I am looking for used draw bar (the tong) and all the parts that go
inside of the Cobra trailer. Does anyone here in the US have a damaged, ruined, not road worthy trailer and is willing to sell those parts to me? Thanks, Jacek, Pasco, WA 509-380-4106 |
Not to hijack your thread Jacek, but I was just about to post
regarding my Cobra trailer... The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel |
On Sep 2, 10:13*am, "noel.wade" wrote:
Not to hijack your thread Jacek, but I was just about to post regarding my Cobra trailer... *The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). *I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? *Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel I believe Rex and Noelle Mays at Williams Soaring Center have a pretty full stock of Cobra trailer parts. You might try them first. Thanks, Craig Funston |
On Sep 2, 1:13*pm, "noel.wade" wrote:
Not to hijack your thread Jacek, but I was just about to post regarding my Cobra trailer... *The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). *I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? *Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel Call John Murray. |
Last time I measured--a while ago, the smallest floor jack (on wheels) from
NAPA auto parts would have fit but for machining one bushing. Simple job but I didn't have a lathe then,. I was going to take it back for a refund, but I decided to keep the jack. It was about the same price as the replacement part anyway. I would have saved a few bucks, and the shipping. -- Hartley Falbaum "noel.wade" wrote in message ... Not to hijack your thread Jacek, but I was just about to post regarding my Cobra trailer... The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel |
For the older cobra's with the hand crank Screw I used two of these and
some minor welding of the together worked for me: http://www.harborfreight.com/1-1-2-h...ourc e=nextag Although the ones I found years ago were a lot cheaper IIRC $9.99 ea from a tool place in the NW US but can't seem to find them now. CH |
Ooops!
pardon me--I didn't read "screw jack" and assumed hydraulic. Sorry -- Hartley Falbaum "HL Falbaum" wrote in message m... Last time I measured--a while ago, the smallest floor jack (on wheels) from NAPA auto parts would have fit but for machining one bushing. Simple job but I didn't have a lathe then,. I was going to take it back for a refund, but I decided to keep the jack. It was about the same price as the replacement part anyway. I would have saved a few bucks, and the shipping. -- Hartley Falbaum "noel.wade" wrote in message ... Not to hijack your thread Jacek, but I was just about to post regarding my Cobra trailer... The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel |
Not to hijack your thread Jacek, but I was just about to post regarding my Cobra trailer... *The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). *I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? *Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel I just replaced the failed scissor jacks on my Komet trailer with a motorcycle scissor lift I found at T-Motorsports. The lift has a wide stable platform and just fit between the fuse dolly rails. I attached the lift to the rails with a heavy piano hinge I got from McMaster Carr. The jack capacity is 1,000 lbs and it is a bit heavier than the original jack set up but it works great. Try this link to see the lift: http://www.t-motorsports.com/product...-mlift-mh8054/ Good luck, Steve |
On Sep 3, 6:27*am, SP wrote:
On Sep 2, 10:13*am, "noel.wade" wrote: Not to hijack your thread Jacek, but I was just about to post regarding my Cobra trailer... *The fuselage-ramp scissor-jacks just failed (stripped thread, then the bearing failed under the resulting load). *I've seen some older postings about these jacks but does anyone have an up-to-date source for small scissor jacks that would fit? *Most retail-store jacks are too big, and I'm willing to bet that if I go direct to Cobra or one of the glider mfgrs/dealers that it'll cost me a bundle. Thanks, --Noel I just replaced the failed scissor jacks on my Komet trailer with a motorcycle scissor lift I found at T-Motorsports. The lift has a wide stable platform and just fit between the fuse dolly rails. I attached the lift to the rails with a heavy piano hinge I got from McMaster Carr. The jack capacity is 1,000 lbs and it is a bit heavier than the original jack set up but it works great. Try this link to see the lift: http://www.t-motorsports.com/product...lift-scissor-j... Good luck, Steve A couple of notes on the motorcycle lift: The base plate has two brackets on it that I cut off. The jack gets very low but it's just low enough for my LS-3a. SP |
| Thread Tools | |
| Display Modes | |
| COBRA TRAILER | Gordon Schubert[_2_] | Soaring | 0 | February 10th 09 05:15 AM |
| WTB: Cobra Trailer for LS-4 | [email protected] | Soaring | 0 | July 31st 08 06:04 PM |
| Cobra Trailer | [email protected] | Soaring | 22 | December 8th 06 12:38 AM |
| Cobra Trailer | Soaring | 1 | September 28th 03 02:14 PM | |
| FS: Cobra Trailer | Ed Byars | Soaring | 0 | September 22nd 03 05:47 PM |
