=A0am, Uncle Fuzzy *wrote: On Oct 22, 8:01=A0am, "bumper" *wrote: Yup, what JJ said. The "red stuff" is Mil Spec 5606 hydraulic oil and i= s compatible with Buna-N O-rings and seals. It's also commonly used in th= e USA for most small GA aircraft. DOT automotive brake fluid, the "clear stuff", most often glycol-ether based, and is compatible with EPDM rubber seals. If you are switching parts from one fluid to the other, you gotta chang= e the rubber stuff. bumper "JJ Sinclair" *wrote in message ...= .. Why didn't it work, Mike? Hydraulics are hydraulics, the Clevland brake slave cylinder doesn't know (or care) where that pressure is coming from? Make sure you have compatible seals. What type fluid doe= s BMW use? Can't mix the red stuff with the clear stuff. JJ Mike McCarron wrote: JJ, I did purchase a master cylinder from a BMW motorcycle dealer that d= id fit in place. =A0Unfortunately it did not function properly. =A0It was p= roperly bled and all but it did not work. =A0I don't know what to do next. = =A0There must be at least 100 of these gliders in the US that will need a mas= ter cylinder replacement in the future. =A0I don't see how we can junk a= $30K glider for lack of a functioning master cylinder. Thanks for your comment, MC At 13:41 22 October 2008, JJ Sinclair wrote: If memory serves me, its a motorcycle master cylinder BMW? I believ= e they cut it down from the original, good luck getting your inspecto= r to sign off on installing it! JJ Mike McCarron wrote: My club has a 1983 Grob 103 Twin II that needs a new master cylin= der. Over the years the Grob factory has made changes to the system without= full documentation and as a result the US distributor can not be sure = of how I go about purchasing the proper master cylinder for this glider. If you or anyone you know has replaced the master cylinder on a vintage Grob 103 Twin II recently I would appreciate your input on where = I might purchase the correct system. Thank you, Mike- Hide quoted text - - Show quoted text - In our club Grob 103, the master cylinder is a Magura motorcycle front brake master cylinder. =A0Magura makes parts for a bunch of bikes, and for the aftermarket. Motorcycle front brake master cylinders come in a variety of piston diameters. =A0They are also somewhat weird to bleed. They won't develop pressure unless almost all of the air is bled out of the system. =A0"Pumping" one endlessly has no effect. =A0On a bike, on= e trick is to zip tie the handle so that the lever is halfway to the grip, crack the bleeder on the caliper (with a tube on it to direct the drainage), and walk away for a couple hours and let gravity do some work for you. =A0Much quicker is to zip tie the lever halfway, and use a small vacuum pump rig to PULL the fluid through. =A0Once most of the air is gone, you should be able to develop some pressure to complete the bleeding in the normal manner. =A0YES to DOT 3/4. =A0NO to Mil Spec 5606 hydraulic oil. =A0As an experiment, I tossed some motorcycle brake bits in a jar of 5606. =A0They turned into something other than brake bits pretty quickly.- Hide quoted text - - Show quoted text - Clarification on the quicker way to purge the air out: *Zip tie the lever at half travel, use a vacuum pump ON THE CALIPER BLEEDER to pull brake fluid through. *Hope this helps- Hide quoted text - One possibly non-obvious thing is that if there are flexible rubber hoses in the pressure side of the system they you need to check that they are servicable. With age they lose stiffness and expand sufficiently under pressure such that the brakes do not work. Indistinguisable symptoms from air in the system. If you have one that is 30 years old then I would just get a new one. I don't suppose that the fancy teflon ones suffer from this. http://www.goodridge.co.uk/buy-goodridge-hoses.htm |
1 The master cylinder in the Grob103 Acro is a BMW front brake master
cylinder from a R series motorcycle. The actuating lever is the cut off front brake lever. 2 It is virtually impossible to bleed the brakes in the normal way and the following method is used by the Royal Air Force techies who service the 99 Grobs owned by the RAF a. Cover the open master cylinder in the cockpit with a cloth, important if you do not want fluid all over the floor. b With the slave unit removed from the wheel but attached to the pipe remove the slave piston from the cylinder. c Turn the unit so the slave cylinder is facing upwards and fill with DOT3/4 fluid, it tells you the correct one on the master cylinder cover. Make sure that the bottom of the cylinder is the lowest point. d Insert the piston and very slowly push completely home in the cylinder, and I do mean very slowly forcing fluid and any trapped air upwards into the master cylinder. Clean up the slave and reassemble. e Fill the master cylinder in the normal way. Saves spending a fortune on specialist tools which may or may not work. Soaring Oxford Ltd. Fosse Rd, Syerston, Newark, Nottinghamshire NG23 5NG. Tel: +441636 525318 are the UK suppliers and supply the RAF. They may help in sourcing the correct cylinder. |
