Removing Cement From Gelcoart ... Safely
Old April 5th 10, 05:56 PM posted to rec.aviation.soaring
sisu1a
Default Removing Cement From Gelcoart ... Safely
Good luck with the Velcro. I've had problems with the part mounted
to
the cockpit wall sliding (sliming the wall with gooey) in the heat.
The 3M mushroom lock is stronger and works better the Velcro for
mounting heavier loads (sold at McMaster-Carr)
On your velcro, buy the non adhesive backed kind. Epoxy (or pliobond
or industrial contact cement, or...) the soft side to your cockpit
wall and use upholstery needle/thread to attach the spiky side to your
to your pockets (glue bond the spiky side to solid objects). When I
ever want velcro to stay put on any surface, I use the strongest
bonding/fastening methods I can, because in some conditions (heat
etc) the hook and loop is invariably stronger than the bond you can
achieve with the sticky back crap they supply it with, which will lead
to the same problem Frank had.
Your bond has to repeatedly win the tug-o-war with the velcro, so that
rules out the stock sticky in my book.
-Paul
Old April 6th 10, 03:55 AM posted to rec.aviation.soaring
ContestID67[_2_]
Thanks for the suggestions. Yes, I thought about the velcro coming
unstuck. However, the 2" wide stuff seems pretty well stuck to the
cockpit wall - but time will tell. Worse case I remove it all and
start over, no great loss and it has to be easier than taking off the
previous adhesive - which is why I don't want to glue on the next
batch. The bottom line is that the idea of a velcro "wall" to attach
whatever you need, and being able to change things around easily, is
really a good idea.
I am trying to find some type of elastic top bag which duplicates what
was there. Bags with non-elastic tops just aren't as usable. I think
that the real trick will be finding one with a stiffner. So I might
just have to sew my own with a thin aluminum backing insert. And
*SEW* the hook side onto the back of the bag.
Thanks again,
John DeRosa
Old April 6th 10, 05:58 AM posted to rec.aviation.soaring
sisu1a
Thanks again,
John DeRosa
Still use the non adhesive backed stuff at least to sew on the pouch.
The adhesive horribly binds the needle and necessitates liberal
application of profanity to achieve even mediocre results
Good point on epoxying the velcro onto the wall. Turns future removal
into a grinder job.
Velcro... pffft. this is what Chuck Norris would use:
http://news.cnet.com/8301-13639_3-10346953-42.html
http://www.metaklett.de/
-Paul
Plexiglas cement?? Larry Home Built 16 November 11th 07 03:15 PM
Transporting O2 safely Michael Horowitz Home Built 22 November 2nd 07 10:50 PM
Fly Safely.... muff528 Piloting 1 April 18th 07 08:05 PM
How to be safely stupid scott moore Instrument Flight Rules 10 March 15th 07 03:20 AM
OOPS! Got contact cement on the windshield Mike Rapoport Owning 12 November 14th 04 12:13 AM
