24 Volt starter for Chevy V8
Old January 14th 09, 11:41 PM posted to rec.aviation.homebuilt
larry
Default 24 Volt starter for Chevy V8
Thanks Charlie and root,
The whole Idea is to use a lighter cable on the run from a single
battery to the engine, to save weight and expense of heavier cable. A
24V starter should also turn the engine over more robustly. The idea
is to not have a complicated system of two 12V batteries in series and
still only run 12V all that way. A typical 24V starter uses about 100
amps and a 12V starter uses about 200 amps. So using safe wire sizing
for those amperages and total 40 ft. run, thats the difference between
#2 wire and 3-0 wire. A difference of about 15 lb. Regarding one
other idea, I would be leary of down sizing the battery cable to the
point of getting even a 10 volt drop over the run at risk of over
heating the wire.
Larry
FS: Chevy Trailblazer Tow Vehicle James Hamilton[_2_] Soaring 0 October 29th 08 08:30 PM
Chevy LS2 and Trans??? any real issues besides weight MrV Home Built 82 November 18th 05 03:11 AM
Flying the small block Chevy Bret Ludwig Home Built 13 November 12th 05 11:36 PM
PIREP: Chevy American Revolution 400, Richmond, VA John T Piloting 2 May 20th 05 06:35 PM
Chevy 4.3 L V-6 and Misbehaving Engine Control Unit Bushy Home Built 6 August 18th 03 09:33 AM
