http://www.fcc.gov/Daily_Releases/Da...-09-1258A1.doc
FYI - One of our proactive members found this article about an FCC fine of $9,000 against the Texas Soaring Association (TSA) in Lubbock TX because their airport's radio license had expired. It appears what tripped this trigger was the TSA complaining to the FCC about "interference" on 123.3. Boy, did that backfire. We looked into it and my own gliderport's license had also expired - which we are *QUICKLY* fixing. You might want to look into that at your port. It is unclear to me if the license relates to 123.3, or the frequency on the sectional or a general FCC license that a particular airport is legal to broadcast, or a combination. I also don't understand if this has to do with the base station, handhelds, airplane radio or totally unrelated to the hardware being used. I do know that my own use of a radio in my glider no longer requires an individual license. I'd also like to understand what controls the use of 123.3 (or 123.5) which I have been told is for "training" use. True? By whom? The FAA? FCC? Note that the FCC complaint says that TSA complained about interference from "commercial jets inbound to Lubbock, Texas" (on 123.3) which surprised me. Any information about how the FAA/FCC handles airport licensing would be interesting. My $0.02. - John DeRosa |
Correction, TSA is located in "Midlothian, Texas, which is itself at
the southern edge of the Dallas-Fort Worth area" according to their web site http://www.texassoaring.org/. |
On Jun 24, 2:54*pm, ContestID67 wrote:
http://www.fcc.gov/Daily_Releases/Da...b0608/DA-09-12... FYI - One of our proactive members found this article about an FCC fine of $9,000 against the Texas Soaring Association (TSA) in Lubbock TX because their airport's radio license had expired. *It appears what tripped this trigger was the TSA complaining to the FCC about "interference" on 123.3. *Boy, did that backfire. We looked into it and my own gliderport's license had also expired - which we are *QUICKLY* fixing. *You might want to look into that at your port. It is unclear to me if the license relates to 123.3, or the frequency on the sectional or a general FCC license that a particular airport is legal to broadcast, or a combination. *I also don't understand if this has to do with the base station, handhelds, airplane radio or totally unrelated to the hardware being used. *I do know that my own use of a radio in my glider no longer requires an individual license. I'd also like to understand what controls the use of 123.3 (or 123.5) which I have been told is for "training" use. *True? *By whom? *The FAA? *FCC? *Note that the FCC complaint says that TSA complained about interference from "commercial jets inbound to Lubbock, Texas" (on 123.3) which surprised me. Any information about how the FAA/FCC handles airport licensing would be interesting. My $0.02. - John DeRosa AC90-50D, Aircraft Support is the FAA designated use for both. We verify our license at the first regular meeting of the newly elected board annually. Make it an order of business item for seating all new boards. IIRC ground stations licenses are good for 10 years. For those clubs not having a club house/hangar where you hold the meetings, make it a January agenda item. Frank Whiteley |
On Jun 24, 4:54*pm, ContestID67 wrote:
http://www.fcc.gov/Daily_Releases/Da...b0608/DA-09-12... FYI - One of our proactive members found this article about an FCC fine of $9,000 against the Texas Soaring Association (TSA) in Lubbock TX because their airport's radio license had expired. *It appears what tripped this trigger was the TSA complaining to the FCC about "interference" on 123.3. *Boy, did that backfire. We looked into it and my own gliderport's license had also expired - which we are *QUICKLY* fixing. *You might want to look into that at your port. It is unclear to me if the license relates to 123.3, or the frequency on the sectional or a general FCC license that a particular airport is legal to broadcast, or a combination. *I also don't understand if this has to do with the base station, handhelds, airplane radio or totally unrelated to the hardware being used. *I do know that my own use of a radio in my glider no longer requires an individual license. I'd also like to understand what controls the use of 123.3 (or 123.5) which I have been told is for "training" use. *True? *By whom? *The FAA? *FCC? *Note that the FCC complaint says that TSA complained about interference from "commercial jets inbound to Lubbock, Texas" (on 123.3) which surprised me. Any information about how the FAA/FCC handles airport licensing would be interesting. My $0.02. - John DeRosa In the name of deficit reduction, I move we shutter the FCC. -T8 |
For everybody that's always thought how do they know?
