I sold Soaring Aids Variometers many years ago (20 + years or more) they
were made by Marvin Willis in Arlington Texas..these were even then an old design but a lot of us liked them back then....always worked pretty well at the time..if you'll drop me a note I'll give you a Tel# you might try... tim -- Please visit the Wings & Wheels website at www.wingsandwheels.com "Tony Condon" wrote in message ... Tim - Easy enough I suppose. when I first got the Cherokee it had an old Crossfeld electric vario in it. the audio part didnt work. Either the flask or the battery was hooked up backwards and when I was in lift it showed down and when I was in sink it showed lift. Also, the scale was way off. The highest I ever saw was like 2 feet per second but usually it was between 1/2 and 1 fps (down) when i was in lift that was stronger than that. I actually learned how to read that old thing and got fairly good at working lift with it. -Tony Condon Cherokee II N373Y |
If the ports are on opposite sides of the case, you can hold you hand in
front of one port and walk around your house. It will show up when you block your walking speed from the static connection. You could do a similar thing by connecting a piece of tubing to it and bending it around so it points back as you walk. Again, the vario will show up when the capacity port is open to your walking dynamic pressure. This is probably safer than taking a battery, wires, and a suspicious looking package to a tall building and trying to use the express elevator to get to the top floor. Steve Leonard |
On Jul 3, 12:15*am, Steve Leonard wrote:
If the ports are on opposite sides of the case, you can hold you hand in front of one port and walk around your house. *It will show up when you block your walking speed from the static connection. You could do a similar thing by connecting a piece of tubing to it and bending it around so it points back as you walk. *Again, the vario will show up when the capacity port is open to your walking dynamic pressure. This is probably safer than taking a battery, wires, and a suspicious looking package to a tall building and trying to use the express elevator to get to the top floor. Steve Leonard You crack me up Steve! And I missed you at IVSM |
| Thread Tools | |
| Display Modes | |
| Soaring Aids Variometer | Tony Condon[_2_] | Soaring | 0 | July 2nd 09 05:00 PM |
| Hearing Aids | Casey Wilson | Piloting | 9 | February 20th 06 02:40 AM |
| Yet another case of AIDS | jsmith | Piloting | 12 | March 18th 05 02:20 AM |
| question about the state of the arts of landing aids on aircraft carriers | Charlie Wolf | Naval Aviation | 0 | March 6th 05 03:25 AM |
| AFMC pilot initiative aids test, operational worlds | Otis Willie | Military Aviation | 0 | February 19th 04 01:01 AM |
