First emergency
Old September 9th 09, 05:38 AM posted to rec.aviation.owning
EventHorizon
Default First emergency
"vaughn" wrote in
"EventHorizon" wrote in message
. 12.10...
We were still at full
throttle and obviously we had a broken cable or something similar.
Were you truly at full throttle? While flying towards home and a
longer runway would be tempting, I would not be comfortable flying at
takeoff power for some 45 minutes. Your engine is likely not made to
do that.
This only took about 5 minutes. Yes, we were at full throttle.
Two minor things that you did not mention: You could have at least
slightly reduced your power with carb heat. Switching off one mag
should reduce power by a further small amount. To keep your engine
from overheating, 90% power is far better that 100% power.
Good points. My partner and I just mentioned the one mag idea and that is a
good one. I hadn't thought about carb heat, that's another good idea.
I am glad that it worked out for you!
Vaughn
Emergency Dan Luke Piloting 57 April 12th 06 03:01 PM
EMERGENCY AIR PUMPS [email protected] Soaring 7 January 31st 06 12:29 AM
Emergency airports Paul kgyy Piloting 7 November 2nd 05 11:44 PM
Emergency Procedures RD Piloting 13 April 11th 04 09:25 PM
Not an emergency??? William W. Plummer Instrument Flight Rules 14 December 26th 03 07:28 AM
