Could Blackjack bombers reach USA?
Old January 20th 04, 01:53 AM
BUFDRVR
Those BEAR
H that the US hosted were new build aircraft and only rolled off the
production line during the 80's.
Hmm, their tail numbers don't state a year like ours do, but those aircraft
sure looked older than 1980's, although this may have been due to Russian
maintenance than anything else.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old January 18th 04, 04:11 PM
Scott Ferrin
Range, loaded on internal fuel - 7,640 miles (B-1B - 3,444 miles)
Equipped for IFR.
Those are brochure numbers for the Blackjack.
How about B1 are the cited numbers for B1 are brochure numbers
as well?
Pretty much from what I understand. The B-1 is definitely faster than
789 mph though I'd be surprised if any operational aircraft had done a
takeoff at 477,000lbs.
In the real world (at
least as far as FAI records go) the B-1 has the Blackjack beat in the
paylaod/range department.
In its department where B1 is the only one amybe. Tu160
is much bigger?much faster and longer lange.
Speed over a closed circuit of 5000 km with 30000 kg payload : 1054.21
km/h
Date of flight: 17/09/1987
Pilot: H. Brent HEDGPETH (USA)
Crew: Robert A. CHAMBERLAIN (copilot)
Course/place: Palmdale, CA (USA)
Aircraft:
Rockwell B-1B (4 General Electric F 101-GE-102, 14 700 kg each)
Registered 'S/N70'
Speed over a closed circuit of 5000 km with 30000 kg payload : 1017.80
km/h
Date of flight: 28/05/1990
Pilot: Serguei OSSIPOV (USSR)
Crew: D.N. MATVEEV (USSR)
Course/place: Podmoskovnoe Aerodrome (USSR)
Aircraft:
Tupolev Aircraft "70N-304" (Tupolev TU-160 "Blackjack") (4 Model "P",
25 000 kg each)
As you can see, with the same 30,000kg payload flown over a distance
of 5000km, the Blackjack was slower than the B-1B. Since the
Blackjack's record attempt was flown at a later date one would assume
they'd try to beat the B-1's. If they did try they failed. The
Blackjack also holds no 10,000km speed records while the B-1 does.
While this in itself doesn't say the Blackjack can't fly that far, it
doesn't exactly help it's case either.
As for the Blackjack being faster, the lower speed of the B-1b was
intentional. The original B-1A reached Mach 2.22 which was faster
than the Blackjack. That speed was judged so important that pretty
much nobody cared when they gave it up. As for the Blackjack being
bigger. . .well if you think an aircraft that needs to be 27% heavier
and 83% more powerful to do an inferior job is something to brag
about. . .well, that's your business.
Anyway
do you have any doubts about the question asked
"Could Blackjack bombers reach USA?"
It probably had the range for a one way trip, but any aircraft that
can fly far enough could say the same.
Old January 19th 04, 11:50 AM
Michael Petukhov
Scott Ferrin wrote in message . ..
Equipped for IFR.
as well?
km/h
Aircraft:
Registered 'S/N70'
km/h
Aircraft:
25 000 kg each)
Well nobody claims that neither Tu-160 nor B1 can go supesonic for
5000 km. But why you skipped shorter range records? Unlike B1
Tu160 can go supersonic for distances of 1000-2000 km. The later
is very important for the battle applications particualrly
to hit and escape from fighters attention:
Records:
Speed over a closed circuit of 1000 km with 30000 kg payload
Podmoskovnoe 1726.90 km/h Lev Vasilyevich KOZLOV Tu-160 15/05/1990
Speed over a closed circuit of 2000 km with 30000 kg payload
Podmoskovnoe 1678.00 km/h B.I. VEREMEY Tu-160 03/11/1989
Something which B1-B is not capable at all.
Michael
Anyway
Old January 19th 04, 03:51 PM
Scott Ferrin
I skipped the shorter ranged records because the higher speed of the
Blackjack was never in doubt. I was questioning warload and range
which is why I quoted that particular record.