[Code of Federal Regulations] [Title 47, Volume 5] [Revised as of October 1, 2008] From the U.S. Government Printing Office via GPO Access [CITE: 47CFR87] [Page 223-224] TITLE 47--TELECOMMUNICATION CHAPTER I--FEDERAL COMMUNICATIONS COMMISSION (CONTINUED) PART 87_AVIATION SERVICES--Table of Contents Subpart K_Aviation Support Stations Sec. 87.319 Scope of service. Aviation support stations are used for the following types of operations: (a) Pilot training; (b) Coordination of soaring activities between gliders, tow aircraft and land stations; (c) Coordination of activities between free balloons or lighter- than-air aircraft and ground stations; (d) Coordination between aircraft and aviation service organizations located on an airport concerning the safe and efficient portal-to- portal transit of the aircraft, such as the types of fuel and ground services available; and (e) Promotion of safety of life and property. [[Page 224]] Sec. 87.321 Supplemental eligibility. Each applicant must certify as to its eligibility under the scope of service described above. [63 FR 68958, Dec. 14, 1998] Sec. 87.323 Frequencies. (a) 121.500 MHz: Emergency and distress only. (b) The frequencies 121.950, 123.300 and 123.500 MHz are available for assignment to aviation support stations used for pilot training, coordination of lighter-than-air aircraft operations, or coordination of soaring or free ballooning activities. Applicants for 121.950 MHz must coordinate their proposal with the appropriate FAA Regional Spectrum Management Office. The application must specify the FAA Region notified and the date notified. Applicants for aviation support land stations may request frequency(ies) based upon their eligibility although the Commission reserves the right to specify the frequency of assignment. Aviation support mobile stations will be assigned 123.300 and 123.500 MHz. However, aviation support mobile stations must operate only on a noninterference basis to communications between aircraft and aviation support land stations. (c) The frequency 122.775 MHz and, secondary to aeronautical multicom stations, the frequency 122.850 MHz are available for assignment to aviation support stations. These frequencies may be used for communications between aviation service organizations and aircraft in the airport area. These frequencies must not be used for air traffic control purposes or to transmit information pertaining to runway, wind or weather conditions. (d) The frequency 3281.0 kHz is available for assignment to aviation support stations used for coordination of lighter-than-air aircraft operations. [53 FR 28940, Aug. 1, 1988, as amended at 63 FR 68958, Dec. 14, 1998] |
Here's some more good reading about frequency allocation:
http://www.jneuhaus.com/fccindex/aviation.html |
http://www.fcc.gov/Daily_Releases/Da...b0608/DA-09-12... FYI - One of our proactive members found this article about an FCC fine of $9,000 against the Texas Soaring Association (TSA) in Lubbock TX because their airport's radio license had expired. *It appears what tripped this trigger was the TSA complaining to the FCC about "interference" on 123.3. *Boy, did that backfire. We looked into it and my own gliderport's license had also expired - which we are *QUICKLY* fixing. *You might want to look into that at your port. It is unclear to me if the license relates to 123.3, or the frequency on the sectional or a general FCC license that a particular airport is legal to broadcast, or a combination. *I also don't understand if this has to do with the base station, handhelds, airplane radio or totally unrelated to the hardware being used. *I do know that my own use of a radio in my glider no longer requires an individual license. I'd also like to understand what controls the use of 123.3 (or 123.5) which I have been told is for "training" use. *True? *By whom? *The FAA? *FCC? *Note that the FCC complaint says that TSA complained about interference from "commercial jets inbound to Lubbock, Texas" (on 123.3) which surprised me. Any information about how the FAA/FCC handles airport licensing would be interesting. My $0.02. - John DeRosa I would think that the absence of complaints against TSA for use of the frequency during the violation period would be grounds to appeal for a significant reduction in the forfeiture. Note these are proposed forfeitures. TSA is also a 501c(3) charitable organization. That means that their corporate purpose includes a defined public benefit. Said forfeiture would impact their ability to fully meet that goal, regardless of ability to pay. Frank Whiteley |