This thread started with the necessity of replacing the brake master cylinder, right? Did anyone mention why it needed replacement? My first guess is wear or corrosion in the cylinder bore causing it to leak pressure. If this is the case, there are places that will bore the cylinder and sleeve it with either stainless steel or brass. It's done all the time for old cars. On the other hand, I don't know anything about the legality of doing that for an aircraft brake system. And on the Gripping Hand, I would probably do it that way myself. Jim Beckman |
There's a thread about this he http://www.aviationbanter.com/archiv...p/t-22487.html some old G103 maintenance manual on the web http://tinyurl.com/G103MM doesn't mention anything about changing brake fluid every two years as is common in most cars, however the DG505 needs it done every 4 years. http://tinyurl.com/5zy2wj At 13:00 23 October 2008, Jim Beckman wrote: This thread started with the necessity of replacing the brake master cylinder, right? Did anyone mention why it needed replacement? My first guess is wear or corrosion in the cylinder bore causing it to leak pressure. If this is the case, there are places that will bore the cylinder and sleeve it with either stainless steel or brass. It's done all the time for old cars. On the other hand, I don't know anything about the legality of doing that for an aircraft brake system. And on the Gripping Hand, I would probably do it that way myself. Jim Beckman |
On Oct 23, 7:15*am, P Ilatus wrote:
There's a thread about this he http://www.aviationbanter.com/archiv...p/t-22487.html some old G103 maintenance manual on the webhttp://tinyurl.com/G103MM doesn't mention anything about changing brake fluid every two years as is common in most cars, however the DG505 needs it done every 4 years.http://tinyurl.com/5zy2wj At 13:00 23 October 2008, Jim Beckman wrote: This thread started with the necessity of replacing the brake master cylinder, right? *Did anyone mention why it needed replacement? *My first guess is wear or corrosion in the cylinder bore causing it to leak pressure. *If this is the case, there are places that will bore the cylinder and sleeve it with either stainless steel or brass. *It's done all the time for old cars. On the other hand, I don't know anything about the legality of doing that for an aircraft brake system. *And on the Gripping Hand, I would probably do it that way myself. Jim Beckman- Hide quoted text - - Show quoted text - I wouldn't let it go that long myself. I change the brake fluids (all fluids really) in my bike every year. It's the water accumulated in the automotive brake fluid that causes the corrosion that kills the cylinders. |
"Jim Beckman" wrote in message ... This thread started with the necessity of replacing the brake master cylinder, right? Did anyone mention why it needed replacement? My first guess is wear or corrosion in the cylinder bore causing it to leak pressure. If this is the case, there are places that will bore the cylinder and sleeve it with either stainless steel or brass. It's done all the time for old cars. On the other hand, I don't know anything about the legality of doing that for an aircraft brake system. And on the Gripping Hand, I would probably do it that way myself. Jim Beckman One shop that does a good job with this is: http://www.brakecylinder.com/ Part of the problem, as has been posted before, is that DOT brake fluids are hygroscopic. If brake parts are aluminum, then water in the fluid can promote corrosion. Anodizing the aluminum parts, or sleeving them in the case of caliper housings, can help prevent this. To test to see if a given part is anodized, say a piston from a caliper, touch the part with the leads from a ohm meter (digital meter set on ohms). The anodize layer is an insulator and won't conduct. bumper QV and MKII |
This thread started with the necessity of replacing the brake master cylinder, right? Did anyone mention why it needed replacement? My first guess is wear or corrosion in the cylinder bore causing it to leak pressure. If this is the case, there are places that will bore the cylinder and sleeve it with either stainless steel or brass. It's done all the time for old cars. On the other hand, I don't know anything about the legality of doing that for an aircraft brake system. And on the Gripping Hand, I would probably do it that way myself. Jim Beckman Old cars normally have steel brake cyliders, the BMW part we are talking about is aluminium. Putting a steel or brass sleeve in will almost certainly cause corrosion (disimilar metals). A new part is available and is not expensive. All that needs to be done is to swap over the lever. |
Similar Threads | ||||
Grob 103 Twin II (non acro) manual | YFCpilots | Soaring | 1 | August 27th 08 07:40 PM |
Grob Twin III Must read! | [email protected] | Soaring | 3 | June 9th 08 07:08 AM |
Grob Twin Astir Tailshaking | Peter | Soaring | 11 | January 15th 07 12:54 AM |
looking for good brake master cyls for homebuilt. | clare @ snyder.on .ca | Aviation Marketplace | 0 | March 28th 04 05:13 AM |
Need G-103 Acro Master Cylinder | Ray Lovinggood | Soaring | 5 | September 30th 03 03:39 AM |
