"Morgans" wrote in message
... "twdeckard" wrote I am sure you know all of this (grin), I just chimed in becuase its a check best done on the run-up pad. He did not say you shouldn't do it at run-up. He was just pointing out that your engine could run very rough if you lose one side while cruising. -- Jim in NC I am really not sure exactly what he tried to say; but, in his initial post, it was clear that he had lost the use of all of one mag and a part of the other--or the plugs or wires attached to it. The problem with that is that mags have a couple of failure modes that are common to all breaker point ignition systems in addition to the failure modes that are peculiar to magnetos. As far as I know, it is still a common practice to simply set the timing and perform a runup type mag check as part of an annual and not open the mags to gap and visually check the points. That leaves the door a lot farther open for the failure modes involving erosion of the points--which is related to one of the two failure modes of the capacitor a/k/a condenser--and also to wear of the cam follower. Both of those failure modes usually make the engine harder to start long before they will fail in flight, or at runup test; but are masked sufficiently by electric starters that they can go virtually unnoticed--unless the pilot is so dilligent as to carefully prime and set the throttle and then count the blades on nearly every start. Peter |
On Oct 18, 10:40*am, "Peter Dohm" wrote:
"Morgans" wrote in message ... "twdeckard" wrote I am sure you know all of this (grin), I just chimed in becuase its a check best done on the run-up pad. He did not say you shouldn't do it at run-up. *He was just pointing out that your engine could run very rough if you lose one side while cruising. -- Jim in NC I am really not sure exactly what he tried to say; but, in his initial post, it was clear that he had lost the use of all of one mag and a part of the other--or the plugs or wires attached to it. The problem with that is that mags have a couple of failure modes that are common to all breaker point ignition systems in addition to the failure modes that are peculiar to magnetos. As far as I know, it is still a common practice to simply set the timing and perform a runup type mag check as part of an annual and not open the mags to gap and visually check the points. *That leaves the door a lot farther open for the failure modes involving erosion of the points--which is related to one of the two failure modes of the capacitor a/k/a condenser--and also to wear of the cam follower. *Both of those failure modes usually make the engine harder to start long before they will fail in flight, or at runup test; but are masked sufficiently by electric starters that they can go virtually unnoticed--unless the pilot is so dilligent as to carefully prime and set the throttle and then count the blades on nearly every start. Peter To put several of your minds at ease, of course I did the conventional both-right-both-left mag check at runup, but at 1900 RPM. I had not had one bank of spark plugs go in/op ever until the in flight failure a little while ago, and my post was simply to suggest pilots go to one mag while at cruise rpm and engine loading to see what happens. In my case the engine ran a bit rougher -- rpms stayed where they were set, of course, because prop pitch changed to accommodate the reduction in power. I am sure I make lots of inadvertent errors when flying: missing a mag check is not one of them. |
| Interesting and different flight on OLC | Dave Nadler | Soaring | 2 | August 4th 09 02:06 PM |
| Solar Flight Much more interesting than Hilarious Video | Richard[_1_] | Soaring | 0 | December 5th 08 05:07 PM |
| Interesting 2-plane takeoff at BWI 4-28-06 (formation flight) | Gary G | General Aviation | 2 | May 1st 06 09:42 PM |
| An interesting trial flight attempt... | [email protected] | Soaring | 35 | February 12th 06 08:31 PM |
| A small experiment | Mike Borgelt | Soaring | 16 | May 6th 05 07:41 AM |
