You need to be VERY careful about investing in the PADS600 UAT receiver.
The ITT ADS-B ground stations that are currently being deployed nationwide will only transmit traffic and weather data in response to receiving an ADS-B out interrogation from an ADS-B UAT equipped aircraft. They do not transmit this data continuously. As a result, the PADS600 will only receive this data when it is listening in on data being sent to other aircraft. If you want reliable traffic and weather data via ADS-B, you need to invest in an ADS-B transceiver that supports both ADS-B In and Out functionality. Mike Schumann "Darryl Ramm" wrote in message ... On Jun 21, 10:23 am, "Mike Schumann" mike-nos...@traditions- nospam.com wrote: One note of caution about relying too much on TCAS for collision avoidance. TCAS was designed as the last line of defense against collisions when all else fails. It is NOT designed for use as the primary way to avoid collisions. Unfortunately, given current FAA ATC procedures, this is the way it is currently being used. One of the problems with TCAS and gliders is that the TCAS logic is designed for typical aircraft. As a result, TCAS is assuming that targets are traveling in a relatively straight trajectory. Gliders don't do this, so the TCAS RA may generate advice that actually creates a collision. If you are really serious about minimizing the threat of collisions, you also need a device that will show you where the other traffic is. If you are in an area where there are ADS-B ground stations, an ADS-B UAT transceiver is definitely the way to go. If you look at the FAA web site, you will see that there currently is ground station coverage on the entire east coast, in southern Florida, and in other isolated other areas of the US. By next summer, there should be a major expansion of the ground station coverage, with most of the US covered by 2011. If you are not in an area with ADS-B coverage, a PCAS type of device is an alternative. Mike Schumann [snip] If all you want is TIS-B traffic information then a Mode-S transponder can get you traffic data, provide TCAS compatibiiey, and also compatibility with PCAS systems used in some gliders and GA aircraft. I know Mike knows all this, that comment is to make it clear to others. TCAS is the absolute last defence and for high-traffic jet/airline areas I just hope people will not think a glider would be better off with ADS-B TIS-B traffic data *instead* of a transponder that provides visibility to TCAS equipped jets. While there are arguments about TCAS RA predictions, the RA are based on altitude and jet traffic can climb or descend rapidly when needed and the TCAS will monitor what is happening as the threat target converge. This is not a satisfactory answer but I just worry that many readers might thing that TCAS is doing some sophisticated track avoidance and therefore a glider maneuvering might cause far more complexity than the altitude based avoidance that actually happens. Being primarily altitude based makes the resolution determination a lot simpler. Gliders are also relatively slow moving, so even if maneuvering their relative location to a fast jet does not move rapidly. Gliders might change climb rates at +/- thousands of feet per minute but with altitude margins in TCAS and the continuous monitoring of altitude as targets converge probably make this less of an issue than it could be. I am not aware of any technical study that shows serious problems with gliders (or other slow traffic) and TCAS. I'd love to see any if they exist. With TCAS on TCAS targets the Mode-S transponders are communicating RA data to ensure that both aircraft are not instructed to climb etc. Since a glider won't have TCAS that won't happen, but the real issue with that is avoiding TCAS directing both the jet aircraft with high climb/descent performance to do the same thing, and the ultimate fall back here is the ability of a jet to normally out-climb or out-descent a glider even if the glider pilot decides to change altitude abruptly to avoid a collision. So again, the problem if people just relied on ADS-B UAT devices and a TIS-B traffic display is that the glider would be entirely invisible to TCAS. I would much rather have the TCAS help the fast jet avoid me than me avoid the fast jet. But ideally have both. And ADS-B TIS-B (either over UAT or 1090ES) offers more range than PCAS - one of the issues with PCAS (I fly with a Zaon MRX) is it may not have sufficient range to be useful for fast jet traffic. And even if you have a fancy TIS-B display you may still decide to make an avoidance manouvre that conflicts with what TCAS is telling the other aircraft to do. Again this would rely on the jet typically being able to out climb or out descend a glider. Had the ASG-29 flying near Reno a few years ago had a simple transponder the Hawker jet very likely would not have collided with with it. ATC hopefully would have given the Hawker a traffic advisory (but as Mike points out there is no guarantee that currently they would have since both aircraft collided outside controlled airspace), failing that the TCAS should have done its job. Likewise with another incident near Reno more recently a transponder would likely have avoided the jet pilots and ATC being "surprised" by a glider while on approach to Reno, and the subsequent hassles for all involved. BTW people wanting to see what TIS-B traffic on a UAT device might look like in a real product -- the NavWorx PADS600 receives TIS-B (and FIS-B) data, it does not do ADS-B out. See http://www.navworx.com. The receiver is currently ~$1,500 and can display traffic data on a Garmin 496 or several other types of popular GA displays. As Mike points out, this technology is quite interesting for the future. Darryl |
Transponder vs. Portable Transponder Detectors | John Murphy | Soaring | 16 | December 20th 08 07:25 AM |
forgotten trig for climb angle... | xerj | Piloting | 5 | January 29th 07 01:08 PM |
My OSH thoughts | Hilton | Piloting | 6 | August 4th 05 10:03 PM |
What are your thoughts on..... | Ben | Owning | 46 | March 23rd 04 03:50 PM |
Your thoughts on this 150 please | Paul Folbrecht | Owning | 8 | March 19th 04 02:14 AM |
