![]() "Mike Noel" wrote in message ... I added the sender immediately to my block list. There are too many other things to worry about these days to give such comments serious consideration. Good point. -- Jim in NC |
I see no good deed goes unpunished around here.
{;-) Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Rip" wrote in message ... RST Engineering wrote: We wrote up one in a Kitplanes article several years ago. We also (as I vaguely remember) offered to sell the parts for our cost ($15 or so), kitted up a dozen of them, but didn't get any takers. One of them is yours for a SASE. Jim SPAM! Take it to r.a.marketplace, Jim. Trying to unload your useless castoffs doesn't qualify as as "owner" assistance. |
![]() "RST Engineering" wrote in message m... I see no good deed goes unpunished around here. ...or untrolled. Vaughn (my spell checker is going to hate this post) |
Don't pay attention to some of these idiots contributing nothing informative to the newsgroup. You have contributed much and alot of us appreciate it. I've been flying since 1980 and enjoy reading the different post. Normally I just read and stay in the background and not say much but I wanted you to know that your an asset to the group. It doesn't take long to figure out the people that have a real interest in sharing information, learning and contributing to the group in a positive way. The others - thats why we have "kill files". Just hit "ignore sender" and their gone forever. ![]() Terry N6401F "RST Engineering" wrote in message m... I see no good deed goes unpunished around here. {;-) |
Yes, on a Warrior with wingtip lights...
........fab reconition system... I think what you are seeing at Spruce is the "Pulsar" by AvTek.. Ours works as advertised, connectiig it in the Archer switch panel is a bitc--, but doable. ......great factory suport if you should need it from AvTek... We have the dual mosfet flasher, pulsing the 2 tip lights together , alternating with the nose light. Tower has ID'ed us at 22 miles at night , 5+ miles on a bright day... Dave On Tue, 10 Mar 2009 11:20:35 -0700, "Mike Noel" wrote: I like the visibility of the flashing landing light...they really get your attention. The Pulsar unit sold by Spruce for about $320 (single light, mosfet, variable speed) is the only one I've seen advertised. They say 30 minute install for an under panel mount. They also say you simply need to put two wires onto the landing light switch (the third wire goes I don't remember where). I can't imagine doing anything at the switch pane in an Archer would be easy. Has anyone installed one? |
Yes, on a Maule with wingtip lights. I orginally had the pre Mosfet
flashers with the distinctive clicks when the lights flashed. The Maule had one switch for two lights, had to change that out and rewire it for two switches, one for each light. Each light had to be on its own circuit in order for the pulsar to switch back and forth. Mike at Avtek helped greatly with that. Avtek offered previous owners a discount upgrade to the Mosfet, which among other things; allows the higher wattage bulbs. The upgrade was easy to put in since Mike speced out quick disconnects the first time around. There is another brand called pulselite for double the money (or more). It routinely burned out the landing light bulbs on a friends C182 and was not speed selectable. YMMV. Regards, Watson "Dave" wrote in message ... Yes, on a Warrior with wingtip lights... .......fab reconition system... I think what you are seeing at Spruce is the "Pulsar" by AvTek.. Ours works as advertised, connectiig it in the Archer switch panel is a bitc--, but doable. .....great factory suport if you should need it from AvTek... We have the dual mosfet flasher, pulsing the 2 tip lights together , alternating with the nose light. Tower has ID'ed us at 22 miles at night , 5+ miles on a bright day... Dave On Tue, 10 Mar 2009 11:20:35 -0700, "Mike Noel" wrote: I like the visibility of the flashing landing light...they really get your attention. The Pulsar unit sold by Spruce for about $320 (single light, mosfet, variable speed) is the only one I've seen advertised. They say 30 minute install for an under panel mount. They also say you simply need to put two wires onto the landing light switch (the third wire goes I don't remember where). I can't imagine doing anything at the switch pane in an Archer would be easy. Has anyone installed one? |
I installed AvTek's Pulsar on our Pathfinder a couple of years ago. It
works great in conjunction with our wingtip landing lights, wig-wagging them so that we look like a 737 on short final. AvTek's owner (Mike Peter) is fantastic to work with. We managed to hook it up backwards and blew out the mosfet circuitry. No problem -- mailed it back to Mike, he repaired and mailed it back -- no charge. He's truly one of the good guys in GA, and he caters to Cherokee owners. (By the way -- contact him directly through his website -- he'll beat that $320 price by a long ways.) Although it sounds like you got the best deal of all from Jim -- it's hard to beat free! :-) Forget that "30 minutes to install" stuff. Mine said TWENTY minutes on the packaging -- and it took more like half a day. Any time you try to do ANYTHING behind the panel of a 30+ year old Cherokee, it's a cluster f*ck, and hooking these *******s up means connecting little-bitty wires to the back-side of the landing light switch. That, my friend, is no fun at all, unless you have teeny-tiny fingers and don't mind doing a 30-minute half-sit-up while working 14 inches from your face with cruddy lighting. Still, it was well worth the effort. We hear from controllers and other traffic about how noticeable we are -- and that's what it's for. -- Jay Honeck Iowa City, IA Pathfinder N56993 Ercoupe N94856 www.AlexisParkInn.com "Your Aviation Destination" |
Thanks to everyone for the feedback. I'll post my own experiences when I
