I need to acquire a dolly capable of recovering a typical general
aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug. Any ideas? |
A sturdy mechanics creeper? not a cheap wood one that would sag.
move slowly "John" wrote in message ... I need to acquire a dolly capable of recovering a typical general aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug. Any ideas? |
I assume you are planning to use a jack to raise the wheel with the flat? The creeper concept is ok, but the first problem is the weight. You need to expect 1000 lb per wheel for a single (Bonanza). Sure, the passengers will be out, but the plane may be full of fuel and baggage. The wheels on a creeper or on the dollies sold at Home Depot are another issue. Even if they could take the weight, they are just too small for cracked taxiways. I recently moved a 650 lb grand piano and bought my supplies from Movers Supply House in the Bronx. They sell a variety of dollies under $150. There are also piano mover dollies designed for outdoor use, including some with air tires. I would investigate those, too. Good luck. -John BT wrote: A sturdy mechanics creeper? not a cheap wood one that would sag. move slowly "John" wrote in message ... I need to acquire a dolly capable of recovering a typical general aviation aircraft with a flat tire. I would like something that I can just place the flat tire wheel assembly onto without removing wheel pants or brakes. It also needs to be capable of being towed up to a mile using only one tug. Any ideas? |
"John T" wrote in message news:1IlHl.1340$io.136@llnews... I assume you are planning to use a jack to raise the wheel with the flat? The creeper concept is ok, but the first problem is the weight. You need to expect 1000 lb per wheel for a single (Bonanza). Sure, the passengers will be out, but the plane may be full of fuel and baggage. The wheels on a creeper or on the dollies sold at Home Depot are another issue. Even if they could take the weight, they are just too small for cracked taxiways. http://www.northerntool.com/webapp/w...5530_200365530 Wheels are 3" -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate |
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote Wheels are 3" I have found you need at least 6" wheels to be used on outdoor pavement, with heavy loads. I suggest air filled wheelbarrow wheels, 4 of them mounted on the sides of two pieces of angle iron, with the bottom of the angles extended wide enough for the wheel to sit on an inch or so off the ground. -- Jim in NC |
Here's a design that I've been mulling over. Since I don't have the
ability to weld something up, I was considering a double thickness of 3/4" pressure treated plywood. If you can get a 2' x 4' piece, then cut it in half and glue/screw the two together to get a 2' x 2' slab of plywood that's 1 1/2" thick. Then mount 4 of something like these: http://www.northerntool.com/webapp/w...029422_1029422 using through-bolts, fender washers and locknuts. You'd get approx 1200' capacity with not too much cost. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
These?
http://www.harborfreight.com/cpi/cta...emnumber=93368 "Jay Masino" wrote in message ... Here's a design that I've been mulling over. Since I don't have the ability to weld something up, I was considering a double thickness of 3/4" pressure treated plywood. If you can get a 2' x 4' piece, then cut it in half and glue/screw the two together to get a 2' x 2' slab of plywood that's 1 1/2" thick. Then mount 4 of something like these: http://www.northerntool.com/webapp/w...029422_1029422 using through-bolts, fender washers and locknuts. You'd get approx 1200' capacity with not too much cost. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
I bet those tiny wheels would be a bear to push around on asphalt
runways/taxiways/ramps. Also, I wonder if the wheel arc would cause a problem... you'd definitely need to remove any wheel pants. Dan D wrote: These? http://www.harborfreight.com/cpi/cta...emnumber=93368 "Jay Masino" wrote in message ... Here's a design that I've been mulling over. Since I don't have the ability to weld something up, I was considering a double thickness of 3/4" pressure treated plywood. If you can get a 2' x 4' piece, then cut it in half and glue/screw the two together to get a 2' x 2' slab of plywood that's 1 1/2" thick. Then mount 4 of something like these: http://www.northerntool.com/webapp/w...029422_1029422 using through-bolts, fender washers and locknuts. You'd get approx 1200' capacity with not too much cost. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Quite a few other examples there also, including this:
http://www.harborfreight.com/cpi/cta...emnumber=94682 "Jay Masino" wrote in message ... I bet those tiny wheels would be a bear to push around on asphalt runways/taxiways/ramps. Also, I wonder if the wheel arc would cause a problem... you'd definitely need to remove any wheel pants. Dan D wrote: These? http://www.harborfreight.com/cpi/cta...emnumber=93368 "Jay Masino" wrote in message ... Here's a design that I've been mulling over. Since I don't have the ability to weld something up, I was considering a double thickness of 3/4" pressure treated plywood. If you can get a 2' x 4' piece, then cut it in half and glue/screw the two together to get a 2' x 2' slab of plywood that's 1 1/2" thick. Then mount 4 of something like these: http://www.northerntool.com/webapp/w...029422_1029422 using through-bolts, fender washers and locknuts. You'd get approx 1200' capacity with not too much cost. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Not bad. Put some 8" or larger pnematic casters on something like that, and you would have something that would work outside at an airport. With those small wheels, even a piece of pea gravel or crack in the pavement would cause one wheel to stop, piviot the assembly to the side, and tear off a wheel pant, or drop the wheel on the ground with resultant damages. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| LS4 tail dolly | Leigh | Soaring | 0 | May 30th 08 03:02 AM |
| ASK-21 - is a tail dolly necessary? | Dave Springford | Soaring | 7 | December 31st 07 09:43 AM |
| FS: ASW-24 Tail Dolly | [email protected] | Soaring | 0 | December 26th 06 03:40 PM |
| WTB: used tail dolly | David Campbell | Soaring | 5 | April 17th 06 04:19 PM |
| assembly dolly | Udo Rumpf | Soaring | 0 | April 29th 05 05:17 PM |
