#11
Stealth Pilot wrote:
On Tue, 15 Sep 2009 13:36:29 GMT, Jerry Wass wrote: Stealth Pilot wrote: On Mon, 14 Sep 2009 15:44:02 -0400, Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike MIKE, for crissake!!! aaaaaaaaaaaaaaaaaarrrrrrrggggggghhhhhhh!!!!!!! post the dimensions you need and I'll machine you a new one. sTEALTH pILOT sEE YOU'VE UPSET ME THAT MUCH THAT THE CAPS LOCK HAS JAMBED. mINE DOES THAT aLL THE tIME!!--jERRY we should make it an internet project. absolutely everyone in the world with a lathe makes him a new bushing insert and sends it to him. maybe after the 80,000th bushing arrives it will sink in that in aircraft you do it properly or not at all. (have you been too embarrassed to ask for a bushing jERRY?) Stealth :-) Pilot If all else fails make it too big and hammer it in place? Dan, U.S. Air Force, retired |
Peter Dohm wrote:
"Dan" wrote in message ... Peter Dohm wrote: "brian whatcott" wrote in message ... Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike That method is generally recognized as cowboy engineering. You might hope for better life from using a metal powder filled epoxy to fill the gap, and that's no great shakes either. Pick a bigger bush and reduce it, if you possibly can. Brian W What??? Is "cowboy engineering" the newest politically correct version of political incorrectness in describing a "kluge" or generally unacceptable practice? Peter ;-))) You're gonna upset some guys who're real good with .44s .44 is for sissies, try .500 S&W magnum. In any event knurling isn't a good solution for something on which your life may depend. There simply isn't enough surface generated by knurling. I have done it for toy steam engines, but would never do it for something that has significant forces applied. Bear in mind bronze and the tube material have different temperature expansion rates. If you don't need to apply a lot of force to it you can use a prick punch to stipple the outside of the bushing if you don't have access to a lathe and knurling tool. If you choose to make your own bushing bear in mind there are different bronze alloys each with its own characteristics. I use phosphor bronze for most of my bearing applications. Dan, U.S. Air Force, retired AFAIK, the .44 was the percussion cap wheel gun that became the .45 Long Colt, a/k/a The Gun That Won The West, and extremely popular amoung cowboys during the brief period of the Old West. In any case, I agree with you about knurling. Peter Oh, THAT 44 Mine is a replica Colt army. Did you know if one doesn't crimp the caps correctly they all drop off when the first one is fired? Not that anything like that ever happened to me or anything. Dan, U.S. Air Force, retired |
In article , Dan
wrote: Peter Dohm wrote: "Dan" wrote in message ... Peter Dohm wrote: "brian whatcott" wrote in message ... Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike That method is generally recognized as cowboy engineering. You might hope for better life from using a metal powder filled epoxy to fill the gap, and that's no great shakes either. Pick a bigger bush and reduce it, if you possibly can. Brian W What??? Is "cowboy engineering" the newest politically correct version of political incorrectness in describing a "kluge" or generally unacceptable practice? Peter ;-))) You're gonna upset some guys who're real good with .44s .44 is for sissies, try .500 S&W magnum. In any event knurling isn't a good solution for something on which your life may depend. There simply isn't enough surface generated by knurling. I have done it for toy steam engines, but would never do it for something that has significant forces applied. Bear in mind bronze and the tube material have different temperature expansion rates. If you don't need to apply a lot of force to it you can use a prick punch to stipple the outside of the bushing if you don't have access to a lathe and knurling tool. If you choose to make your own bushing bear in mind there are different bronze alloys each with its own characteristics. I use phosphor bronze for most of my bearing applications. Dan, U.S. Air Force, retired AFAIK, the .44 was the percussion cap wheel gun that became the .45 Long Colt, a/k/a The Gun That Won The West, and extremely popular amoung cowboys during the brief period of the Old West. In any case, I agree with you about knurling. Peter Oh, THAT 44 Mine is a replica Colt army. Did you know if one doesn't crimp the caps correctly they all drop off when the first one is fired? Not that anything like that ever happened to me or anything. And then you're left with trying to decide whether scrabbling on the ground to pick up caps and try again, or to get a new batch out of the tin will be less obvious to onlookers. Generally, they won't notice, being doubled over, laughing hysterically. Never happened to me, either. Nope. |
"Dan" wrote in message ... Oh, THAT 44 Mine is a replica Colt army. Did you know if one doesn't crimp the caps correctly they all drop off when the first one is fired? One also quickly learns to turn the gun upside-down whilst re-cocking the hammer after each shot. Otherwise you risk having the used cap drop down and jam the action. Vaughn |
Steve Hix wrote:
