Suppose your tow plane has a placard that says "Max Glider or Banner
Weight: 1000 lbs." You are going to tow a glider with a max gross weight of 1000 pounds. Are you supposed to limit the tensile strength of the tow rope used to 1000 lbs? The regulation specifies that the tow rope should be no less than 80 percent and no greater than 200 percent of the max towed weight. This would allow you to use a rope that has a strength of 2000 pounds but wouldn't that endanger the towing aircraft which has the placarded 1000 pound limit? Would you use a weaker tow rope or a weak link or would you just tow the 1000 pound glider with the rated 2000 pound rope? |
On Apr 12, 9:18*am, 150flivver wrote:
Suppose your tow plane has a placard that says "Max Glider or Banner Weight: *1000 lbs." *You are going to tow a glider with a max gross weight of 1000 pounds. *Are you supposed to limit the tensile strength of the tow rope used to 1000 lbs? *The regulation specifies that the tow rope should be no less than 80 percent and no greater than 200 percent of the max towed weight. *This would allow you to use a rope that has a strength of 2000 pounds but wouldn't that endanger the towing aircraft which has the placarded 1000 pound limit? *Would you use a weaker tow rope or a weak link or would you just tow the 1000 pound glider with the rated 2000 pound rope? It would be worthwhile to look at the origin of the placard to determine what it really means. Example. Schweizer hooks for many applications have a maximum rope strength specified of 1200 lb. This effectively limits the max weight of the glider to be towed to 1500 lb based on min rope strength of 80% of max gross weight of the glider.. The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH |
On Apr 13, 8:01*am, wrote:
It would be worthwhile to look at the origin of the placard to determine what it really means. Example. Schweizer hooks for many applications have a maximum rope strength specified of 1200 lb. This effectively limits the max weight of the glider to be towed to 1500 lb based on min rope strength of 80% of max gross weight of the glider.. The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH So in your example, a Schweizer hook is limited to 1200 lbs and it would be acceptable to tow a 1500 lb glider as long as the rope (or weak link setup) was rated at 1200 lbs? |
The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH So in your example, a Schweizer hook is limited to 1200 lbs and it would be acceptable to tow a 1500 lb glider as long as the rope (or weak link setup) was rated at 1200 lbs? Unfortunately, the wording on the placard doesn't refer to rope strength limits, but to maximum glider weight. If it referred to rope strength, I could see it being legal to tow a 1500 lb. glider by using a 1200 lb setup but because it specifies a max gross weight for the glider/banner, wouldn't anything heavier exceed the legal limit? |
I am trying to find (remember) the standard formula for tow pressure on the
tow line in a standard smooth tow. I forget if it is weight of the glider divided by L/d or a percentage of L/d. Initial tow pull to get rolling, is high drag on the line. I can tell when the skid comes up on the 2-33 or when the 2-33/Grob/Janus break ground. The reduction in rolling resistance can be felt in the tow plane, even on a paved runway. We never notice a 1-26 on tow. Unless the weak link has been further weakened by use, we normally don't break the link for training slack line recoveries. We have a Standard Schweizer tow set up on our Pawnee and it is placarded to 1200# Max. Our weak links are to the about the 1000# configuration to fit the 80-200% CFR requirement for most of our gliders. We routinely tow one glider at about 1500# with no issues. This glider POH specifies a weak link tolerance higher than our standard links and CFRs. We have a special weak link for that one and still stay within the 1200# max. Yes the Tow rating is limited to being able to effect a release if it had the max pressure holding mechanism, as in the case of the glider kiting and lifting the Pawnee tail. B "150flivver" wrote in message ... On Apr 13, 8:01 am, wrote: The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH So in your example, a Schweizer hook is limited to 1200 lbs and it would be acceptable to tow a 1500 lb glider as long as the rope (or weak link setup) was rated at 1200 lbs? Unfortunately, the wording on the placard doesn't refer to rope strength limits, but to maximum glider weight. If it referred to rope strength, I could see it being legal to tow a 1500 lb. glider by using a 1200 lb setup but because it specifies a max gross weight for the glider/banner, wouldn't anything heavier exceed the legal limit? |
the max pressure holding mechanism, as in the case of the glider kiting and lifting the Pawnee tail. I can't remember the name of the company right now, but they are making SGS style tow hooks that will release under considerably more pressure than std SGS hook. It has precision bearings in it where the SGS is just plain metal on metal so the release friction is reduced by multitudes of force. -Paul |
On Apr 13, 8:06*pm, sisu1a wrote:
Yes the Tow rating is limited to being able to effect a release if it had the max pressure holding mechanism, as in the case of the glider kiting and lifting the Pawnee tail. I can't remember the name of the company right now, but they are making SGS style tow hooks that will release under considerably more pressure than std SGS hook. It has precision bearings in it where the SGS is just plain metal on metal so the release friction is reduced by multitudes of force. -Paul well Spruce has'm but they're not STC'd... (hook at bottom of page) http://www.aircraftspruce.com/catalo...towBanners.php -Paul |
On Apr 14, 2:23*pm, "BT" wrote:
