On Mar 14, 3:10*am, Ron Wanttaja wrote:
wrote: How about this:http://tinyurl.com/b4ocs3 That actually shows promise....This pump you've found might in fact be made of fuel tolerant material since it's marketed as a fuel specific pump. It's cheap, simple, lightweight... I'm going to have to get my hands on one and check it out. *Thanks for bringing it to my attention. *I was ready to give in and go electric but this would be great if it checks out., Go ahead and give it a shot (since it's cheap enough), but it looks like the one I bought at Cabella's a year or so ago for tanking up my Fly Baby. *Leaked like a sieve. *Gave up on it within 15 seconds. A friend of mine used a marine bilge pump for years to fill his T-18, AFAIK, he didn't have any problems with it. *This looks like what he was using: http://www.go2marine.com/product.do?no=86244F They've even got an all-aluminum model for about a hundred bucks mo http://www.thebosworthco.com/product...-H&Num=&S=1483 The manufacturer claims the pumps do not react to gasoline, but do not recommend them for transferring fuel. Ron Wanttaja Thanks Ron, I've been wondering where all the marine pumps were hiding! These still seem a little large. I once saw a tiny little wobble pump in a mooney mite that was exactly what I need. No luck sourcing those however... |
wrote in message ... On Mar 14, 3:10 am, Ron Wanttaja wrote: wrote: How about this:http://tinyurl.com/b4ocs3 That actually shows promise....This pump you've found might in fact be made of fuel tolerant material since it's marketed as a fuel specific pump. It's cheap, simple, lightweight... I'm going to have to get my hands on one and check it out. Thanks for bringing it to my attention. I was ready to give in and go electric but this would be great if it checks out., Go ahead and give it a shot (since it's cheap enough), but it looks like the one I bought at Cabella's a year or so ago for tanking up my Fly Baby. Leaked like a sieve. Gave up on it within 15 seconds. A friend of mine used a marine bilge pump for years to fill his T-18, AFAIK, he didn't have any problems with it. This looks like what he was using: http://www.go2marine.com/product.do?no=86244F They've even got an all-aluminum model for about a hundred bucks mo http://www.thebosworthco.com/product...-H&Num=&S=1483 The manufacturer claims the pumps do not react to gasoline, but do not recommend them for transferring fuel. Ron Wanttaja Thanks Ron, I've been wondering where all the marine pumps were hiding! These still seem a little large. I once saw a tiny little wobble pump in a mooney mite that was exactly what I need. No luck sourcing those however... -------------------------------------------------------------- What's the mission? Are you fueling an ultralite? |
What's the mission? Are you fueling an ultralite? In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. |
On Mar 14, 9:56*pm, Brian Whatcott wrote:
wrote: ------------------------------------------------------- What's the mission? Are you fueling an ultralite? In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. That suggests a minimum transfer rate of a pint a minute would be needed to keep up with the greatest conceivable flow - but a gallon a minute would do nicely? Brian W Header tank is 16 gal. After that has gone down to 10 the aux fuel can be sent to it. That allows approximately 2 hours to transfer the 6 aux gallons to the main (allowing for half hour reserve). Not that I want to do it that slowly. Actually, for optimal CG it would be nice to send the aux up when the main is down to reserve so that would require a much faster rate. |
In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. Do you have an electrical system? If so how about one of the "clicker" pumps like the Cherokee uses. They are made in uncertified versions that are quite cheap. The Ercoupe O-200 engine installation STC uses one of the uncertified versions to pump from the wing tanks to the header tank. If you have C-75 or 85 why not fit an engine driven pump? Cheers: Paul N1431A KSDM |
On Mar 15, 11:49*am, "Tri-Pacer" wrote:
In flight transfer of fuel from aux tank to main header tank in a Bowers Fly Baby. Do you have an electrical system? If so how about one of the "clicker" pumps like the Cherokee uses. They are made in uncertified versions that are quite cheap. The Ercoupe O-200 engine installation STC uses one of the uncertified versions to pump from the wing tanks to the header tank. If you have C-75 or 85 why not fit an engine driven pump? Cheers: Paul N1431A KSDM electrical system is gel cell. Engine is A75 Thinking about this pump. Half a pound and $35 http://www.sigmfg.com/cgi-bin/dpsmar...883.html?E+Sig |
| Thread Tools | |
| Display Modes | |
| Fuel transfer pump | rmhou at yahoo.com | Home Built | 8 | August 20th 07 02:35 AM |
| Trailer tow vehicle fuel pumps | Steve Leonard | Soaring | 2 | March 4th 07 10:35 PM |
| Trailer tow vehicle fuel pumps | Bill Daniels | Soaring | 15 | March 4th 07 04:59 PM |
| Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 06:53 PM |
| Fuel Transfer Placards | Ben Smith | Owning | 22 | October 16th 03 03:32 PM |
