Feathering an engine
Old May 6th 09, 01:19 PM posted to rec.aviation.piloting
vaughn
Default Feathering an engine
"Tim" wrote in message
m...
So you are saying if I loose power at high altitude in a fixed pitch prop
aircraft, like a Skyhawk, I will have less drag if I stop the prop, as
opposed to letting it windmill?
Yes, but with a fixed pitch prop you may or may not be able to stop the prop
by slowing down to a near stall. Once stopped, it may or may not stay
stopped at best glide speed. It would depend on the pitch of your prop, the
compression of your engine, your plane's best glide speed, the quality of
the pilot's speed control, and the phase of the moon.
Vaughn
Old May 6th 09, 05:37 PM posted to rec.aviation.piloting
Jim Logajan
Orval Fairbairn wrote:
Scott Skylane wrote:
As an aside, the drag created by a windmilling propeller, i.e. one
not feathered and attached to a dead engine, creates as much drag
as a flat plate the same size as the area of the prop arc.
Nope. The blades cannot be everywhere at once, and so the area
affected is no larger than the blade area.
YES! In aeronautical engineering analysis, a windmilling prop is
considered to be a flat disk, with drag numbers to match. Feathering
the prop greatly reduces drag.
Three answers not entirely correct, none entirely wrong - how can this be?
Because as shown by simple empirical measurements, "it depends" as
indicated in this thesis:
http://www.goshen.edu/physics/PropellerDrag/thesis.htm
(Scroll down to review figures 11 through 14 if you are in a hurry. Figure
13 label provides a summary relevant to this thread.)
As the author of that thesis noted:
"The available publications and information in the area of propeller drag
are almost non-existent, not because of any difficulties of the research
sophistication, but because of the simplicity of it. To investigate
propeller drag one does not need electronics and a large grant, one only
needs a wind tunnel and a spring for a quick measurement. Therefore, most
of the research in this field was done before articles were indexed as they
are now. It was not until I found some journals from the 1930's that I
could actually piece together trails of research."
Old May 6th 09, 06:00 PM posted to rec.aviation.piloting
True that propeller research went away around WWII, but wind turbine
research is currently a hot topic and that's what the propeller becomes
when the engine stops.
Jim Pennino
Remove .spam.sux to reply.
Engine-out procedures and eccentric forces on engine pylons Mxsmanic Piloting 18 May 26th 07 01:03 AM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
Tilt-rotor folding/feathering props. Charles Gray Military Aviation 2 June 19th 04 03:18 AM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
