Seaplane rating
Old November 28th 08, 06:49 AM posted to rec.aviation.piloting
Dallasâ„¢
Default Seaplane rating
Wouldn't a pilot flying a seaplane with only a ASEL showing in the FAA
Registry be in violation?
Dallas
Old November 28th 08, 09:03 AM posted to rec.aviation.piloting
Depends on the certification of the seaplane. If it's experimental, he
doesn't need the rating to fly solo.
Old November 28th 08, 05:23 PM posted to rec.aviation.piloting
Dallasâ„¢
On 28 Nov 2008 14:20:43 GMT, Clark wrote:
Not necessarily. The Registry is always a little out of date. The pilot could
be ASES for a couple or three months before it shows in the registry.
Ok... I was just wondering, I kept seeing Todd Palin's float plane moored
in the Palin's backyard when she was doing all those interviews. The
Registry shows him as SEL.
Dallas
Old November 28th 08, 11:31 PM posted to rec.aviation.piloting
Robert M. Gary
in the Palin's backyard when she was doing all those interviews. *The
Could be that he's signed off solo. However, I read somewhere that the
FAA estimates that about 25% of all pilots in Alaska are not properly
rated. Alaska is a long way from DC and they're not always excited to
follow regulations that are brought to them from 5,000 miles away. In
fact there is a pretty big movement of people in Alaska who want to
leave the union because they feel that DC is far too out of touch with
the realities of living in remote Alaska.
-Robert
Old November 28th 08, 11:33 PM posted to rec.aviation.piloting
BT
explain that one further please? what does experimental have to do with it?
In the USA
BT
Old November 28th 08, 11:56 PM posted to rec.aviation.piloting
Robert Moore
with it? In the USA
FAR 61.31
(k) Exceptions.
(1) This section does not require a category and class rating for aircraft
not type-certificated as airplanes, rotorcraft, gliders, lighter-than-air
aircraft, powered-lifts, powered parachutes, or weight-shift-control
aircraft.
(2) The rating limitations of this section do not apply to—
(i) An applicant when taking a practical test given by an examiner;
(ii) The holder of a student pilot certificate;
(iii) The holder of a pilot certificate when operating an aircraft under
the authority of—
(A) A provisional type certificate; or
(B) An experimental certificate, unless the operation involves carrying a
passenger;
Bob Moore
Old November 29th 08, 12:07 AM posted to rec.aviation.piloting
Maxwell[_2_]
could
-Robert
Then we should all leave the union, because they seem to be a good bit out
of touch with the realities of living just about anywhere.
FAA Registry be in violation?
he doesn't need the rating to fly solo.
In the USA
Experimentals operate under Special Airworthiness, where any
restrictions are spelled out in operating limitations. Until a few
years back, there were no limitations at all, but now they limit a pilot
without the appropriate ratings to flying solo.
It's kinda like how the FARs don't require homebuilts to have annual
inspections....
Old November 29th 08, 12:09 AM posted to rec.aviation.piloting
BT
Thanx Bob... that's a new wrinkle I had not seen..
BT
"Robert Moore" wrote in message
5.250...
with it? In the USA
FAR 61.31
(k) Exceptions.
aircraft.
(2) The rating limitations of this section do not apply to-
the authority of-
passenger;
Bob Moore
Old November 29th 08, 12:34 AM posted to rec.aviation.piloting
Morgans[_2_]
"BT" wrote in message
Although, there are ways the FAA can make it difficult for you.
At a EAA flyin, a FAA inspector guy told us that although you were not
required to have a seaplane rating for an experimental seaplane, if he was
doing the signing off the inspection before the initial test period and knew
the person going to fly it was not seaplane rated, he would likely make the
restrictions something like "only to fly on the last Tuesday in the month
after a full moon at full tide and only if the full tide maximum occurs at
2:00 PM."
You get the idea. He wanted to make sure a person flying a brand new
homebuilt was rated for the aircraft.
Jim in NC
Seaplane Base 1 - Leaving the Seaplane Base-2.jpg (1/1) john smith[_2_] Aviation Photos 2 August 2nd 07 09:37 AM
Moosehead seaplane fly-in Cub Driver Piloting 4 August 2nd 05 02:28 PM
Seaplane Rating Add-On and Seaplane Rental Peter Bauer Piloting 10 May 29th 05 12:53 PM
Seaplane Gliders Burt Compton Soaring 0 September 24th 04 02:45 PM
rotorcraft commercial rating or better rating advice Rick Cook Rotorcraft 0 October 13th 03 05:49 PM