In article , Dan wrote: Peter Dohm wrote: "Dan" wrote in message ... Peter Dohm wrote: "brian whatcott" wrote in message ... Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike That method is generally recognized as cowboy engineering. You might hope for better life from using a metal powder filled epoxy to fill the gap, and that's no great shakes either. Pick a bigger bush and reduce it, if you possibly can. Brian W What??? Is "cowboy engineering" the newest politically correct version of political incorrectness in describing a "kluge" or generally unacceptable practice? Peter ;-))) You're gonna upset some guys who're real good with .44s .44 is for sissies, try .500 S&W magnum. In any event knurling isn't a good solution for something on which your life may depend. There simply isn't enough surface generated by knurling. I have done it for toy steam engines, but would never do it for something that has significant forces applied. Bear in mind bronze and the tube material have different temperature expansion rates. If you don't need to apply a lot of force to it you can use a prick punch to stipple the outside of the bushing if you don't have access to a lathe and knurling tool. If you choose to make your own bushing bear in mind there are different bronze alloys each with its own characteristics. I use phosphor bronze for most of my bearing applications. Dan, U.S. Air Force, retired AFAIK, the .44 was the percussion cap wheel gun that became the .45 Long Colt, a/k/a The Gun That Won The West, and extremely popular amoung cowboys during the brief period of the Old West. In any case, I agree with you about knurling. Peter Oh, THAT 44 Mine is a replica Colt army. Did you know if one doesn't crimp the caps correctly they all drop off when the first one is fired? Not that anything like that ever happened to me or anything. And then you're left with trying to decide whether scrabbling on the ground to pick up caps and try again, or to get a new batch out of the tin will be less obvious to onlookers. Generally, they won't notice, being doubled over, laughing hysterically. Never happened to me, either. Nope. Have you ever noticed a truly good foul up is almost always accomplished with an appreciative audience? Dan, U.S. Air Force, retired |
vaughn wrote:
"Dan" wrote in message ... Oh, THAT 44 Mine is a replica Colt army. Did you know if one doesn't crimp the caps correctly they all drop off when the first one is fired? One also quickly learns to turn the gun upside-down whilst re-cocking the hammer after each shot. Otherwise you risk having the used cap drop down and jam the action. Vaughn One also rapidly ;earns not to go target shooting on a totally windless day. Waiting an hour to be able to see the target again gets old fast. Smokeless powder? We don't need no steenking smokeless powder. Dan, U.S. Air Force, retired |
On Tue, 15 Sep 2009 12:28:49 GMT, Stealth Pilot
wrote: On Mon, 14 Sep 2009 15:44:02 -0400, Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike MIKE, for crissake!!! aaaaaaaaaaaaaaaaaarrrrrrrggggggghhhhhhh!!!!!!! post the dimensions you need and I'll machine you a new one. sTEALTH pILOT sEE YOU'VE UPSET ME THAT MUCH THAT THE CAPS LOCK HAS JAMBED. Don't bother |
Peter Dohm wrote:
I have a small bronze bushing whose OD I'd like to expand ... with something like a knurling tool. ~*~ That method is generally recognized as cowboy engineering. ~*~ What??? Is "cowboy engineering" the newest politically correct version of political incorrectness in describing a "kluge" or generally unacceptable practice? Peter ;-))) You're gonna upset some guys who're real good with .44s Hmmm...you have a point... :-) B |
On Tue, 15 Sep 2009 13:36:29 GMT, Jerry Wass wrote: Stealth Pilot wrote: On Mon, 14 Sep 2009 15:44:02 -0400, Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike MIKE, for crissake!!! aaaaaaaaaaaaaaaaaarrrrrrrggggggghhhhhhh!!!!!!! post the dimensions you need and I'll machine you a new one. sTEALTH pILOT sEE YOU'VE UPSET ME THAT MUCH THAT THE CAPS LOCK HAS JAMBED. mINE DOES THAT aLL THE tIME!!--jERRY we should make it an internet project. absolutely everyone in the world with a lathe makes him a new bushing insert and sends it to him. maybe after the 80,000th bushing arrives it will sink in that in aircraft you do it properly or not at all. (have you been too embarrassed to ask for a bushing jERRY?) Stealth :-) Pilot NO--I have a lath--Steif & Bruin 11X22--melt down old 45-70 hulls for stock. |
On Tue, 15 Sep 2009 17:28:57 -0400, Michael Horowitz
wrote: On Tue, 15 Sep 2009 12:28:49 GMT, Stealth Pilot wrote: On Mon, 14 Sep 2009 15:44:02 -0400, Michael Horowitz wrote: I have a small bronze bushing whose OD I'd like to expand slightly so it fits the ID of a tube. I seem to recall there was a way to expand the OD slightly with something like a knurling tool. Does that sound familiar? Is there an easy way to do this? - Mike MIKE, for crissake!!! aaaaaaaaaaaaaaaaaarrrrrrrggggggghhhhhhh!!!!!!! post the dimensions you need and I'll machine you a new one. sTEALTH pILOT sEE YOU'VE UPSET ME THAT MUCH THAT THE CAPS LOCK HAS JAMBED. Don't bother michael. I once drove 600km getting a bushing sorted out. the first time it was too tight. trimmed off a bit. slightly too loose. worked out the fit needed, next time a perfect drive fit, just tap in place. 600km to get it just right. the project now sits in my backyard workshop. do it properly or the bushing will wear prematurely. if you cant get one locally I can machine one in phos bronze and post it to you. is easy. you've probably still got my email address. Stealth Pilot |
| Thread Tools | |
| Display Modes | |
| ?replace bushing on compressor wheels? | mhorowit | Home Built | 4 | September 22nd 08 04:43 AM |
| Expanding my flying comfort zone (long) | Ron Lee[_2_] | Piloting | 2 | December 8th 07 04:02 AM |
| Enlarging a bushing hole? | Michael Horowitz | Home Built | 18 | September 17th 07 12:57 PM |
| (CNN & AP) U.N: Iran expanding rather than freezing nuclear program | AirRaid[_3_] | Naval Aviation | 3 | February 26th 07 07:49 PM |
| Rubber Bushing Replacement | Boelkowj | Home Built | 8 | December 12th 03 01:45 AM |
