On Nov 1, 2:49*pm, "vaughn"
wrote: "Andy" wrote in message ... *This still leaves total climb capability a bit over 4,500 feet so the straight cruise must get more out of the motor than a sawtooth, though I am not clear why this would be true. One good reason is because the whole electrical system, especially the battery itself, is more efficient when operated at lower currents. *At higher power outputs, a greater percentage of the battery's precious stored energy turns into waste heat, so less of the battery's stored energy is available to actually propel your aircraft.. Vaughn True - though I was under the impression that a sawtooth profile is more efficient for the overall glider-motor system. I'm at a loss as to why the cruise mode for this system would produce nearly twice the range of the sawtooth - at least according to math on the various specs quoted.. The electric motor would have to REALLY hate being run full out. 9B |
I was wondering when someone would use the motor and folding prop used
on the Radian RC sailplane on a full scale ship. Nice, motor weight in nose is balanced with battery weight aft and only 77 pounds total. I figure 75 miles at low power or 5700 foot climb at full power. Heat from running motor could warm your feet on a cold winter day! Any idea on retrofit price and availability? JJ |
On Nov 1, 1:49*am, LimaZulu wrote:
First flight of Front Electric Sustainer - FES http://www.front-electric-sustainer.com http://www.youtube.com/watch?v=TNOKq6PKIvM Regards, Luka Znidarsic I've got an empty engine bay in my Apis, always thought an electric motor would be a nice thing to put in there. The doors for the prop can handle a 46" dia. blade. Brad |
This looks like a natural for a single blade prop, folding flush into
a contoured recess in the bottom of the nose. I like it! Kirk |
On Sun, 01 Nov 2009 09:51:45 -0800, kirk.stant wrote:
This looks like a natural for a single blade prop, folding flush into a contoured recess in the bottom of the nose. That would be nice to see from a propeller efficiency point of view too, because the prop could be bigger while absorbing the same power. The bigger the prop the more efficient it is. Propeller ground clearance would be irrelevant for a sustainer system. I remember seeing an Antares 20E and an ASW-22ble launch within 10 minutes of each other, so the ground and air conditions were very similar. The ASW-22 has 49hp (36 kW) and (I think) a 0.9m diameter prop while the Antares swings a 2m prop with a 47 kW motor. The Antares was off the ground in about 1/3 the run the '22 needed and climbed out at least twice as fast. I don't know how the takeoff weights would compare, but if they're not too different the additional 30% power output in the Antares wouldn't account for the takeoff and climb out difference I saw, but the different props could easily do it. A two blade prop is rather more efficient than a 5 or 6 blade unit and the almost 5:1 difference in swept area would make a big difference to drive efficiency, especially at low speeds. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
kirk.stant wrote:
This looks like a natural for a single blade prop, folding flush into a contoured recess in the bottom of the nose. I like it! Kirk Another good idea from the model world :-). Needs a hefty counterweight at those dimensions of spinner (small) and prop (large) though. /AndersP |
The HPH 304S Turbine sustainer glider | kd6veb | Soaring | 2 | September 23rd 09 05:10 AM |
would an electric sustainer be practical | Brad[_2_] | Soaring | 7 | July 24th 09 06:29 PM |
Sustainer engine ignition noise (Solo2350) | Per | Soaring | 8 | January 4th 07 05:56 AM |
DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 12:16 AM |
Chasing the front | Paul Tomblin | Piloting | 7 | April 21st 04 01:09 PM |
