I find the aerodynamics of fixed pitch props relatively easy to understand -
the angle of attack varies with both forward speed and RPM. However, something puzzles me about constant speed prop thrust. I realise that the blades twist to give a different pitch, and therefore when you increase MP to maintain the same RPM the blades will be at a higher helix angle. However, won't the angle of attack (calculated by the relative wind) by the same? Isn't that the idea? If the prop is at the same angle of attack, why is the thrust higher? Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) rather than simply the pitch angle? I've seen texts that say you get a bigger bite, but that doesn't seem to explain why that matters since lift is predicated on angle of attack. Anyone have a good explanation? TIA |
On Aug 18, 3:03*pm, "coriolis" wrote:
I find the aerodynamics of fixed pitch props relatively easy to understand - the angle of attack varies with both forward speed and RPM. However, something puzzles me about constant speed prop thrust. I realise that the blades twist to give a different pitch, and therefore when you increase MP to maintain the same RPM the blades will be at a higher helix angle. However, won't the angle of attack (calculated by the relative wind) by the same? Isn't that the idea? If the prop is at the same angle of attack, why is the thrust higher? Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) rather than simply the pitch angle? I've seen texts that say you get a bigger bite, but that doesn't seem to explain why that matters since lift is predicated on angle of attack. Anyone have a good explanation? TIA If you increase MP you will increase the prop's angle of attack. The governor is set by the prop control, and if it senses any RPM increase as power is increased it will increase the pitch of the blades. AoA therefore increases, thrust increases, speed increases; as speed increases the AoA drops back some but not to the former value, since the higher aircraft drag at the higher speed needs more thrust to maintain and so the prop's AoA will need to be higher to create that thrust. If it didn't change, the higher power (torque) would increase the prop RPM, as with a fixed-pitch prop. AoA on a prop can vary a lot. Common wisdom is that useful AoA will be at least 2 degrees, varying with RPM and speed up to the stall angle of the prop blade, which might be 15 to 18 degrees or so. Dan |
"coriolis" wrote in message ... I find the aerodynamics of fixed pitch props relatively easy to understand - the angle of attack varies with both forward speed and RPM. However, something puzzles me about constant speed prop thrust. I realise that the blades twist to give a different pitch, and therefore when you increase MP to maintain the same RPM the blades will be at a higher helix angle. However, won't the angle of attack (calculated by the relative wind) by the same? Isn't that the idea? If the prop is at the same angle of attack, why is the thrust higher? Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) rather than simply the pitch angle? I've seen texts that say you get a bigger bite, but that doesn't seem to explain why that matters since lift is predicated on angle of attack. Anyone have a good explanation? http://www.avweb.com/news/pelican/182082-1.html Best one I've seen. Matt |
In article , "coriolis" wrote:
I find the aerodynamics of fixed pitch props relatively easy to understand - the angle of attack varies with both forward speed and RPM. However, something puzzles me about constant speed prop thrust. I realise that the blades twist to give a different pitch, and therefore when you increase MP to maintain the same RPM the blades will be at a higher helix angle. However, won't the angle of attack (calculated by the relative wind) by the same? Isn't that the idea? If the prop is at the same angle of attack, why is the thrust higher? Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) rather than simply the pitch angle? I've seen texts that say you get a bigger bite, but that doesn't seem to explain why that matters since lift is predicated on angle of attack. Anyone have a good explanation? TIA On a fixed-pitch prop AOA reduces as airspeed increases. RPM has to increase in order to maintain a constant AOA until it reaches redline. Essentially, the variable-pitch propeller increases angle-of-attack (AOA) as speed or RPM decreases and MP remains the same. Those propellers are also a set of compromises, since their twist is set up to give maximum efficiency at a given airspeed/RPM. Deviations from those conditions reduce efficiency. You can make a simple program to map airspeed, RPM, AOA at various stations along the prop span. -- Remove _'s from email address to talk to me. |
On Aug 18, 5:03*pm, "coriolis" wrote:
isn't the angle of attack the important thing in generating lift (which is what thrust is) http://www.grc.nasa.gov/WWW/K-12/airplane/forces.html ----- - gpsman |
attack. Ok, this is where I was going wrong. Most probably by my misreading of some texts, I was under the impression that the blade would seek one particular AoA (regardless of the pitch) throughout its operating range until it hit the stops. Thanks to all who replied. |
On Wed, 19 Aug 2009 07:03:55 +1000, "coriolis"
wrote: I find the aerodynamics of fixed pitch props relatively easy to understand - the angle of attack varies with both forward speed and RPM. However, something puzzles me about constant speed prop thrust. I realise that the blades twist to give a different pitch, and therefore when you increase MP to maintain the same RPM the blades will be at a higher helix angle. you are one confused puppy. let me correct some of that text. the blade is twisted to give the same pitch at different radiuseseses. the twist is something fixed in the shape of the prop blade, for aluminium, during the forging process used to make the blade. the pitch angle is a function of the circumfrence of the circle prescribed by the radius point and the forward advance in one revolution. the pitch angle = arctan(pitch advance/circumference) typically the units are in feet. if you have the same pitch along the blade then you have a helical twist in the blade. in an inflight adjustable prop the blades rotate in the hub to change the pitch as the hub is spun through the air by the engine. you'll find it a lot easier to undersand if you use words more precisely. However, won't the angle of attack (calculated by the relative wind) by the same? Isn't that the idea? If the prop is at the same angle of attack, why is the thrust higher? Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) rather than simply the pitch angle? I've seen texts that say you get a bigger bite, but that doesn't seem to explain why that matters since lift is predicated on angle of attack. now, what dan said in another post. Stealth Pilot |
coriolis wrote:
I find the aerodynamics of fixed pitch props relatively easy to understand - the angle of attack varies with both forward speed and RPM. However, something puzzles me about constant speed prop thrust. I realise that the blades twist to give a different pitch, and therefore when you increase MP to maintain the same RPM the blades will be at a higher helix angle. However, won't the angle of attack (calculated by the relative wind) by the same? Isn't that the idea? If the prop is at the same angle of attack, why is the thrust higher? Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) rather than simply the pitch angle? I've seen texts that say you get a bigger bite, but that doesn't seem to explain why that matters since lift is predicated on angle of attack. Anyone have a good explanation? TIA I'll give this a shot: Fixed Pitch Prop: prop AoA inversely proportional to IAS prop AoA proportional to prop RPM Const Speed Prop: prop AoA inversely proportional to IAS prop AoA proportional to throttle setting & therefor shaft HP Brian W |
On Wed, 19 Aug 2009 07:03:55 +1000, coriolis wrote:
Once again, I know the pitch is higher, but isn't the angle of attack the important thing in generating lift (which is what thrust is) Thrust isn't lift. Lift is opposite weight. The forces are not with you. |
On Wed, 19 Aug 2009 15:24:04 GMT, Stealth Pilot wrote:
you are one confused puppy. let me correct some of that text. the blade is twisted to give the same pitch at different radiuseseses. He may be confused but *he* is not a misspelling moron. |
| Thread Tools | |
| Display Modes | |
| Max RPM for constant speed | Paul kgyy | Owning | 27 | November 4th 05 10:06 PM |
| Constant speed props | GE | Piloting | 68 | July 3rd 04 05:08 AM |
| Rotax 914 / Constant Speed? | Richard Riley | Home Built | 4 | February 26th 04 04:01 PM |
| Constant Angle Non-Precision Approaches (CANPA) | John Bell | Instrument Flight Rules | 0 | October 24th 03 10:31 PM |
| Constant speed or constant attitude? | Jim | Soaring | 37 | September 3rd 03 01:41 PM |
