TE probe up or down?
On Sep 27, 5:13*am, "kirk.stant" wrote:
It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL Well, your very own Oran W. Nicks describes the development of the probe in your "Soaring" magazine of September 1976. He definitely has the probe pointing up. As he is the inventor and arrived at the configuration in extensive wind tunnel tests that settles it for me. Rolf |
"Rolf" wrote in message ... On Sep 27, 5:13 am, "kirk.stant" wrote: It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL Well, your very own Oran W. Nicks describes the development of the probe in your "Soaring" magazine of September 1976. He definitely has the probe pointing up. As he is the inventor and arrived at the configuration in extensive wind tunnel tests that settles it for me. Rolf And Professor Irving, who developed two different designs, shows his pointed down, and 20 degrees forward. Professor Irving also used wind tunnel testing. So there! Hartley Falbaum "KF" USA |
This is pure speculation, but I wonder if Prof Frank Irving’s
preference for the probe pointing downwards is because in his day, and particularly in the UK, cloud flying was commonplace. It follows that accumulation of water droplets on the probe was also, common. After only a few minutes in cloud, it is usual to find that the vario starts misbehaving. (I find that typically, it suddenly stops displaying rate of climb accurately, and then flicks to a different reading, then settles back to something sensible for a few seconds, and then repeats the cycle. I put this down to water droplets accumulating, to the point that they block the tiny holes in the probe, then suddenly get freed, then repeat the cycle. I have no means of knowing whether my speculation in this respect is accurate.) Anything that can delay that, or at least get rid of surplus water droplets so that the vario returns to functionality for a few seconds at a time, is probably worth doing. If you're not flying where water droplets are likely to accumulate on the probe, other things being equal it seems to me that keeping it as far from disturbed air over the wings as possible is a good thing, hence up. Just my two cents worth. Chris N |
On Sep 28, 10:45*am, Chris Nicholas wrote:
This is pure speculation, but I wonder if Prof Frank Irving’s preference for the probe pointing downwards is because in his day, and particularly in the UK, cloud flying was commonplace. It follows that accumulation of water droplets on the probe was also, common. *After only a few minutes in cloud, it is usual to find that the vario starts misbehaving. (I find that typically, it suddenly stops displaying rate of climb accurately, and then flicks to a different reading, then settles back to something sensible for a few seconds, and then repeats the cycle. I put this down to water droplets accumulating, to the point that they block the tiny holes in the probe, then suddenly get freed, then repeat the cycle. I have no means of knowing whether my speculation in this respect is accurate.) *Anything that can delay that, or at least get rid of surplus water droplets so that the vario returns to functionality for a few seconds at a time, is probably worth doing. If you're not flying where water droplets are likely to accumulate on the probe, other things being equal it seems to me that keeping it as far from disturbed air over the wings as possible is a good thing, hence up. Just my two cents worth. Chris N Gliders with short rear fuselage mounted TE probes often suffer from a flickering and false vario reading when flown at high angles of attack, as in a thermalling turn. I assume that this is because of interference from turbulent air coming off the wings. I have also experienced this effect with some fin mounted probes. I would point the probe upwards to keep it as clear as possible from any wing turbulence. Derek C |
At 14:21 28 September 2010, Derek C wrote:
On Sep 28, 10:45=A0am, Chris Nicholas wrote: This is pure speculation, but I wonder if Prof Frank Irving=92s preference for the probe pointing downwards is because in his day, and particularly in the UK, cloud flying was commonplace. It follows that accumulation of water droplets on the probe was also, common. =A0After only a few minutes in cloud, it is usual to find that the vario starts misbehaving. (I find that typically, it suddenly stops displaying rate of climb accurately, and then flicks to a different reading, then settles back to something sensible for a few seconds, and then repeats the cycle. I put this down to water droplets accumulating, to the point that they block the tiny holes in the probe, then suddenly get freed, then repeat the cycle. I have no means of knowing whether my speculation in this respect is accurate.) =A0Anything that can delay that, or at least get rid of surplus water droplets so that the vario returns to functionality for a few seconds at a time, is probably worth doing. If you're not flying where water droplets are likely to accumulate on the probe, other things being equal it seems to me that keeping it as far from disturbed air over the wings as possible is a good thing, hence up. Just my two cents worth. Chris N Gliders with short rear fuselage mounted TE probes often suffer from a flickering and false vario reading when flown at high angles of attack, as in a thermalling turn. I assume that this is because of interference from turbulent air coming off the wings. I have also experienced this effect with some fin mounted probes. I would point the probe upwards to keep it as clear as possible from any wing turbulence. Derek C We use to use a nose mounted probe on a K18 I flew,not sure how good it was, but the yaw string mounted on it was much better as it didn't over react as much. Jon |
Similar Threads | ||||
Ka-6 TE Probe | vontresc | Soaring | 14 | August 30th 08 03:17 AM |
Probe problem | smf | Home Built | 3 | July 8th 07 01:29 PM |
TE Probe on ASW-15 | [email protected] | Soaring | 4 | April 29th 07 01:43 AM |
Multi - probe | KP | Soaring | 1 | March 7th 05 06:03 PM |
TE-Probe for 1-26D | Heinz Gehlhaar | Soaring | 6 | January 17th 05 10:52 PM |
