nrp wrote:
On Jan 14, 11:22 pm, Clark wrote: wrote in news:0aed474f-8115-4575-84e4-18b6c58bb1b3 @n10g2000vbl.googlegroups.com: Greetings: It's winter here in Tennessee a question for the group: If I took a flexible Aluminim duct,/ hose hooked it up to my car exhaust pipe, then put the other end in the lower end of the engine cowling to pre- heat the aircraft's engine would this cause any problems? I would drill a small hole in the cars exhaust pipe to allow for exhaust water to escape Today's cars are very clean burning with almost zero emissions or so they say? I would not direct the exhaust at the airframe or the engine just enough to enter the cowling at the nose strut. I would open the oil door to allow a flow of exhaust. I would leave the cabin door open on the aircraft to make sure no CO2 besides, my aircraft has a CO2 detector installed. Carbonic acid isn't the problem but the nitrogen oxides and sulfur oxides combine with the water of combustion to make nitric and sulfuric acids! I assume that you do not have electricity at your aircraft otherwise a Tanis, etc preheater installed would be much better, or a modified ceramic heater with ducting. I have a Tanis that heats the oil and all four cylinders. -- Regards, Ross C-172F 180HP KSWI |
Clark writes:
Big time corrosion potential with all that water vapor and CO2. Carbonic acid is a problem with any combustion gas... Note that mufflers rust out. There's a reason why, and the exhaust gas is it. On a home furnace, you use a clay or PVC flue. [It's less of an issue when the muffler/flue gets HOT and stays hot. It's the cooler ones where the gases condense that get you..] -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
150 exhaust leack | [email protected] | Owning | 5 | October 6th 06 05:52 PM |
O290 exhaust | Ray Toews | Home Built | 0 | February 13th 05 10:14 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
YF-23 exhaust? | Sir Loin of Beef | Military Aviation | 0 | August 1st 03 04:55 AM |
Exhaust for VW motor | Andre | Home Built | 0 | July 14th 03 03:14 PM |