get the flasher circuit built and installed. -- Best Regards, Mike. http://flickr.com/photos/mikenoel/ "Jay Honeck" wrote in message news:OiXul.612068$yE1.503051@attbi_s21... I installed AvTek's Pulsar on our Pathfinder a couple of years ago. It works great in conjunction with our wingtip landing lights, wig-wagging them so that we look like a 737 on short final. AvTek's owner (Mike Peter) is fantastic to work with. We managed to hook it up backwards and blew out the mosfet circuitry. No problem -- mailed it back to Mike, he repaired and mailed it back -- no charge. He's truly one of the good guys in GA, and he caters to Cherokee owners. (By the way -- contact him directly through his website -- he'll beat that $320 price by a long ways.) Although it sounds like you got the best deal of all from Jim -- it's hard to beat free! :-) Forget that "30 minutes to install" stuff. Mine said TWENTY minutes on the packaging -- and it took more like half a day. Any time you try to do ANYTHING behind the panel of a 30+ year old Cherokee, it's a cluster f*ck, and hooking these *******s up means connecting little-bitty wires to the back-side of the landing light switch. That, my friend, is no fun at all, unless you have teeny-tiny fingers and don't mind doing a 30-minute half-sit-up while working 14 inches from your face with cruddy lighting. Still, it was well worth the effort. We hear from controllers and other traffic about how noticeable we are -- and that's what it's for. -- Jay Honeck Iowa City, IA Pathfinder N56993 Ercoupe N94856 www.AlexisParkInn.com "Your Aviation Destination" |
Mike ... I've got some work that is going to keep me out of commission for
about a week. I haven't gotten your SASE yet and I'm about to start that week. Don't think I've forgotten about you. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Mike Noel" wrote in message ... Thanks to everyone for the feedback. I'll post my own experiences when I get the flasher circuit built and installed. -- Best Regards, Mike. http://flickr.com/photos/mikenoel/ "Jay Honeck" wrote in message news:OiXul.612068$yE1.503051@attbi_s21... I installed AvTek's Pulsar on our Pathfinder a couple of years ago. It works great in conjunction with our wingtip landing lights, wig-wagging them so that we look like a 737 on short final. AvTek's owner (Mike Peter) is fantastic to work with. We managed to hook it up backwards and blew out the mosfet circuitry. No problem -- mailed it back to Mike, he repaired and mailed it back -- no charge. He's truly one of the good guys in GA, and he caters to Cherokee owners. (By the way -- contact him directly through his website -- he'll beat that $320 price by a long ways.) Although it sounds like you got the best deal of all from Jim -- it's hard to beat free! :-) Forget that "30 minutes to install" stuff. Mine said TWENTY minutes on the packaging -- and it took more like half a day. Any time you try to do ANYTHING behind the panel of a 30+ year old Cherokee, it's a cluster f*ck, and hooking these *******s up means connecting little-bitty wires to the back-side of the landing light switch. That, my friend, is no fun at all, unless you have teeny-tiny fingers and don't mind doing a 30-minute half-sit-up while working 14 inches from your face with cruddy lighting. Still, it was well worth the effort. We hear from controllers and other traffic about how noticeable we are -- and that's what it's for. -- Jay Honeck Iowa City, IA Pathfinder N56993 Ercoupe N94856 www.AlexisParkInn.com "Your Aviation Destination" |
Thanks for letting me know Jim. I've got lots of project to keep me busy
also. -- Best Regards, Mike. http://flickr.com/photos/mikenoel/ "RST Engineering" wrote in message m... Mike ... I've got some work that is going to keep me out of commission for about a week. I haven't gotten your SASE yet and I'm about to start that week. Don't think I've forgotten about you. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle "Mike Noel" wrote in message ... Thanks to everyone for the feedback. I'll post my own experiences when I get the flasher circuit built and installed. -- Best Regards, Mike. http://flickr.com/photos/mikenoel/ "Jay Honeck" wrote in message news:OiXul.612068$yE1.503051@attbi_s21... I installed AvTek's Pulsar on our Pathfinder a couple of years ago. It works great in conjunction with our wingtip landing lights, wig-wagging them so that we look like a 737 on short final. AvTek's owner (Mike Peter) is fantastic to work with. We managed to hook it up backwards and blew out the mosfet circuitry. No problem -- mailed it back to Mike, he repaired and mailed it back -- no charge. He's truly one of the good guys in GA, and he caters to Cherokee owners. (By the way -- contact him directly through his website -- he'll beat that $320 price by a long ways.) Although it sounds like you got the best deal of all from Jim -- it's hard to beat free! :-) Forget that "30 minutes to install" stuff. Mine said TWENTY minutes on the packaging -- and it took more like half a day. Any time you try to do ANYTHING behind the panel of a 30+ year old Cherokee, it's a cluster f*ck, and hooking these *******s up means connecting little-bitty wires to the back-side of the landing light switch. That, my friend, is no fun at all, unless you have teeny-tiny fingers and don't mind doing a 30-minute half-sit-up while working 14 inches from your face with cruddy lighting. Still, it was well worth the effort. We hear from controllers and other traffic about how noticeable we are -- and that's what it's for. -- Jay Honeck Iowa City, IA Pathfinder N56993 Ercoupe N94856 www.AlexisParkInn.com "Your Aviation Destination" |
HID landing light | [email protected] | Home Built | 2 | July 10th 08 02:50 AM |
HID Landing Light | Kyle Boatright | Home Built | 23 | February 18th 07 09:19 AM |
Landing Light Flasher Circuit | ELIPPSE | Home Built | 1 | January 12th 05 06:05 PM |
Landing light CB | Hankal | Piloting | 15 | August 30th 04 08:32 PM |
Landing light | Hankal | Aviation Marketplace | 0 | July 14th 04 01:23 AM |
