"Speed to fly"?
Old January 16th 10, 09:54 PM posted to rec.aviation.piloting
Mxsmanic
Default "Speed to fly"?
What does "speed to fly" mean when piloting gliders?
Old January 16th 10, 10:26 PM posted to rec.aviation.piloting
Jim Logajan
See page 7-34 of the FAA publication "Glider Flying Handbook" which is
online he
http://www.faa.gov/library/manuals/a...-h-8083-13.pdf
Old January 16th 10, 10:41 PM posted to rec.aviation.piloting
Stefan[_3_]
Am 16.01.10 23:26, schrieb Jim Logajan:
Hum... They write "The object of speed-to-fly is to minimize the time
and/or altitude required to fly from the current position to the next
thermal." This is just plain wrong.
Old January 16th 10, 11:02 PM posted to rec.aviation.piloting
george
Whatever happened to best penetration speed ?
Old January 17th 10, 12:16 AM posted to rec.aviation.piloting
Jim Logajan
Wrong how? Note that they first write "Speed-to-fly refers to the optimum
airspeed for proceeding from one source of lift to another."
Others use the term similarly, e.g.:
"Speed-to-fly means selecting the optimum airspeed for cruising through a
given airmass, whether subsiding, still, or ascending. The goal is to
maximize distance flown per unit of altitude consumed. In a nutshell, you
can summarize the speed-to-fly concept as follows: fly slowly when in lift,
fly fast through sink, fly faster stil through very heavy sink."
- "The Art of Thermaling" by Bob Wander.
Old January 17th 10, 01:31 AM posted to rec.aviation.piloting
Stefan[_3_]
Am 17.01.10 01:16, schrieb Jim Logajan:
Yes, and that's wrong. Speed to fly is not the optimum speed to reach
the next thermal but rather to reach the target altitude in in that next
thermal. Otherwise, there would be absolutely no reason why you should
care about the strength of the next thermal.
You might argue that this is included in the word "proceeding", but I
doubt it, and even if it were, then that's certainly not clear enough
for somebody who has to ask.
You can cite as many authors as you like, if they copy their errors from
each other.
Old January 17th 10, 08:36 PM posted to rec.aviation.piloting
Jim Logajan
optimum airspeed for proceeding from one source of lift to another."
next thermal. Otherwise, there would be absolutely no reason why you
should care about the strength of the next thermal.
I'm afraid I still don't see anything in the sentence I quoted and what you
write above that are mutually exclusive in such a way as to indicate the
quoted sentence is "wrong." The brief discussion in its entirety in the FAA
handbook seems sufficient to answer the OP's question. However, a Google
search for the term by the OP, if he had bothered to even try it, would
have yielded plenty of useful hits giving more than adequate definitional
details - enough so that there would be no need to even post a query here.
The FAA handbook's brief discussion seems adequate (IMVHO) for definitional
purposes.
As to authoritativeness, Bob Wander's books are well known on this side of
the Atlantic and often recommended for new glider pilots like myself.
Besides the rough definition I quoted from his "The Art of Thermaling"
book, he goes into more detail in his book "Glider Polars and Speed-to-
Fly."
(All his titles technically end with "... Made Easy!" You can go to his web
site, www.bobwander.com, and complain to him there about his verbiage. I
think he may also follow the soaring newsgroup too.)
from each other.
What would you recommend as authoritative that defines the term to your
satisfaction?
Old January 17th 10, 10:37 PM posted to rec.aviation.piloting
Stefan[_3_]
Am 17.01.10 21:36, schrieb Jim Logajan:
Funny. If you don't understand the difference between the bottom and the
top of the next thermal, then I strongly suggest that you profit from
these cold days and read Reichmann's "cross country soaring" again.
Considering who was the OP, I strongly assume that he wasn't even
looking for an answer at all.
purposes.
How can a wrong definition be adequate?
satisfaction?
The abovementioned Helmut Reichmann's "cross country soaring" would be a
perfect starter. (Since the book was written 1975 (translated to English
1978) you may consider it somewhat vintage, but on this side of the pond
it's still considered *the* standard, and as such it's regularily
reprinted.)
Old January 18th 10, 09:00 PM posted to rec.aviation.piloting
Jim Logajan
your satisfaction?
a perfect starter.
I may buy a copy. In the mean time, how does he define the term?
Old January 18th 10, 09:17 PM posted to rec.aviation.piloting
Stefan[_3_]
Am 18.01.10 22:00, schrieb Jim Logajan:
a perfect starter.
I may buy a copy.
I strongly suggest it.
Ad hoc translation from the German book: "Speed to fly (in German
"Sollfahrt") is the speed that fits best your intention. Depending on
your situation it will be different." He then explains it over the next
30 pages.
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Piloting 168 February 5th 08 05:32 PM
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Instrument Flight Rules 137 February 5th 08 05:32 PM
Tool to "speed" up ATC in FS2004 Kenneth Skovgaard Simulators 1 February 1st 06 08:33 PM
