Just pull the little red handle!
Old September 4th 10, 03:42 PM posted to rec.aviation.soaring
mike
Default Just pull the little red handle!
On Sep 1, 1:02*am, Walt Connelly Walt.Connelly.
JJ Sinclair;739478 Wrote:
I have felt for some time now that my back-pack parachute provides
little more than a false sense of security..............I don't think
I would ever get out of a spinning, tumbling ship. The BRS has been
demonstrated to work as low as 260 feet during the FAA certification
of the Cirrus. This could save you from a mid-air in the pattern or
that all time biggest killer. stall/spin turning final. BRS also
provides a way out of structural failures or pilot incapacitation. How
about stuck low on the wrong side of the ridge with nothing but trees
in all directions?
The BRS descent rate is about like a normal parachute (like stepping
off a 7' ledge). The Genesis installation calls for a 4-point bridle
that attaches to all 4 lift fittings, this will result in *a wings-
level, slight nose down attitude under the chuts. *Lowering the gear
will absorb some of the landing forces.
Flarm is great and I'd buy it in heartbeat if everybody had it. Lets
not forget that 2 of the 4 mid-airs in the US last year involved a tow
plane and some of them still don't even have radios, let alone
transpponders, Pcas or Flarm.
Bottom line is; We are all the chairman of our own safety committee
and we must take the actions we believe to be the best course to keep
us out of harms way. For me that includes installing a BRS.
Cheers,
JJ
I have always felt that listening to those with greater experience than
myself is one of the best safety devices. *Seems that today people spend
more time flying with their heads inside the cockpit than outside. *With
a parachute, BRS, FLARM, survival kit, bail out bottle, knife, gun,
flares, medical kit, lunch, snacks, condoms and everything else one
could carry in a glider, it's a wonder these things can get off the
ground.
As a relative newbie to the world of gliding, I have in my some 100
flight had two close calls. I consider myself a heads up kind of guy and
try hard to keep my head on a swivel, my eyes wide open and paying
attention. *
I have asked a few local pilots why it seems that the preferred color
for gliders appears to be white. *I understand that the sun might
degrade a more brightly painted ship faster than a base white one. *Is
this really true? *It would seem to me that the cheapest form of
avoidance would be making ourselves more visible. * I am in the market
for an older, aluminum ship and would consider painting it bright red if
it would increase my visibility. *
I understand that FLARM only works if the other guy has one. *I guess
for the time being I will have to depend on my parachute and luck for
survival, along with a healthy dose of paying attention. *
Walt
Walt Connelly
There is a problem with darker colors on the majority of composite
sailplanes. The darker colors get hotter by absorbing more heat in the
sun, and at a certain temperature the glass/epoxy matrix will begin to
loose its structural integrity. Look up T sub G. Go to your glider
field in the midday sun and put your hand on a glass ship painted
white, do the same on a red 1-26.
Mike "0"
Old September 4th 10, 06:47 PM posted to rec.aviation.soaring
5Z
On Sep 1, 12:02*am, Walt Connelly Walt.Connelly.
The BGA did a study and bottom line is the only thing that really
helps is adding highly reflective bits to leading and trailing edges.
Bright colors and contrasting colors end up being worthless at
anything but close range, is my understanding.
-Tom
Old September 4th 10, 10:59 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
On 9/4/2010 11:47 AM, 5Z wrote:
On Sep 1, 12:02 am, Walt ConnellyWalt.Connelly.
this really true? It would seem to me that the cheapest form of
avoidance would be making ourselves more visible. I am in the market
-Tom
One good test is worth a thousand considered opinions. But that's just my
opinion...
Seriously, I doubt there's any single color/device that is '100% visually
"best".' The devil's in the details. F'r'example...
Reflective tape is likely pretty ineffective unless in non-diffuse sunlight.
Solid yellow is definitely better/more visible than many other primary colors
I've seen on sailplanes under many lighting conditions...but virtually
disappears in certain conditions of beneath-cloud shadow. Both observations
true for distant sightings, too, at least with my eyes.
In 'essentially solid color terms', dark orange is probably 2nd-best IMHO,
with red less so. Blue and green not so good, though against certain
backgrounds both can stand out.
Shiny silver is mostly excellent camouflage.
So anyone looking for a 'panacea visibility scheme' is likely doomed to
disappointment...but anyone rationalizing 'white is as good as anything else'
is (arguably) - and easily personally testable by keeping a good lookout in an
environment of mixed sailplane colors - wrong.
YMMV.
Bob W.
Old September 5th 10, 06:16 AM posted to rec.aviation.soaring
Jim Logajan
to disappointment...
High intensity flashing beacon powered from a solar-charged battery? ;-)
(Haven't checked to see if such a thing already exists.)
Old September 1st 10, 04:54 PM posted to rec.aviation.soaring
Surfer![_2_]
"JJ Sinclair" wrote in message
snip
Personally I know one glider pilot whose life was saved after a mid-air by
his parachute, and I know of at least one more. I also know of a poor chap
who managed to egress from his glider but whose parachute malfunctioned.
So, your parachute as well as being a pricey cushion might save your life
one day.
How easy it is go get out might also depend on the glider design as well as
what has happened to it. It seems likely to me that the AS front canopy
hinge designs with a lifting panel leave a lot more room than the SH side
hinge ones especially if the panel is non-lifting. I got in a Discus with a
non-lifting panel once, and the thought crossed my mind that it would
probably be very difficult to get out in a hurry, whereas my own has a
front-hinged canopy and a massive gap once it's open - or the canopy is
removed.
BTW I pulled the handle on my parachute last time it was repacked - was
surprised how little force was needed, and how little happened given I was
stood on the floor in the packing room!
Wing Launch - Can it pull your wings off? ContestID67[_2_] Soaring 92 September 5th 10 10:51 PM
physics question about pull ups John Rivers Soaring 59 June 10th 10 12:21 PM
Pull up a chair and hear me out: Vaughn Aviation Marketplace 0 February 2nd 06 02:04 AM
Pull plane by tail hook Tarif Halabi Owning 19 February 24th 04 02:27 PM
Glider pull-up and ballast M B Soaring 0 September 15th 03 06:29 PM