I pulled this from the FCC website:
Licensing On October 25, 1996, the FCC released a Report and Order in WT Docket No. 96-82 (text) eliminating the individual licensing requirement for all aircraft, including scheduled air carriers, air taxis and general aviation aircraft operating domestically. This means that you do not need a license to operate a two-way VHF radio, radar, or emergency locator transmitter (ELT) aboard aircraft operating domestically. I guess TSA must have a base station. I am not sure what type of license is needed for hand-held radios. Someone should contact TSA and find out the details. |
On Jun 25, 5:52*pm, "r.t.s." wrote:
I pulled this from the FCC website: Licensing On October 25, 1996, the FCC released a Report and Order in WT Docket No. 96-82 (text) eliminating the individual licensing requirement for all aircraft, including scheduled air carriers, air taxis and general aviation aircraft operating domestically. This means that you do not need a license to operate a two-way VHF radio, radar, or emergency locator transmitter (ELT) aboard aircraft operating domestically. I guess TSA must have a base station. *I am *not sure what type of license is needed for hand-held radios. Someone should contact TSA and find out the details. Did you read the link provided? That's a lot of details already. They unfortunately made two mistakes, the first was not renewing the license, the second of which was right up there with the Pegase owner asking the FAA about airframe hours and inspections. I think there is a moral here about not asking government bureaucracies for help unless you know your ass is well covered. Information on base station licensing and handhelds etc. is all documented on the FCC web site. e.g. http://wireless.fcc.gov/services/ind...craft_stations To operate a handheld or car mounted mobile etc. outside an aircraft, e.g. by a glider ground crew, you need the same license as TSA did not renew i.e. a Ground Station Authorization for Aviation Support Services. I was goign to start a submission for a handheld to see how painful that was on the FCC ULS website, but it's down for nightly maintenance... (I presume the only justification for how bad ULS is as a Web application is the development went to the lowest bidder). Darryl |
Does anyone know what the Fee is for the 10yr FCC certificate application
for a base station or mobile mount? "Darryl Ramm" wrote in message ... On Jun 25, 5:52 pm, "r.t.s." wrote: I pulled this from the FCC website: Licensing On October 25, 1996, the FCC released a Report and Order in WT Docket No. 96-82 (text) eliminating the individual licensing requirement for all aircraft, including scheduled air carriers, air taxis and general aviation aircraft operating domestically. This means that you do not need a license to operate a two-way VHF radio, radar, or emergency locator transmitter (ELT) aboard aircraft operating domestically. I guess TSA must have a base station. I am not sure what type of license is needed for hand-held radios. Someone should contact TSA and find out the details. Did you read the link provided? That's a lot of details already. They unfortunately made two mistakes, the first was not renewing the license, the second of which was right up there with the Pegase owner asking the FAA about airframe hours and inspections. I think there is a moral here about not asking government bureaucracies for help unless you know your ass is well covered. Information on base station licensing and handhelds etc. is all documented on the FCC web site. e.g. http://wireless.fcc.gov/services/ind...craft_stations To operate a handheld or car mounted mobile etc. outside an aircraft, e.g. by a glider ground crew, you need the same license as TSA did not renew i.e. a Ground Station Authorization for Aviation Support Services. I was goign to start a submission for a handheld to see how painful that was on the FCC ULS website, but it's down for nightly maintenance... (I presume the only justification for how bad ULS is as a Web application is the development went to the lowest bidder). Darryl |
| Thread Tools | |
| Display Modes | |
| Scaled Composites Space Tourism Firm Fined Over Deaths | Larry Dighera | Piloting | 16 | February 6th 08 07:01 PM |
| Lockheed Fined $3 million | Jay Honeck | Piloting | 11 | June 8th 07 08:48 PM |
| Only at a gliderport | SAM 303a | Soaring | 5 | August 18th 06 03:53 PM |
