I'm at my welding table practicing welding with a new torch, and I've
found myself burning thru the metal. I've been correcting the error by filling in the metal with filler and continuing with the exercise. Can I do the same to correct a "run away hole" on real work? - Mike |
On Jun 5, 8:00*am, mhorowit wrote:
I'm at my welding table practicing welding with a new torch, and I've found myself burning thru the metal. I've been correcting the error by *filling in the metal with filler and continuing with the exercise. Can I do the same to correct a "run away hole" on real work? - Mike There are certainly better welder than me on this group to advise you but I'll give it a try. Possibilities: 1. Your gas pressure is too high and you are blowing holes in the metal. Try using a smaller flame and working slower. 2. You aren't quick enough in pulling the flame back when you see the metal starting to boil and spark. If you see that, the heat needs to be reduced NOW. The only way to quickly reduce heat is remove the flame. Learning to weld it fun if a little frustrating. It brings out the inner child - with pyromaniacal tendencies. |
On Jun 5, 10:18*am, bildan wrote:
On Jun 5, 8:00*am, mhorowit wrote: I'm at my welding table practicing welding with a new torch, and I've found myself burning thru the metal. I've been correcting the error by *filling in the metal with filler and continuing with the exercise.. Can I do the same to correct a "run away hole" on real work? - Mike There are certainly better welder than me on this group to advise you but I'll give it a try. Possibilities: 1. Your gas pressure is too high and you are blowing holes in the metal. *Try using a smaller flame and working slower. 2. You aren't quick enough in pulling the flame back when you see the metal starting to boil and spark. *If you see that, the heat needs to be reduced NOW. *The only way to quickly reduce heat is remove the flame. Learning to weld it fun if a little frustrating. It brings out the inner child - with pyromaniacal tendencies. Thanks; any idea if I can "fill in my gaps" when off the practice table? - Mike |
On Jun 5, 8:31*am, Mike wrote:
On Jun 5, 10:18*am, bildan wrote: On Jun 5, 8:00*am, mhorowit wrote: I'm at my welding table practicing welding with a new torch, and I've found myself burning thru the metal. I've been correcting the error by *filling in the metal with filler and continuing with the exercise. Can I do the same to correct a "run away hole" on real work? - Mike There are certainly better welder than me on this group to advise you but I'll give it a try. Possibilities: 1. Your gas pressure is too high and you are blowing holes in the metal. *Try using a smaller flame and working slower. 2. You aren't quick enough in pulling the flame back when you see the metal starting to boil and spark. *If you see that, the heat needs to be reduced NOW. *The only way to quickly reduce heat is remove the flame. Learning to weld it fun if a little frustrating. It brings out the inner child - with pyromaniacal tendencies. Thanks; any idea if I can "fill in my gaps" when off the practice table? - Mike I assume you mean "fill in the holes". I add a little fill metal, back off and let it solidify (not cool - keep it red/orange). Repeat by adding fill metal in small amounts until the hole is filled. BTW, my welding instructor taught me the circular motion of the torch but not the in and out motion needed to control melt puddle temperature. I had to learn that myself. I think temperature control is the real secret to gas welding. If you need to go in too close with the torch to get the right temperature, you need a larger flame or bigger tip. If you need to be too far away, you need a smaller flame or smaller tip. I like to work with the torch about 1/2" from the puddle when working 1/16" thick metal. |
| Thread Tools | |
| Display Modes | |
| Welding question - | Michael Horowitz | Restoration | 11 | September 7th 06 04:52 PM |
| Welding question 2 | Bill Daniels | Home Built | 11 | June 10th 06 02:48 AM |
| Welding question: 43-13-1B, Fig.4-43 | Mike | Restoration | 0 | May 15th 06 03:36 PM |
| Welding question | Mike | Restoration | 4 | February 20th 06 03:23 PM |
| Welding question | Michael Horowitz | Home Built | 1 | October 13th 05 10:53 PM |
