Slats are typically UN-powered devices on the leading edge that extend
simply by the reduced dynamic pressure against them as airspeed slows. Example would be the leading edge extensions of the F-86 and F-100. I wouldn't agree with "typically." Aero slats also extend when a certain AOA is achieved ... the A-4 slats would extend at approximately 12 units AOA (IIRC) and bringing them out symmetrically at higher airspeeds was not a sure thing. Grumman liked powered slats. Both the A-6 and F-14 had them. R / John |
![]() "John Carrier" wrote in message ... Slats are typically UN-powered devices on the leading edge that extend simply by the reduced dynamic pressure against them as airspeed slows. Example would be the leading edge extensions of the F-86 and F-100. I wouldn't agree with "typically." Aero slats also extend when a certain AOA is achieved ... the A-4 slats would extend at approximately 12 units AOA (IIRC) and bringing them out symmetrically at higher airspeeds was not a sure thing. The Blues bolted 'um shut. Can you imagine what would happen in a tight diamond with an A4 if a wing position got an asymmetrical slat extension with roll induced....say in a barrel roll? Not a pretty thought!! :-)) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
The F-4C, D and hardwing E had leading edge flaps, the E (post 556) and
subsequent models F,G, S had powered slats. The Thunderbirds used hardwing E-models, probably for the reasons you stated. Also had no radar and added VHF radios, but we weren't talking about that. I once had an asymmetric leading edge flap extension in a C model. Rolled inverted faster than I ever had. Pilot was cool and unloaded and used a whole bunch of rudder to regain control. -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Dudley Henriques" wrote in message k.net... The Blues bolted 'um shut. Can you imagine what would happen in a tight diamond with an A4 if a wing position got an asymmetrical slat extension with roll induced....say in a barrel roll? Not a pretty thought!! :-)) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
diamond with an A4 if a wing position got an asymmetrical slat extension with roll induced....say in a barrel roll? Not a pretty thought!! :-)) Also bolted shut when the A-4E/F (AKA Mongoose) was used as adversary for F-8 and F-4. Then unbolted when the Turkey showed the necessity of better slow speed capability. John X |
"Dudley Henriques" wrote...
The Blues bolted 'um shut. Can you imagine what would happen in a tight diamond with an A4 if a wing position got an asymmetrical slat extension with roll induced....say in a barrel roll? Not a pretty thought!! :-)) In over 1700 A-4 hours, I never had an asymmetric slat extension that I could not quickly and easily control. After about 1000 hours, few of them were even unpredictable... Careful preflight of the slats would give a VERY good idea of which one would come out first, and any preflight "stickiness" was grounds for rejecting the airplane or having the Airframers work on it before flight. I believe too many TA-4s were lost in the Training Command due to students' unfamiliarity with the airplane and instructors' failure to teach and emphasize both preflight and recovery techniques. That said, I fully understand why the Blues bolted them in -- their 36" wingtip-to-fuselage clearance in some of their formation maneuvers gave quite a bit less room for error than our nominal 3-5' wingtip-to-wingtip clearance in the fleet. |
On Sun, 11 Jan 2004 20:14:26 GMT, "John R Weiss"
wrote: "Dudley Henriques" wrote... The Blues bolted 'um shut. Can you imagine what would happen in a tight diamond with an A4 if a wing position got an asymmetrical slat extension with roll induced....say in a barrel roll? Not a pretty thought!! :-)) In over 1700 A-4 hours, I never had an asymmetric slat extension that I could not quickly and easily control. After about 1000 hours, few of them were even unpredictable... I wonder if you could try to describe, as well as you can recall, what exactly happens during an asymmetrical slat extension? The reason I am asking such an obvious sounding question is that we recently had a discussion concerning asymmetric slat extension of a BF-109 in a Finnish newsgroup. While the immediate lay-man's reaction is that the aircraft would, of course, violently roll away from the extended slat (=extended slat up), because of the increased lift by the slat, the situation becomes less obvious the more I think about it. Theoretically, from the textbook figure illustrating the effect of trailing edge flaps and leading edge slats, one could argue that nothing happens, since slats (unlike flaps) do not increase Lift