Old January 19th 04, 12:12 PM
Michael Petukhov
Just to add a few words about their inferior job. Who else can do
this inferior job in this world, but americans and russians? Nobody
http://www.newsmax.com/archives/arti...0/123624.shtml
"... In the early morning of May 14, six Russian strategic bombers,
namely two TU-160Cs and four TU-95MCs belonging to the 37th Strategic
Aviation Army, left the Engels airbase near Saratov city and reached
the Indian Ocean five hours later. There the TU-95 fired two strategic
cruise missiles X-55 (3,000-km range, usually with a nuclear warhead),
which "precisely hit ground targets."
The Tu-160 bombers flew further and, at a 2,500-km distance, simulated
the firing of several X-55 missiles at Diego-Garcia Island. The
targets included a U.S. strategic aviation airbase, a naval base, the
command and control center of U.S. strategic submarines in the Pacific
Ocean, the U.S. electronic reconnaissance center and a nuclear warhead
storage facility.
Several hours later, the six strategic bombers returned to Engels
airbase. According to Russian Air Force Commander-in-Chief Col.-Gen.
Vladimir Mikhailov, 1) Russian strategic bombers "visited" the Indian
Ocean for the first time since 1990 and 2) the Russian top military
command has a definite interest in this region.
On May 15, TU-95 and TU-160 strategic bombers and TU-22 long-range
bombers accomplished military training over the Polar and Pacific
oceans. All the bombers had a full battle load: Each T-95 carried 6
X-55 missiles, each TU-160 12 missiles. The X-55 usually is equipped
with a 200-kiloton nuclear warhead. All the bombers simulated hitting
important U.S and U.K. targets.
However, in accordance with direct orders from Putin to Russian
Defense Minister Sergei Ivanov, this time – in contrast with strategic
aviation maneuvers in 1999 – Russian bombers didn't approach the
borders of Norway, Iceland, Canada, the U.K. and the U.S. This was
done to provide a "friendly environment" for the visits of Secretary
of State Colin Powell to Moscow on May 16 and President Bush to
Petersburg on May 30.
During the maneuvers over the Pacific Ocean on May 15, four TU-22
long-range bombers (two from the 37th AF Army, two from the Russian
Pacific Ocean Fleet) simulated the simultaneous firing of four X-22
anti-ship missiles at the U.S. aircraft Karl Winson, which was moving
at this time from the Yokosoka base in Japan to the coast of North
Korea.
Maneuvers of Russian bombers in the airspace over the three oceans
have been supported by the Russian Northern Fleet, Pacific Fleet,
Strategic Missile Troops, Space Troops and two air force and air
defense armies.
Gen. Mikhailov claimed that a) all goals of the maneuvers were reached
and b) in July and August, the 37th Strategic Aviation Army will hold
similar large-scale maneuvers (apparently against American and British
targets), though the number of participating strategic bombers and
long-range bombers will increase two to three times.
Remarkably, on May 16, a united group of the Russian Navy, compiled
from the vessels from the Pacific Fleet and Black Sea Fleet, held
"enemy [U.S. and U.K.] aircraft groups destruction maneuvers" in the
Indian Ocean.
Concretely, the Moskva missile cruiser launched a P-500 Bazalt
anti-ship cruise missile. This missile has a 480-km radius and is
usually equipped with a 350-kiloton nuclear warhead. The Moskva
missile cruiser has eight cruise missile launchers and a store of 16
Bazalt missiles..."
Old January 19th 04, 03:25 PM
Kevin Brooks
"Michael Petukhov" wrote in message
You are rather desperate if you are still depending on that training
exercise conducted nearly a year ago, with no "opposing force", to buttress
your fragile ego, Michael. Are we supposed to be impressed that you managed
to get *six whole bombers* into the air at one time?
Brooks
snip
Old January 19th 04, 04:01 PM
BUFDRVR
First off, the ability of the X-55 to fly over 1600 nm is highly debateable.
Secondly, a round trip from Engels AB to a point 2,500km from Diego Garcia and
back to Engels is a distance of over 6824 km (in a straight line). If there was
no in flight refueling done, this mission simply did not happen.
BUFDRVR
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 04:34 PM
Bombers and Fighters ArtKramr Military Aviation 4 September 18th 03 01:37 AM
water bombers Stew Hicks Home Built 2 September 9th 03 12:55 AM
F-111 bombers flying from carriers ? Mike Military Aviation 38 August 7th 03 01:19 AM
Backfire bombers: Reach USA ? Mike Military Aviation 11 July 28th 03 12:56 PM
