New Soaring PNA Available
Old May 11th 10, 08:22 AM posted to rec.aviation.soaring
johngalloway[_2_]
Default New Soaring PNA Available
On May 11, 6:26*am, "
On May 10, 10:10*pm, JS wrote:
On May 10, 9:53*pm, "
What is more important is the readability with more screen real
estate.
And a free Plastic Jesus!http://web.archive.org/web/200605210...ght.com/Glidin...
Ok Jim, I'll throw in free plastic Jesus upgrade for the first 10
purchasers.
The JPS (Jesus Positioning Unit) will be autographed with a Sharpie by
yours truely.
Al
Plastic is a bit old hat. I'd expect Jesus to be digitized and to
appear on screen as a pop-up at appropriate times - such as below a
user defined altitude or on a marginal final glide - and I'd expect to
have a choice of prophets and deities for pilots of other faiths - or
for those (like me) who can go through a variety of short term
religious conversions in the course of a single flight.
Old May 11th 10, 08:50 AM posted to rec.aviation.soaring
estate.
purchasers.
yours truely.
Al
Plastic is a bit old hat. *I'd expect Jesus to be digitized and to
All you have to do is rub the head of your JPS.
The Voodoo version ships with a rubber chicken which you can choke
when low..
Old May 12th 10, 02:47 AM posted to rec.aviation.soaring
PCool
A few questions:
1) Does the JPS work really for finding the way back home?
2) Does it multiplicate the thermals?
3) Does it transform the water ballast into wine ballast ? (this is very
important)
4) Is it certified by the Vatican City Aviation?
5) Is it possible to connect it to a Cambridge?
Thanks ..
Paolo
ha scritto nel messaggio
On May 10, 10:10 pm, JS wrote:
On May 10, 9:53 pm, "
estate.
And a free Plastic
purchasers.
yours truely.
Al
Old May 12th 10, 05:52 AM posted to rec.aviation.soaring
On May 11, 6:47*pm, "PCool" wrote:
A few questions:
important)
Thanks ..
Paolo
ha scritto nel ...
estate.
And a free Plastic
purchasers.
yours truely.
Al
First of all Paolo your work on the LK8000 is fantastic.
I think what you have created especially with the latest release is
absolutely amazing.
Cant wait to see the full release version out.
I urge everyone who is interested in reading the manual here.
http://www.bware.it/LK8000/LK8000_MANUAL_120.pdf
Now in answer to your questions, the JPS unit only works if you trust
in its plastic'ness.
If you do not feel the force from the JPS then it is not going to give
proper direction.
The JPS has not been known to affect thermal size or density but if
you do find yourself low I found it always helped to rub its head.
The water to wine upgrade has not been installed mine as its
experimental and does not carry the Vatican VSO.
I have used it with Cambridge S-Nav quite extensively and you can see
it here pre-take off..
http://web.archive.org/web/200512280...suscockpit.jpg
Here you can see the JPS in action
http://web.archive.org/web/200512280...JesusPanel.jpg
Note it blocks out the S-Nav completely.
The JPS is still the original one given to me by an ex-stripper who
used to work for me after she found religion.
To this day I always carry him in my camelback when flying.
You can see the JPS's last recorded on video sighting here.
http://silentflight.com/index.php?op...=7&video_id=26
Cheers
Al
Old May 12th 10, 04:35 PM posted to rec.aviation.soaring
Brad[_2_]
On May 10, 10:26*pm, "
estate.
purchasers.
yours truely.
Al
Al,
If you can add FLARM or ADS-B and integrate that with a JPS that
speaks up and informs you of the traffic I'll get 2 of them!
Would the Goddard cable that powers the iPAQ310 also be able to power
the Faux Oudie?
Brad
Old May 12th 10, 05:12 PM posted to rec.aviation.soaring
estate.
purchasers.
yours truely.
Al
Al,
the Faux Oudie?
Brad
The LK8000 software has FLARM integration you can see their test setup
on Paolo's website.
It is detailed in the manual link I posted earlier in this thread.
As far as cabling goes, it's basically a serial to USB converter with
power.
Cumulus has them "shipping may 15th" I believe or there are a number
of raw cables that could be modified easily.
I can assemble a package of cable, computer and test NMEA into the
device shipping it as a package for you ready to go.
If you would like multiple units email me directly to discuss.
Cheers
Al
Old May 12th 10, 08:13 PM posted to rec.aviation.soaring
Andrew Blanchard
I purchased a unit on ebay (Item number 270547293803 ) that looks
quite similar. I can say that it loads LK8000 easy and runs great.
Battery life sucks, but I just use 4-AA batteries in USB charger.
Old May 12th 10, 02:04 AM posted to rec.aviation.soaring
Tony V
estate.
http://web.archive.org/web/200605210...ng/gliding.htm
But I *do* care if it rains or freezes. :-)
Tony
Colorado Soaring Pilots/SSA Governor 2007 Seminar and 2006 Soaring Awards Banquet Frank Whiteley Soaring 0 February 15th 07 04:52 PM
The Soaring Server is dead; long live the Soaring Servers John Leibacher Soaring 3 November 1st 04 10:57 PM
Soaring Server/Worldwide Soaring Turnpoint Exchange back online John Leibacher Soaring 0 June 21st 04 05:25 PM
Soaring Server - Worldwide Soaring Turnpoint Exchange John Leibacher Soaring 0 June 19th 04 04:57 PM
World Champion Soaring Pilot To Speak at Sky Soaring John DeRosa Sky Soaring Chicago IL Soaring 0 May 14th 04 09:02 PM
