Airspeed of military planes
Old January 25th 04, 02:53 PM
Frijoles
Nozzles aft, Harrier approach speed will be in the 155kt +/-range. At 20
nozzles and auto flaps(normal for IFR final), you're somewhat slower but to
be honest I don't recall the airspeed because my primary reference was
always AoA. Depending on the type of landing you intend to make, once
you're in the visual environment, you transition to a higher nozzle angle
(60-75 depending...), and in some instances, STOL flaps where the flaps
program automatically as a function of nozzle angle. "On speed" for a
fixed-nozzle slow landing is around 110kts. The *very* slow rolling
landings you occasionaly see are called rolling vertical landings -- 60 kts
ground speed is the target but the transition to that speed will usually be
over the runway, not on approach final.
"Darkwing Duck" wrote in message
"Tetsuji Rai" wrote in message
s.com...
Airspeed limitation below 10000ft is usually 250kts unless you have been
authorized by the Administrator. However I guess it's a bit slow for
military fighters. So I am curious how fast military fighters fly in
real world. I guess it's very dangerous military aircraft fly much
fast
among civilian planes.
So how fast is short final in a F-14 or whatever? Always wanted to know.
Old January 25th 04, 05:10 PM
Jim Baker
You're right Frijoles, in the Bone the correct answer for "What airspeed do
you fly on final" is "I don't know/care. I'm flying 7 AoA as required by
the Dash One". There is however, a chart of airspeed and gross weights that
every pilot has and, IAW the Landing Checklist, every final must have an
airspeed computed.
JB
"Frijoles" wrote in message
ink.net...
to
kts
be
s.com...
been
fast
Old January 25th 04, 06:00 PM
S. Sampson
the Dash One".
Is the AOA indicator a piece of string like Wilbur and Orville had?
airspeed computed.
That's in case the AOA indicator goes T.U. :-)
Old January 25th 04, 06:07 PM
Jim Baker
Yes, kind of. It's such a fast, heavy airplane that we use yarn rather
than string. ;-)
"S. Sampson" wrote in message
news:2DSQb.6653$ce2.804@okepread03...
do
by
the Dash One".
an
airspeed computed.
Old January 25th 04, 11:52 PM
John R Weiss
"S. Sampson" wrote03...
No, but the yaw indicator on the F-14 is!
Old January 26th 04, 01:53 AM
Frijoles
I've known generally what (the string) was for a long time but never
bothered to ask when it was referenced (primarily)? High alpha stuff?
Landing pattern? Single engine would be an obvious case...anything else?
More for "departure prevention," TF 30 "management" or both?
"John R Weiss" wrote in message
news:ZMXQb.146068$I06.1467724@attbi_s01...
Old January 26th 04, 04:20 AM
John R Weiss
"Frijoles" wrote...
I never flew the Turkey, but probably all of the above.
I flew gliders with them, and they replaced the turn balance ball -- "step on
the knot".
Old January 26th 04, 05:15 PM
Ed Rasimus
On Mon, 26 Jan 2004 00:53:22 GMT, "Frijoles"
We had a "yaw string" on F-4s in USAF. I don't recall if there was on
for the F-105. The main purpose in operational aircraft was during
weapons deliver and the most important weapons delivery with a yaw
concern was strafe or rockets.
Any yaw at the moment of release means the sight is pointing left or
right of the flight path and the weapons will go in the direction the
aircraft has imparted, not the place that the sight tells you. Yaw
left, shoot right.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
Old January 27th 04, 01:00 AM
Frijoles
Thanks -- had forgotten about sideslip and FF ordnance realignment with the
relative wind...
"Ed Rasimus" wrote in message
left, shoot right.
Ed Rasimus
ISBN #1-58834-103-8
Old January 25th 04, 06:43 PM
Frijoles
Good job JB, you compute an airspeed for the Bone. And so your point
is...*what* about landing the Harrier?
"Jim Baker" wrote in message
news
do
that
airspeed computed.
JB
ink.net...
20
to
angle
kts
be
s.com...
been
for
in
fast
know.
FA: Flying Aviation Videos - Concorde - Just Planes - Military - B-52, F/A-18, Etc Robert Aviation Marketplace 0 August 29th 04 09:27 PM
Updated List of Military Information-Exchange Forums Otis Willie Military Aviation 0 December 29th 03 03:20 AM
List of News, Discussion and Info Exchange forums Otis Willie Military Aviation 0 November 14th 03 06:01 AM
08 Nov 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 November 9th 03 02:51 AM
RUSSIAN WAR PLANES IN ASIA James Military Aviation 2 October 2nd 03 12:25 AM
