Looking for some suggestions on location of Transponder antenna from
people who have them mounted on their Nimbus or DUO. Looking for area for placement of a 3rd Battery. Do you have a location that works well? Thanks in advance for the suggestions. Mark Mahan 2K |
On Feb 18, 7:06*pm, wrote:
Looking for some suggestions on location of Transponder antenna from people who have them mounted on their Nimbus or DUO. Looking for area for placement of a 3rd Battery. Do you have a location that works well? Thanks in advance for the suggestions. Mark Mahan 2K Is there a reason why you don't follow the factory TN showing a location and correct mounting/groundplane installation. Darryl |
If you don't like the factory-suggested antenna location, I know a
couple have located it on the turtle deck on the fuselage above the wing. Mike |
For Nimbus 3T & 4T see TN 825-44/831-12/863-17/868-16 (a single TN but the
numbers indicate different gliders to which it applies) This allows transponder antenna on upper fusalage. There is a different TN for Nimbus & Duo with antenna on underside of fusalage. At 03:31 19 February 2009, Darryl Ramm wrote: On Feb 18, 7:06=A0pm, wrote: Looking for some suggestions on location of Transponder antenna from people who have them mounted on their Nimbus or DUO. Looking for area for placement of a 3rd Battery. Do you have a location that works well? Thanks in advance for the suggestions. Mark Mahan 2K Is there a reason why you don't follow the factory TN showing a location and correct mounting/groundplane installation. Darryl |
Darryl,
I am aware of the factory TN. Looking to see if anyone had a solution other than an external antenna. Hate external antennas on Composite aircraft. Having worked on a lot of homebuilts, thought someone else might have come up with an alternative mount. No harm in asking. Thanks, Mark |
I have placed a Blade antenna on the top of the turtle deck as far
back as I can reach. This is about even with the trailing edge of the wing on my Nimbus 3D. I consulted a neighbor who works in an Avionics division of a local aerospace company. His comment was the placement wouldn’t matter much as there is always some angle to the interrogating station. I have placed a third battery on board solely to power the transponder. There is a Battery mount forward and to the right of the box that the landing gear retracts into. This is accessed by removing the panel behind the rear seat back. Hope this helps. Paul Cordell Scottsdale Az PS - Eric Greenwell has produced a document regarding transponders. He's used a photo of my antenna mount. Maybe he can provide a link to the document. |
On Feb 19, 9:25*am, wrote:
Darryl, I am aware of the factory TN. Looking to see if anyone had a solution other than an external antenna. Hate external antennas on Composite aircraft. Having worked on a lot of homebuilts, thought someone else might have come up with an alternative mount. No harm in asking. Thanks, Mark I think anywhere you'd want to put an antenna is carbon, so it is going on the outside. Parts of the forward fueslage may be RF transparent but you have no space to put an antenna in there and have a proper ground plane and not expose yourself to excessive RF etc. My preference would be below the fuselage if a TN allows this. Darryl |
On Feb 19, 10:25*am, wrote:
Hate external antennas on Composite aircraft. Having worked on a lot of homebuilts, thought someone else might have come up with an alternative mount. I won't help solve your problem but I noted that the Schleicher ASH31Mi will have a transponder antenna mounted inside the fin as standard equipment. Andy |
I ordered my ASG-29 pre-wired for a transponder (including antenna)
and was surprised to get a metal external antenna near the main gear instead of inside the fin. If nothing else I could have used the additional weight in the tail! 2NO |
On Feb 19, 2:55*pm, Tuno wrote:
I ordered my ASG-29 pre-wired for a transponder (including antenna) and was surprised to get a metal external antenna near the main gear instead of inside the fin. If nothing else I could have used the additional weight in the tail! 2NO The ASH-31Mi is the first glider I have noticed Schleicher have offered this on. Did they ever talk about it being an option on the ASG-29? I'm curious what is inside the fin and how well this will work in practice. Darryl |
| Transponder Antenna | Rick Fuller | Soaring | 6 | January 30th 08 07:03 PM |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| Nav Antenna Placement | Jim Pensinger | Home Built | 7 | October 4th 04 10:55 PM |
| Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 09:59 PM |
| Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 04:32 AM |
