Charlie wrote:
.... on most light private aircraft just how critical is the weight anyway? do you think it might be a solution in search of a problem? Stealth Pilot * * While I'd agree with that last pair of rhetorical questions if all pilots exercised some semblance of good judgment, perusal of accident records will quickly reveal how critical excess weight can be. Charlie As I recall, FARs use 170 lbs as the standard passenger weight for airline weight & balance calcs. It's been a while since I've seen many males at 170 lbs. Women at that weight can be hard to find in these parts too.... Brian W |
On Fri, 15 May 2009 08:51:47 +0000, Stealth Pilot wrote:
on most light private aircraft just how critical is the weight anyway? I agree. I would suspect that centre of gravity is more likely to cause problems than weight for light aircraft. do you think it might be a solution in search of a problem? Absolutely ![]() without this. But it's just another tool which can add to safety, and I enjoy thinking about this stuff... especially when I should be working on assignments. Like right now ![]() |
![]() "Michael" wrote in message ... On Fri, 15 May 2009 08:51:47 +0000, Stealth Pilot wrote: on most light private aircraft just how critical is the weight anyway? I agree. I would suspect that centre of gravity is more likely to cause problems than weight for light aircraft. The balance problem is not at all confined to light aircraft. Actually, I suspect the ligh aircraft are less sensitive to balance problems because of their relatively short fuselages and (usually) small capacity as a fraction of gross weight. The main advantage of heavy aircraft is that they are much more likely to have their loads planned and secured--and also calculated for all of the fuel distributions that might reasonably occur during the flight. do you think it might be a solution in search of a problem? Absolutely ![]() without this. But it's just another tool which can add to safety, and I enjoy thinking about this stuff... especially when I should be working on assignments. Like right now ![]() |
![]() "Stealth Pilot" wrote in message ... I've heard a discussion of this and the point made was that the wings are still flying while parked on the ground. in still air the system would work but with a breeze, or worse in gusts, the system may never sense the actual aircraft weight. the other problem was calibrating the weighing (certifying the thing) and finding really horizontal ground all the time. on most light private aircraft just how critical is the weight anyway? do you think it might be a solution in search of a problem? Stealth Pilot In a truly integrated aircraft, the air data computer would sense the 'levelness' of the aircraft and factor out any gust accelerations. The computer should be able to derive the weight fairly easily... |
"Dan D" wrote in message
... "Stealth Pilot" wrote in message ... I've heard a discussion of this and the point made was that the wings are still flying while parked on the ground. in still air the system would work but with a breeze, or worse in gusts, the system may never sense the actual aircraft weight. the other problem was calibrating the weighing (certifying the thing) and finding really horizontal ground all the time. on most light private aircraft just how critical is the weight anyway? do you think it might be a solution in search of a problem? Stealth Pilot In a truly integrated aircraft, the air data computer would sense the 'levelness' of the aircraft and factor out any gust accelerations. The computer should be able to derive the weight fairly easily... It is not quite that simple. The system you describe would still not eliminate the steady state component of the wind. Peter |
On 14 May 2009 10:37:08 GMT, Michael wrote: "The issue is that you need to certify the thing, or you can't use it for any flight crew annunciations. So, to certify it, you need to be able to guarantee performance. And, if you can't certify it, you can't take any credit for it being there. Still a potential safety improvement, but not nearly as cost effective as beating on the flight crew and dispatches to make sure they actually put in the real weight." I've heard a discussion of this and the point made was that the wings are still flying while parked on the ground. in still air the system would work but with a breeze, or worse in gusts, the system may never sense the actual aircraft weight. So the system could incorporate signals from strain gauges(gages?) attached to the wings and rudder. Then those forces could be included in the computation. A nice side benefit of such instrumentation is that one can view and have recorded a history of the forces on the aircraft during flights. All your landings where you had a nice squeaker (or dropped it in) precisely quantified and forever preserved, if you so desire! :-) the other problem was calibrating the weighing (certifying the thing) and finding really horizontal ground all the time. Could also incorporate a signal from a gravity attitude sensor (e.g. damped plumb bob). Can't think of any useful side benefit to that extra sensor, though. on most light private aircraft just how critical is the weight anyway? C.G. is the useful thing on all size aircraft. do you think it might be a solution in search of a problem? Some homebuilders are putting $10k++ instrument panels in their experimentals that are often expensive solutions in seach of problems, so I don't see any problem at all in experimental minded builders playing around in such an underlooked area. Compared to experimenting with things like engines, attaching sensors is a relatively benign area to experiment in. (Not entirely benign of course - e.g. one could badly place sensor wire runs that interfere with controls.) |
"JL" == Jim Logajan writes:
JL Could also incorporate a signal from a gravity attitude sensor JL (e.g. damped plumb bob). Can't think of any useful side JL benefit to that extra sensor, though. Good grief. Just average the landing gear weight data over 10 seconds or so. -- Almost all absurdity of conduct arises from the imitation of those whom we cannot resemble. ~ Samuel Johnson |
Information on Gas sensors | [email protected] | Owning | 1 | July 2nd 06 06:30 AM |
Ethanol & capacitance fuel-level sensors | Adam Aulick | Home Built | 4 | May 20th 06 03:28 PM |
effectiveness of infra red sensors at detecting aircraft | Fe | Military Aviation | 4 | June 6th 04 11:38 AM |
FS: BEI Systron Donner QRS11 GyroChip Sensors | Jup06 | Aviation Marketplace | 0 | February 11th 04 08:41 PM |
oxygen sensors for aircraft | Air Methods Corporation | Home Built | 0 | September 21st 03 07:16 PM |