Co-efficient (CL) on a given Angle of Attack (AOA) but only increase the maximum attainable CL. This at least in the case that the net wing area does not increase when slat extends. If the wing area increases (as probably is the case with A-4, judging from the photo I have) as the slat extends, the aircraft would tend to roll extended slat up. Right? However, if the geometry is such that the leading edge moves down as the slat extends, one could argue that the AOA of the profile decreases causing roll towards the extended slat. Or, if the slat extension causes a change of pressure distribution around the aileron (the aileron snatch reported by the British BF-109 test pilots ?) moving the ailerons (probably not on the hydraulic irreversible(?) control system of the A-4) until the pilot corrects it, the roll could be either way. Mikko |
On Sun, 11 Jan 2004 13:13:00 GMT, "Dudley Henriques"
wrote: The Blues bolted 'um shut. Can you imagine what would happen in a tight diamond with an A4 if a wing position got an asymmetrical slat extension with roll induced....say in a barrel roll? Not a pretty thought!! :-)) Or you could ask Steve what happens when one F-18 slat popped up over the stops and got stuck, perpendicular to the airflow. Not a pretty sight at all. Of course, the O'Hare DC-10 had a slat asymmetry, although that was an asymmetric retraction of an extended slat. Subsequent simulator studies showed that, even knowing the problem was asymmetric slats, the airplane was too low to recover. Mary -- Mary Shafer Retired aerospace research engineer |
On Mon, 12 Jan 2004 23:03:31 -0800, Mary Shafer
wrote: Of course, the O'Hare DC-10 had a slat asymmetry, although that was an asymmetric retraction of an extended slat. Subsequent simulator studies showed that, even knowing the problem was asymmetric slats, the airplane was too low to recover. Mary If we're talking about the same DC-10 that was lost at O'Hare about 20 years ago, the slat assymetry was caused by the engine and pylon departing the wing, up and over and in the process taking a chunk of leading edge with it. The accident investigation and subsequent simulator trials demonstrated fairly conclusively that the aircraft was recoverable, however training to immediately pull up and reduce speed to Vmc was incorrect. What was needed was the more high performance airplane practice of "unload for control" in which you (counter-intuitively) ease off the back pressure possibly all the way to zero G and let airspeed build to a point where more G is available for the recovery. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
On Sun, 11 Jan 2004 06:05:28 -0600, "John Carrier"
wrote: Slats are typically UN-powered devices on the leading edge that extend simply by the reduced dynamic pressure against them as airspeed slows. Example would be the leading edge extensions of the F-86 and F-100. I wouldn't agree with "typically." Aero slats also extend when a certain AOA is achieved ... the A-4 slats would extend at approximately 12 units AOA (IIRC) and bringing them out symmetrically at higher airspeeds was not a sure thing. "How many angels (angles?) can dance on the head of a pin?" My use of "typically" referred to the "un-powered", i.e. hydraulically or electrically actuated/operated aspect. And, the examples (F-86 and F-100) were aerodynamic, not mechanical. It, hopefully, recognized that slats can be mechanically operated. If they extend when airpressure is reduced as airspeed slows, then it would be redundant to add "also when a certain AOA is achieved" because that is the inevitable, inexorable, undeniable result of slowing. Gotta believe that the assymetric deployment even intermittently would be exciting. Really, the discussion of the wide range of wing-modifying devices that have been employed over the years is amazing. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
would be redundant to add "also when a certain AOA is achieved" because that is the inevitable, inexorable, undeniable result of slowing. I was thinking of maneuvering. The A-4 slat would extend up to around 350KIAS once the proper AOA was achieved ... hardly slow. I suspect the various NA products behaved similarly. R / John |
FS - Propeller leading edge protective tape | Sammy | Home Built | 0 | July 6th 04 12:06 PM |
Leading edge protection search | Tim Hickey | Home Built | 0 | June 28th 04 02:45 AM |
A Bush C150? With Leading Edge Slats? | [email protected] | Home Built | 33 | May 27th 04 05:39 PM |
-7 wing leading edge 'glitch' ? | Charlie England | Home Built | 0 | March 7th 04 12:27 AM |
tail buffeting and leading edge fillets, strakes | Wallace Berry | Home Built | 1 | September 26th 03 10:48 PM |