I am trying to find (remember) the standard formula for tow pressure on the tow line in a standard smooth tow. I forget if it is weight of the glider divided by L/d or a percentage of L/d. Well, yes, for straight and level flight at constant speed it would be the weight of the glider divided by the L/D of the glider at that speed. So if it's 400 kg and 40:1 then the tow force is 10 "kg" (not a proper SI unit of force), or about 100 N. But if you're climbing then you also need to look at the climb angle. Technically you'll want the sine of the climb angle times the weight of the glider but for real world tugs it'll be plenty close enough to use: (rate of climb / tow speed) * weight of the glider Making sure of course that the first two are in the same units e.g. both in knots or both in fpm or whatever. So, for example if you tow the above 400 kg glider at 70 knots at a rate of climb of 700 fpm (7 knots) then you've got another 40 kg or 400 N of tension on the rope from that, for a total of 50 kg of tension. Plus, as you point out, if you're accelerating then you need to take that into account as well, but once you're into a steady climb you're obviously not. |
On Apr 13, 9:32*am, 150flivver wrote:
On Apr 13, 8:01*am, wrote: The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH So in your example, a Schweizer hook is limited to 1200 lbs and it would be acceptable to tow a 1500 lb glider as long as the rope (or weak link setup) was rated at 1200 lbs? Unfortunately, the wording on the placard doesn't refer to rope strength limits, but to maximum glider weight. *If it referred to rope strength, I could see it being legal to tow a 1500 lb. glider by using a 1200 lb setup but because it specifies a max gross weight for the glider/banner, wouldn't anything heavier exceed the legal limit? To repeat myself another way: You should look through the records for the aircraft and determine where the limit on the placard came from. It may be as simple as someone putting their own saftey factor on top of one established by the hook supplier. A 1000 lb limit seems really low. This would preclude towing most 2 seaters including 2-33's(1040 gross wt). Having determined origin, it can be either corrected, or if not, consider a hook installation more suitable for your needs. If it is someone's home made hook, it may be placarded that way because it was only tested to that force when it was installed. AC 43-13 specifies these testing requirements and is commonly used as method of compliance by banner tow guys. The placard you describe mentioning both makes me suspect this could be the case. If it is not a commonly used glider tow hook(Schweizer type or Tost), I would seriously consider going to a proven glider tow hook which has been demonstrated to work at the expected loads and proven to release when you need it to. FWIW- the highest loads I've experienced have all been from hanging the rope in the trees and getting the "big yank". Good Luck UH |
On Apr 14, 7:32*am, wrote:
On Apr 13, 9:32*am, 150flivver wrote: On Apr 13, 8:01*am, wrote: The basis of this specification, if I recall correctly, was force on the release handle. Rope strength is specified with limits related to the max certified gross weight of the glider being towed, that is NTL .80 of gross wt and NGT than 2.0 times gross wt. Weak links can be used, as appropriate to saty within these limits. If the approved installation of the tow hook has other limits, they are in addition to those related to the glider defined limits. If you are using a hook not produced for towing gliders(there are lots of home made banner towing hooks made to AC 43-13 which may not be suitable for glider towing), consider moving to a proven tow hook installation. Good Luck UH So in your example, a Schweizer hook is limited to 1200 lbs and it would be acceptable to tow a 1500 lb glider as long as the rope (or weak link setup) was rated at 1200 lbs? Unfortunately, the wording on the placard doesn't refer to rope strength limits, but to maximum glider weight. *If it referred to rope strength, I could see it being legal to tow a 1500 lb. glider by using a 1200 lb setup but because it specifies a max gross weight for the glider/banner, wouldn't anything heavier exceed the legal limit? To repeat myself another way: You should look through the records for the aircraft and determine where the limit on the placard came from. It may be as simple as someone putting their own saftey factor on top of one established by the hook supplier. A 1000 lb limit seems really low. This would preclude towing most 2 seaters including *2-33's(1040 gross wt). Having determined origin, it can be either corrected, or if not, consider a hook installation more suitable for your needs. If it is someone's home made hook, it may be placarded that way because it was only tested to that force when it was installed. AC 43-13 specifies these testing requirements and is commonly used as method of compliance by banner tow guys. The placard you describe mentioning both makes me suspect this could be the case. If it is not a commonly used glider tow hook(Schweizer type or Tost), I would seriously consider going to a proven glider tow hook which has been demonstrated to work at the expected loads and proven to release when you need it to. FWIW- the highest loads I've experienced have all been from hanging the rope in the trees and getting the "big yank". Good Luck UH Are any hooks rated to more than 1200 pounds? |
| Fiberglass cloth weight vs 'finished' weight | Fred the Red Shirt | Home Built | 12 | April 5th 08 05:24 PM |
| Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 10:26 PM |
| ILS DME strength? | Jim Burns | Instrument Flight Rules | 10 | November 3rd 05 12:10 AM |
| Tubing strength | Ernest Christley | Home Built | 0 | January 17th 04 12:43 AM |
| Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 05:20 AM |
